East Midlands Trains Liverpool
Geargrinder
13 Oct 2012
I've had cause to use the EMT Liverpool - Norwich service a couple of times this week. Not the whole way (!) but from Peterborough to Ely. My question is do EMT have drivers & conductors based at Liverpool or do the trains start elsewhere early in the morning ?
tbtc
16 Dec 2008
Reston City Centre
I've had cause to use the EMT Liverpool - Norwich service a couple of times these week. Not the whole way (!) but from Peterborough to Ely. My question is do EMT have drivers & conductors based at Liverpool or do the trains start elsewhere early in the morning ?
They are based in Nottingham, so run empty from Nottingham to Liverpool (avoiding Sheffield) at something like four in the morning.
sonic2009
19 Jan 2010
Crewe
No conductors or drivers based at Liverpool for EMT AFAIK, the first Norwich service from Liverpool in the morning is formed by a empty stock move from Nottingham.
43074
10 Oct 2012
EMT have no train crew based at Liverpool so they are worked by Nottingham crews West of there.
The first two services of the day are formed of a pair of trains and crew that start their day in Nottingham, these trains go to Liverpool empty as train 5M06 (with 4 units coupled together as an 8-coach train), where they split and the front two units (i.e. farthest from the gateline at Liverpool Lime Street) work the 06:47 to Norwich, and the rear two units work the 07:43 to Norwich.
(Interestingly, the empty coach move runs via Derby, the Dore curve and the Chat Moss route - I assume this is to maintain route knowledge??)
EDIT: Beaten to it!
sonic2009
19 Jan 2010
Crewe
The ECS will start from Etches Park during the Nottingham blockade AFAIK
dggar
16 Apr 2011
I recently travelled on the 17:52 Ely to Manchester( on a Saturday) where the train terminated.
There was an request by the train staff to vacate the train as quickly as possible.
Will this set be running ECS back to Nottingham?
Is the depot at Nottingham east of the station, and if so how will the 6 week remodelling work at Nottingham affect things?
Geargrinder
13 Oct 2012
I knew someone would know ! Presumably they do have crews based at the other end in Norwich.
Tomnick
10 Jun 2005
If I'm not mistaken (can't check now) - I thought that one came back from Manchester in service. The arrangements for the Notts blockade have been discussed at length elsewhere on here, but most will go to Etches Park (Derby) instead (some 15x go there already), with possibly a few more than usual outstabling elsewhere.
northwichcat
23 Jan 2009
Northwich
In an ideal world some of Northern's Liverpool or Manchester based crews would sign class 158s and then they would work early morning/late night services on behalf of EMT instead of long ECS runs.
bunnahabhain
8 Jun 2005
It use to form the last stopping service over the Hope Valley, which is now served using the last Liverpool. The one that terminates at Manchester is now ECS via Romiley and Dore South Curve.
Liverpool depot used to sign through to Peterborough in Reggie Rail days so you had none of these extremely long ECS movements.
When it was Central trains they had more of a presence in Liverpool with the Birmingham trains. Did the have crews and stable trains at Liverpool at that time, and did the same crews work both routes?
northwichcat
23 Jan 2009
Northwich
I've noticed one guard with very distinguishable features who used to work Liverpool-Norwich under Central now sometimes appears on Liverpool-Birmingham under LM.
Tomnick
10 Jun 2005
Thanks - I knew I should've checked ;) .
bunnahabhain
8 Jun 2005
Yes. Nottingham depot used to sign Liverpool to Birmingham via Stafford, and Birmingham to Nottingham via Derby and Leicester. Trains were also covered by Leicester, Birmingham and Crewe depots on the Liverpool to Norwich run (I think!). I believe some old Nottingham turns took you on a grand tour from Nottingham to Birmingham, up to Liverpool, and back down to Nottingham. Likewise some turns did the same with the Crewe route.
PHILIPE
14 Nov 2011
Caerphilly
The first entry on the Longest ECS Movement thread on alterations etc., Board.
Kneedown
29 Dec 2007
Nottinghamshire
Nottingham crews have never signed Liverpool to Birmingham. Not post 95 anyway when i went there.
The closest we ever came to that route was one Saturday or Sunday evening job where we were booked to travel back passenger from Liverpool via Crewe.
trentside
14 Aug 2010
Messroom
I believe Derby conductors also have a part in some of the Liverpool workings now.
I'm not sure about drivers though.
Kneedown
29 Dec 2007
Nottinghamshire
Yep, Derby Conductors have a couple of Notts - Liverpool jobs. Not the Drivers though. The day they let us have some London work is the day we'll let them have some Liverpools!
Unfortunately inter-depot rivalry is alive and well.
met331
26 Feb 2010
East Mids
we used to have that late job where we coupled to the last Liverpool-Brum travelled pass then pick up the empties off Tysley usually back over Stenson
bunnahabhain
8 Jun 2005
Yep, sorry, you're right. I think it was Leicester that did Birmingham to Liverpool.
Kneedown
29 Dec 2007
Nottinghamshire
Yep, forgot about that one. Never had that job with any regularity as i've never signed Tyseley, but had it on occasion when it was arranged for a New St man to bring the empties into Brum from Tyseley.
I think you're right. I'm sure Leicester men used to go that way before they came under XC, or at least until Central opened the depot at Crewe.
Do you remember that late Liverpool job when we used to swap units with the New St crew?
Remember the time when the New St Driver was waiting on the platform for the incoming 170 and off they went, leaving the Notts crew to walk over to their train where they found, waiting for them on Platform 9......... a 323!
met331
26 Feb 2010
East Mids
I do yes i forget which driver but i went up a couple of days later and control rang to confirm we had a 170
43074
10 Oct 2012
How big is EMT's Norwich depot and do they do any other work away from Liverpool - Norwich?
bunnahabhain
8 Jun 2005
Tiny, just over a dozen of drivers and conductors. Routes are Norwich to Liverpool via Grantham and Melton, and Nottingham to Leicester and Worksop.
jizzer
2 Feb 2012
Liverpool depot used to sign through to Peterborough in Reggie Rail days so you had none of these extremely long ECS movements.[/QUOTE]
It was Piccadilly traincrew that signed Peterborough not Liverpool.
