Emergency engineering work at Lewisham from 22:00 this evening
Emergency engineering work will be taking place at Lewisham this evening and is expected to continue for a number of weeks. This is to allow Network Rail to replace a damaged piece of equipment at Lewisham. Because of this, the following changes will apply -
Tuesday 30 September 22:00 - Wednesday 1 October 04:00
No Southeastern trains will call at Lewisham.
Trains between London and Hayes will not call at New Cross, St Johns or Lewisham in either direction.
There will be no trains between Lewisham and Barnehurst.
If you are travelling between London and New Cross or St Johns, you should use trains between London and Orpington which will stop additionally at these stations.
For journeys between London and Lewisham, we recommend that you travel to Greenwich and take the DLR to Lewisham.
Your tickets will be accepted on DLR services and London Buses at no extra charge.
Wednesday 1 October until further notice
Trains between London Victoria and Dartford via Bexleyheath will be diverted via Sidcup.
If you are travelling between London Victoria and stations between Lewisham and Dartford via Bexleyheath, you will need to change trains at Lewisham.
We are working closely with Network Rail to restore a normal service as quickly as possible and will keep you updated when things change.
Charing Cross and Cannon Street services via Bexleyheath can still run as they don't need the crossover, so an interchange between the VIC-DFD and Bexleyheath line will be possible at Lewisham.
Part of the 'diamond' crossover at the London end of the station is defective and it needs to be removed. For its removal tonight, trains can't run over the crossover or on the North Kent around it, meaning Hayes services will have to use Tanners Hill and can't stop at New Cross or St John's just for tonight.
Once it's removed, trains from Nunhead will not be able to reach the up/down North Kent through platforms 3 and 4, hence the Victoria to Dartford trains being diverted via Sidcup. Charing Cross and Cannon Street services via Bexleyheath can still run as they don't need the crossover, so an interchange between the VIC-DFD and Bexleyheath line will be possible at Lewisham.
Parts been ordered from Germany I believe, obviously have to be made, delivered and installed. I'd expect end of October.
Is there no companies anymore left in the UK that manufacturer railway track?
It is probably this sort of incident that has led to diamonds being designed out of new or revised track layouts wherever possible.
Indeed that's probably why there isn't a UK manufacurer - BR/Railtrack/NR have been removing diamonds for many years now where possible. A lot of junctions have been converted to double leads.
So in a way the "mini thameslink" idea i suggested (by preventing flat movements across that junction; send all from-blackheath services to/from cannon street and all from-hither green/ladywell to nunhead/london bridge) has come to fruition.
And all they had to do was find a faulty piece of railway equipment to do it
Much cheaper than the billions spent just up the road?![]()
Emergency engineering work will be taking place at Lewisham this evening and is expected to continue for a number of weeks. This is to allow Network Rail to replace a cracked rail at Lewisham
They will, but the Charing Cross trains will have to cross at Spa Road, since they can't access the Tanners Hill flydown. If this were to happen again after Christmas, once Spa Road has been taken out of use, they wouldn't be able to run Bexleyheath-Charing Cross at all...
Repairs to damaged equipment at Lewisham will be taking place for at least the next four weeks.
The crossing that allows trains to run from the Bexleyheath line through Lewisham towards London Victoria has broken. This crossing is a specialist piece of equipment and it will take at least four weeks to build a replacement. We are working with Network Rail to ensure the work is completed as quickly as possible.
Because of this, the following changes will apply from Wednesday 1 October until further notice:
All trains between London Victoria and Dartford via Bexleyheath will be diverted via Sidcup. These trains will stop additionally at Crayford, Sidcup and Hither Green in both directions.
Some Cannon Street services will be diverted to run to / from London Blackfriars and will depart slightly earlier than the normal Cannon Street departure time -
Morning peak Cannon Street services diverted to London Blackfriars:
- 06:48 Broadstairs to London Cannon Street
- 05:45 Dover Priory to London Cannon Street
- 06:25 Broadstairs to London Cannon Street
- 06:57 Ramsgate to London Cannon Street
- 07:19 Ramsgate to London Cannon Street
Evening peak Cannon Street services diverted to run from London Blackfriars:
- 16:46 London Cannon Street to Ramsgate (will depart Blackfriars at 16:40)
- 17:08 London Cannon Street to Broadstairs (will depart Blackfriars at 17:00)
- 17:30 London Cannon Street to Ramsgate (will depart Blackfriars at 17:20)
- 17:52 London Cannon Street to Broadstairs (will depart Blackfriars at 17:40)
- 18:14 London Cannon Street to Ramsgate (will depart Blackfriars at 18:00)
- 18:44 London Cannon Street to Ramsgate (will depart Blackfriars at 18:40)
Ticket acceptance
Southeastern tickets will be accepted on London Underground services between Charing Cross, Cannon Street, Blackfriars and Victoria.
Southeastern tickets will be accepted on Thameslink services between Blackfriars and London Bridge.
Passengers on the Bexleyheath line can use stations on neighbouring lines at no extra cost.
Apparently the case against that idea is the large volume of passengers changing trains at London Bridge that would result
I can't check just now, but can someone advise me if there were any preliminary indications, including anything that led to an ESR/TSR (not me) in that location recently?
They would still be able to get to Charing Cross. (using the 'Down Charing Cross')
Presumably the overnight work was to replace the cracked diamond with some plain track for one of the two routes?
So nothing is diverting away from Blakfriars in lieu of the extra services at Blackfriars noted above?
Plenty of space at Blackfriars, even with GTR trains abandoned everywhere.
Have you thought that it might be a specialist piece of equipment that has to be made "bespoke" and the only available capacity was in Germany?
