East Kilbride/Barrhead electrification updates
Southsider
10 Aug 2015
I don’t know if you ever experienced it in a 1st generation DMU: it was worse…..
Biggest problems I see from my non-civil engineering perspective are Clarkston Toll (major road) and Thorntonhall (right next to the station). Everything else should be relatively straightforward including getting rid of redundant bridges (I think a couple near Hairmyres were removed recently). Beyond Hairmyres, the bridges are modern and shouldn’t present any clearance issues.
The fact that there are two, low, arched bridges either end of Clarkston station is an interesting problem. No simple diversion routes for large vehicles if they’re replaced, track lowering would require platform lowering.
You don't happen to know what the local rainwater drainage is like? Is lowering even an option?
snowball
4 Mar 2013
As I've said several times before, for the B767 the obvious solution is to realign it onto a new bridge.
14 Mar 2021
At Barrhead station, the temporary road traffic signals have been removed (they were there when a low loader was parked outside the station on Paisley Road).
There is a new foundation on the Carlibar Road (main entrance) side of the station.
The short term parking bay that was used for the Rail Replacement Bus is now fenced in and in use as a temporary compound. Apparently, the bus contractor was not informed of this decision and so they need to change their pick up and drop off point, otherwise their coaches obstruct the road.
Barrhead Station Electrical Substation.jpgBarrhead Station new foundation.jpg
kaysha
24 May 2023
Falkirk
Yes I did! When I started work in 1975 and used the train to get to work I think it took the thick end of 1/2 hour to travel the short distance from Glasgow to Clarkston. If travelling outwith the rush hour the bus was always quicker and more frequent. It was only one train an hour and no Sunday service then.
MadMac
13 Jun 2008
Moorpark, CA
The one at the Busby end doesn’t look as if a period of closure would present that much of a problem, leading to housing with other ways in. Clarkston Road would be a difficult matter with no easy diversion around it. Like others, I’m surprised that there’s been little information out there as yet.
sannox
1 Mar 2016
Clarkston Road is probably off-line construction, move to new bridge and then demolish old one.
Southsider
10 Aug 2015
There's not really the space to move to a new one while the old one is still there.
It depends on the alignment that is used. A diagonal from before the existing bridge to the roundabout seems feasible. It would also make it easier for buses and HGVs to negotiate.
snowball
4 Mar 2013
We seem to have had this discussion about Clarkston Road several times in the history of this thread. To me it seems obvious that there's plenty of room to build a new bridge clear of the existing one and improving the alignment of the road. You might have to take a bit of land from the adjacent car park, and once the new bridge is in structurally complete there might need to be road closures while you divert first mains services and then traffic onto it.
Of course this doesn't prove it will be done that way. The local authority may be unable to contribute money on the scale needed.
Link is to Google satellite view of the area.
nlogax
Mostly Glasgow-ish. Mostly.
Discovered this on Saturday when I went to use the RRB, and this appeared to be a surprise to the assistants on the ground. The Glasgow-bound fast bus had to park at bottom of the ramp to the recycling centre and they had to marshal us across the street to board it.
snowball
4 Mar 2013
A web search found this video, "Glasgow to Barrhead Electrification - Week 1 Update", dated today.
clc
31 Oct 2011
So they are reopening the underpass as a replacement for the footbridge? Nitshill isn’t the nicest area, which might give a clue as to why the underpass was closed in the first place.
380101
18 Feb 2015
I believe they are still installing a new, OHLE compliant, footbridge. The underpass re-opening will allow the Up side platform to be fully accessible again for all users.
clc
31 Oct 2011
Thanks, that’s good go hear.
14 Mar 2021
The stone masons have been working on-site at the Moray Place footbridge building the stone cladding on the footbridge abutments.
Moray Place footbridge 1.jpgMoray Place footbridge 2.jpgMoray Place footbridge 4.jpg
OB23Gone
22 Aug 2022
Rick1984
23 Aug 2012
Space looks very tight between front of steps and railings
OB23Gone
22 Aug 2022
NO NEW Footbridge. Went along to the Drop In. Asked NR Rep that very question answer was A NO. Met a Surveyor today just coming of Nitshill Station and his answer about a new bridge and got a NO again.
So looks like the locals will only have the Under pass as their option. Post #1429 has the Layouts
N1
10 Aug 2022
As a local user of the station I think that is fine as long as there are some improvements to the pavement around the underbridge. Also, they do something to move the pigeons, it is a good few inches of leavings around the underside of the bridge beams.
Just a gentle reminder to stick to infrastructure updates in this thread please.
To discuss rolling stock provision, timetabling, staffing or any other topic, please create a new thread (or use an existing thread, if there is one), thanks :)
JModulo
17 Nov 2013
67A
Being directly affected by this pretty much every day of the week, I can say the bus service has been reliable.
On the passing in the bus, I see the wires are up till (atleast) Nitshill.
14 Mar 2021
The wire run on the Down Barrhead from Crossmyloof Gardens to Kennishead hasn't been done.
At Priesthill & Darnley station the contractors are renewing the platform surfaces. I don't know if this work was needed for gauge clearance for the EMUs or the blockade is a convenient opportunity to deliver this improvement. The pedestrian overbridge (a redundant masonry arch road bridge) is closed while they build new parapets of engineer's bricks inside the old stone parapets.
The old pedestrian footbridge has gone. The pedestrian underpass is beside the road underpass (see photo).
At Barrhead, beside the short stay car park they built a new brick column as a foundation for a mast. On the other side of the main entrance to the station, they have poured a concrete column.
nlogax
Great photos, thank you. Certainly answers my question of 'is anything visible from the e/b Barrhead ramp? '.. quite rightly the entire thing is closed!
