WatcherZero
- Joined
- 25 Feb 2010
- Messages
- 10,272
We are talking decent acceleration until around 50mph so should be perfectly capable of most unelectrified freight chords.
At just 15mph though which is of no use to anyone outside depots
The only way to prove or disprove theories is for someone to take on a couple of UK Traxx as a benchmark.
25% more power or not, it would give an idea of how the "Extra Mile" diesel would perform.
The last mile diesel was the point I was trying to make,but hey ho,moving on.
I strongly doubt there will be the end of diesel at all until 1) diesel production stops completely or 2) Decent hydrogen fuel cell powered systems come in to replace diesels,
Let's say for instance,there are power cuts/blackouts and your whole rail system is purely electric,you're stuffed! There will be a lot of electric traction,but the way the power companies are going,I wouldn't bank on electric traction!
When was that decided? The Railway Gazette reported that the TRAXX UK would come fitted with a 180kW "last mile" diesel engine:UK TRAXX was pure AC so I am completely lost as to what point you are trying to make.
--- old post above --- --- new post below ---http://www.railwaygazette.com/news/...view/traxx-uk-aimed-at-two-uk-franchises.html
The P200 AC UK would be able to run at 200 km/h and have a maximum power rating of 5 600 kW; maximum starting tractive effort would be 300 kN. Its ‘last mile’ diesel engine meeting Stage IIIB emissions regulations would deliver 180 kW at the wheel. The locomotive would weigh 82 tonnes and be 18·6 m long, the 2 743 mm width fitting within the UK loading gauge.
Both the TRAXX UK and the Vossloh class 88 are four axle, Bo-Bo designs.Must admit you've lost me on the last mile diesel bit if the Traxx is straight electric. We need a similar powered diesel loco to compare with though I suppose the 88 is going to have more weight and more axles so would slip about less.
Thankyou Sprinterguy,obviously some of us weren't reading the technical data of the UK Traxx variant too carefully!:roll:It would be interesting to compare the Vossloh class 88's with a UK variant of Traxx and see just how much this extra mile diesel performs.
Now,as for the electricity debate ,yes and no,if the closure of power stations at the rate of knotts keeps going ahead,you can imbalance the grid causing a complete shutdown if you can't get other stations online to keep a certain Hz stability,that will affect everything that runs of the NG including traction!
I typically expect the railway press to be fairly on the ball, even if the mocked up image in my previous linked article, of a TRAXX loco dragging bogie-less mark 3 carriages along the ground(!), doesnt exactly fill me with confidence (Perhaps they are trying to demonstrate the locos superior pulling power?Of course, media are always spot on. Bombardier could offer all sorts, but the detail of what was actually being looked at appears to have been overlooked here.
Which ROSCOs offering are you referring to? The only cast iron ones which I am aware of were pure AC to replace Class 90 and Class 91. Though not the same ROSCO.
Ah, thanks for that. The Eversholt proposal to replace the 91s still reportedly included a "last mile" diesel engine in January this year, according to this article:The ROSCOs in question were Greater Anglia and Eversholt rail.![]()
30mph is more than enough to use in sidings!
Just google image UK Traxx.
No More 47s to Great Yarmouth then.... :cry:
Examples are diesel power and the pump storage scheme in North Wales (Trawsfynnedd might be its name).
Of course if the England vs France game goes into extra time some poor sole has to be watching the game to get an idea when the peak is coming - possibly a bad example as I feel sure most football supporters drink beer/lager NOT tea but I hope you get the idea.
