ryan125hst
SIMplified BI-Directional Signalling - it allows trains to run according to a more comprehensive timetable in both directions on a single line during incidents or planned works, without requiring too much faffing. All infrastructure is permanently installed, as far as I know. This is generally available on lines with limited roads in everyday and emergency use - e.g. areas where there are only two lines on a mainline which should ideally have four, where a pair of lines taken out of use would result in a complete block.
D1009 said:Simplified bi-directional signalling. No AWS (Automatic Warning System) on the wrong road therefore lower speeds than full bi-di.
Thanks.
Presumably it doesn't require all the complications of Single Line Working as discussed a few weeks ago, and is simply a case of signalling the train onto the other line? The only problems with this being the fact that there is a lot less capacity due to the fact that only one line can be used, and the lower speed limits due to a lack of AWS (and TPWS as well?)
