Driver told to move on
Teapot42
12 Jan 2022
This problem can be resolved by using electric buses.
Apart from the fact the route in question wasn't able to be part of the ZEBRA 2 application as there were no electric buses that can fit under a very low bridge. Not sure if there are even really suitable ones now - the E100EV I think will fit, but capacity not enough for the route.
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
In Scotland, McGills 3 (Neilston/Glasgow) route was recently retimed with buses now waiting several minutes in Neilston, which has improved reliability. However the stop at which they wait usually has cars parked opposite so the bus either almost blocks the road, or has to park on the pavement blocking that instead! They are however electric buses so noise is not an issue, at least.
Teapot42
12 Jan 2022
It's almost a daily occurrence with this member of the public.
Ah, is this a known problem then? (I guess you've identified the spot - Walton Back Lane on the 90/90A)
Any idea what their specific gripe is?
SCH117X
27 Nov 2015
One local council near me went mad during covid and installed cycle lanes everywhere, which are mostly ignored by cyclists, but that's another story!
Problem is cycle lanes get put in a blaze of publicity and then subject to absolute no maintenance. Typically they are full of puncture causing sharp grit if not glass. Bear in mind many cyclists will do a ride of many miles it may be the first time they have come across a cycle lane and wary of experience will avoid them.
On the subject of early running my local service will annoyingly wait time two stops before mine as it is a timing point and has a layby. It does mean the previous stop which has a layby is never waited at and two stops before that, although on road, is a two way road three lanes wide so a wait could easilly be made there, given also houses are set some distance away.
sytransport
15 Dec 2023
Sheffield
Had a bit of an odd one yesterday afternoon.
Our local service is a loop out from town, and in the middle of the loop there is a timetabled wait of typically 2 minutes, but up to 12. The timetable is also very loose as at certain times congestion can cause delays.
Yesterday, the bus got to the timing point with about 5 minutes to wait. Almost as soon as he'd stopped, someone came out from a house and pretty much ordered him to move the bus on. I think their complaint was that he was keeping the engine running - as he pointed out, it was sub-zero, so the engine was the only source of warmth in the bus!
I think to avoid an argument he moved on to the next stop and waited there, but I wonder what the 'correct' think to have done here was? In theory he left the origin and a timing point nearly 5 minutes early, which doesn't seem the right thing to do, but also is unlikely to cause and issue as this stop is seldom used.
Are drivers obliged to turn the engine off in cases like this, especially in cold weather where it's harder to restart.
There is actually wider context here, as I personally don't believe this is a good place to have a service laying over. It's a 40mph road on a bend so not the best visibility to overtake the bus. It's also a bus stop, not a stand. A few stops further on is a bus stand where the bus can get out of the flow of traffic completely, plus is on a 30mph road so less risk. It also means more of the 'unique' part of the loop is covered, so fewer passengers need to wait for the bus to lay over - especially a problem for those longer layovers.
As an aside, the longer layovers really don't make sense to me. It would seem more useful to leave town 10 minutes later, giving more connection opportunities and more margin for late running feeder services.
This isn’t by any chance the clown at Loxley is it who doesn’t like to sit in his front room and look at a bus, so decides to go through the effort of coming out to tell the driver and 9 times out of 10 gets told to jog on is it?
Teapot42
12 Jan 2022
We seem to be amassing a collection! Chesterfield, not Sheffield this one. More than likely the sort of person who buys a house next to a church then spends the rest of their life complaining about the bells. It's not as if bus stops are hard to spot, and - who knew? - buses stop there.
Arriva Fan
14 May 2018
Couldn't agree more! My Bus Stop is a timing point. Very convenient.
I think, if you don't want Buses Stopping outside your house. Don't move in next to a Bus Stop.
PeterC
29 Sep 2014
Plenty of them around.
A friend of mine runs events and even had the police turn up for a cancelled gig once. Some local nutter had complained based on the advert despite the total absence of music
Cheers Drive
5 Jan 2026
Penzance
When I was doing the X54 from Weymouth to Axminster a few years back I got to St Andrews Church Charmouth which was a timing point loaded up and had to wait 4/5 mins as thay day roads were quiet. I had the engine off as I would waiting time anywhere.
A tractor started beeping me and shouting from across the road and I waved & pointed at my watch. He kept beeping then stormed across the road shouting. I am calm anyway but I knew what was coming. I explained to him I had to wait a few minutes and that the company not only are strict on this as I had already been told but that the company can be fined £10k for leaving early and I could see people coming down the road for the bus. He told me I had to move as I was blocking him from exiting his lane on the opposite side of the road I could not move forward as there isnt room if you look on street maps you’ll see cars parked directly in front of stop and I can’t leave the stop because I could get a disciplinary warning which first have done to driver and councils do watch the timing points especially in village like this. He was swearing calling me a jobsworth and so many other things. I stayed calm but inside it gets you anxious and on edge because you also have a bus full of people looking and the people in the street. But I won’t back down I left 58 seconds earlier to be a bit helpful but still the amount of disrespect people give bus drivers when we are doing what we are told to do and there are consequences is awful. The only time I would move is if I was blocking someone in or it was an emergency vehicle needed the space.
Even if you leave the last timing point on time you can still end up early for the next it all depends on how busy it is and how the route is timed some sections are tight and others are ridiculous you end up crawling along at 20 trying to waste time so you don’t end up waiting at every single timing point. But as a bus enthusiast it does give me time to get some good shots. Patience is the key to being a good PCV driver.
Teapot42
12 Jan 2022
Yes. Regulation 98 of the Road Vehicles (Construction and Use) Regulations 1986 applies.
See https://www.legislation.gov.uk/uksi/1986/1078/regulation/98
Would paragraph 2b not apply here, namely where the machinery is required to be worked for a purpose other than driving the vehicle.
You could argue that heating is required which needs the engine to be running. (On this model and in the weather conditions prevalent on the day)
