EMR Class 360's
MML
25 Oct 2015
I've noticed in the past few days that some services are running in 12 car formations now
Last Thursday saw 12 car units in operation. Unfortunately today we see the return of two 4 car units.
Come on EMR. 8 car should be the minimum acceptable with the loading today, and 12 car should be present on peak time workings.
I saw one unit had a smashed windscreen again last week and had been couple in the centre to allow continued running.
Obviously pheasant season again, but you'd think there is some way of deterring bird strikes through colour or design of the front end.
QSK19
29 Dec 2020
Leicestershire
Adds to my strong belief in EMR’s style-over-substance way of doing things. In the case of the 360s, making a nice paint job so that their PR looks super instead of taking into account practical factors such as needing to minimise bird strikes.
Nevertheless, I’m sure these trains are cursed - what will the next thing be? :lol:
pompeyfan
24 Jan 2012
Pheasants are going to pheasant, how you can blame the TOC for a bird strike is beyond me. At least with 4 car MUs you have the ability to box in the cab, with the modern practice of fixed 9/10/12 car units you lose that ability. Internal work should have taken priority to the repaint but then the repaint might have been required due to the age of the unit etc.
LowLevel
26 Oct 2013
The 360s suffer far more broken windscreens due to bird strikes than any other train I've come across. It's a definite issue. The other trains on the same route have nowhere near as many incidents.
pompeyfan
24 Jan 2012
I don’t doubt what you’re saying but that’s not EMRs fault, maybe the birds haven’t got used to electric services and they’re still expecting HSTs or 222s instead. There isn’t really a huge amount the TOC can do
43096
23 Nov 2015
As has been said previously, the bodywork overhaul (which includes repaint) is not optional.
Agent_Squash
22 Jul 2016
Must have been a very, very, very light one then - can’t say I’ve noticed any difference!
To quote the words of Jim Hacker, so light it must've been in very faint pencil...
The 360s are dying out for some love. Great, capable units. Just not suited interior wise for the jobs they've been put on.
The birds need to adapt to the non streamlined front ends!
Kneedown
29 Dec 2007
Nottinghamshire
You'll get plenty of birdstrikes daily whatever train you drive. The issue with 360s is the windscreen itself that can shatter upon highspeed impact with even a pigeon. No other class i've driven has had windscreens shatter due to pigeonstrike, or pheasantstrike for that matter.
dorsetdesiro
30 Oct 2017
Some artifical noise boxes may need fitting, on the 360s' ends, to mimic sounds of a diesel engine for warning the birds like some electric cars do as they're too quiet on the roads
59CosG95
18 Aug 2013
Beeston (Notts)
Would that be due to the design of the windscreen itself, being curved over a much larger area than its corridor counterparts (i.e. 350s/444s/450s)?
Or rather than causing noise pollution (nice quiet EMUs are just that, nice) you could just, well, you know, make the windscreen strong enough?
Trainbike46
18 Sep 2021
belfast
I think that would be a good idea in addition to any other measures to reduce the likelihood of bird strikes
AM9
13 May 2014
St Albans
In theory a curved windscreen should be more resistant to strikes than a flat one on the same construction, but the class 360 ones are almost square so maybe it's just the size that a) makes them less robust and b) a bigger target to be hit by anything.
I'm sure that glass windows could be made more more robust, but that might have been too expensive at the time of manufacture and experience in services has resulted in a decision to live with the problem.
MML
25 Oct 2015
I can see it now. EMR taping a Kazoo to the front of a 360. Correctly branded of course.
Northampton
You can sound the horn every 3 seconds if you like, the Pheasant still won't move. They're incredibly oblivious birds. Do 700s have an issue with windscreen strikes or is it a 360-specific issue? If so, surely there's a film or something you can put on the window to stop it smashing on impact.
baz962
8 Jun 2017
Pheasants make pigeons look bright.
Kneedown
29 Dec 2007
Nottinghamshire
I'm not a technician so cannot give a definitive answer, but the glass does seem a lot thinner than on say, a 222 or a 170.
Silverlinky
3 Feb 2012
Plenty of 350's have suffered broken windscreens due to pigeon strikes. They've had their fair share of pheasants and buzzards too.
Perhaps its just a Desiro thing.....don't remember the 321's having many issues.
There never seemed to be a particular problem in all the years when most of the trains were flat-ended 319s.
It may be more difficult to make curved windscreens stronger. Way back in the 1960s BR had a phase of fitting wraparound windscreens to new units such as the Glasgow and Clacton EMUs, but they were later replaced by flat ones. The ones on the 360s are much larger than those were.
Northampton
Mikey C
11 Feb 2013
Bombardier/Alstom Derby will be feeling smug. We can't get the Class 701s working, but at least our trains can withstand being hit by a dopey pheasant ;)
LowLevel
26 Oct 2013
It's not that. It's the fact the windscreens break far more on impact than any other train I've come across, as other correspondents on here have mentioned. There's some about the 360 windscreen design that is far more likely to break from a simple bird strike. I can trundle along in my 15x and see tens of the poor sods go bouncing out the back or off to the side at certain times of year and I've never had a driver report a broken windscreen as a consequence (albeit there was a problem with some 153s a few years back shattering on impact with pheasants).
360s are a very regular occurrence.
AM9
13 May 2014
St Albans
Does your 15x do 110mph? ;)
LowLevel
26 Oct 2013
Nope, but the 170s occasionally do the ton with a good tail wind and favourable gradient :p
The 360s are certainly vulnerable though.
Northampton
Perhaps the windscreens on the 22x fleet have a higher degree of strength for 125mph running?
Tbf the pidgeon is a much smaller bird and it hit the pillar, not the screen.
I did once have a Pheasant that managed to crash into my house and die on our doorstep, which shows just how thick these birds are (My house was 2-storey detached and well clear of any tress as well as being, unsurprisingly, static)
