Indeed, for reasons explained in post #21.Also there all windows line up with seats, looks better than on the DSB one
only get afraid of talgo ride quality if its running on Iberian Gauge as I've found out and been told.can confirm ride quality on the DB ICE L is also good, nothing to be afraid of. Also there all windows line up with seats, looks better than on the DSB one
You should be able to see the planning on vagonweb.cz. What runs in reality depends on what's available, which I understand from posts on DSO relatively often isn't what's planned...hows the rollout going?
what % of services are now Talgos vs IC1 (vs IC3)
I'm just on ICE 2375 headed towards Hamburg from Niebüll. It's interesting to compare the DB Talgo ICE L with the Danish version. The Danish version has a loco at each end whereas DB runs with one loco.
That's only temporary until DSB have their Talgo driving trailers delivered. The sets will then be formed with a Vectron at one end in push/pull mode.The Danish version has a loco at each end whereas DB runs with one loco.
He also stated being on an ICE, so that will have been a DB ICE-L.@peteb said they were sitting in a driving trailer.
AFAIK DSB ordered sets without driving trailer initially and placed a seperate order for those driving trailers later.And given the articulated nature of the Talgo rakes I'm having trouble visualising how one would operate with an end coach missing.
Correct. The first eight DSB sets were ordered with no driving trailer and an end car with conventioonal couplers at both ends - the plan was to run them with a Vectron on both ends. The second order for eight sets effectively has a driving trailer at both ends. Obviously the sets will be re-formed to give an end car one end and a driving trailer at the other so that all the sets are in the same formation. Presumably DSB realised it was overkill to have two Vectrons on each set and the driving trailer order is presumably much cheaper than ordering another 16 locos from Siemens!AFAIK DSB ordered sets without driving trailer initially and placed a seperate order for those driving trailers later.
Yes, I guess that's the reasonCould this be because the driving trailers aren't certified yet?
It seems to be fairly common for push-pull sets to initially have to operate conventionally until things are sorted out.
I don’t believe that on the basis that a) they run loco both ends from Denmark to Germany now and b) there are other examples of locos changing voltage when at the rear (eg RailJets into Hungary, TRAXX between Belgium and Netherlands). Clearly the multiple working system can cope with it without issue.From what I've heard, they realised that it could be problematic running with a loco in each end to Germany. During the stop in Padborg, one loco would be under 15 kV and the other under 25 kV.
That would only be an issue for equipment with a high voltage bus between pantograph equipped equipment.From what I've heard, they realised that it could be problematic running with a loco in each end to Germany. During the stop in Padborg, one loco would be under 15 kV and the other under 25 kV.
Or maybe they solved the problem? But it was a rumour I heard and I don't know more than that.I don’t believe that on the basis that a) they run loco both ends from Denmark to Germany now and b) there are other examples of locos changing voltage when at the rear (eg RailJets into Hungary, TRAXX between Belgium and Netherlands). Clearly the multiple working system can cope with it without issue.
Denmark's own locomotive is not allowed in Denmark? Or are they using weird hire-in stuff?The Talgo for ECE 396 from Hamburg to Copenhagen today made it as far as Padborg. Some people also had stood all the way as the previous train had been cancelled.
We had to disembark using temporary steps at two doors. Initially promised busses. I would have abandoned my journey if that happened.
Eventually a two danish trains arrived, are coupled and we get on. At least on these trains everybody had a seat and the drinks machine worked.
We arrived in Copenhagen over an hour late. Two hours if you consider they added a hour two days earlier.
I overheard the DB guard tell a passenger that the issue was the locamotive was not allowed in Denmark. The passenger was not the happy as I believe he had experienced the issue before.
Nothing wrong with the Talgo but the DBS IR4? was a better train. Quieter and smoother. Standard class did not feel like a seat downgrade from first on the Talgo.
I safely arrived at Malmo so am not complaining. I just thought you might be interested.
Those DSB units with rubber gaskets (or enormously wide corridor connections) on the front are incredible trains- they look like a Class 158 (British 1990s longer distance DMU) and have seats like a Mk4 carriage- really comfortable.The Talgo for ECE 396 from Hamburg to Copenhagen today made it as far as Padborg. Some people also had stood all the way as the previous train had been cancelled.
They split on the move too - that is quite something!Those DSB units with rubber gaskets (or enormously wide corridor connections) on the front are incredible trains- they look like a Class 158 (British 1990s longer distance DMU) and have seats like a Mk4 carriage- really comfortable.
Rarely, as it requires two drivers on-board. But they can do it, and there are a few cool videos about it around the internet that I have seen!They split on the move too - that is quite something!
