Double Slips
Lucan
21 Feb 2018
Wales
Are double slips ever used in new trackwork? At one time they were widely used at the throats of goods yards as the start of the fan of sidings, simultaneously providing the entry to the headshunt in the opposite direction. They save space compared wiith sequential points.
Sorry, can't answer specifically, but any form of complex pointwork is only used if there is no alternative. Maintenance is more costly and specialist parts are required if something needs replacing.
For example, the new layout at Kings Cross has eliminated slips.
Gostav
14 May 2016
And double slips usually have a sharp curve which severely limited the passing speed.
Western 52
19 Jun 2020
Burry Port
Not sure about new layouts, but to the west of Cardiff Central there are about 5 double slips and a similar number of single slips. Given the number of running lines there and the need for flexible routing, maybe they were the only solution. Perhaps they would have to be renewed as they are at some point?
Cardiff was re-signalled and re-modelled a couple of years ago, and I think this included the west end. If that's right then there would have been no alternative to the double slips in this area.
Wilts Wanderer
21 Nov 2016
I don’t think the West end was touched.
Taunton
1 Aug 2013
Funny that continental European railways seem to manage these without issue, on mainstream running lines; Switzerland and Germany in particular. There must be dozens on the approach to Frankfurt Hbf.
30907
They are classic for 1950-60s layouts (Frankfurt and Zurich as examples) but I have noticed that new layouts avoid them and go for plain S&C - Erfurt has none, Wien Hbf a handful, for example.
Taunton
1 Aug 2013
One of the upsides of the Euro-style long diagonal crossing tracks, with a double slip at each line crossed, apart from its total flexibility, is a train being switched only makes one turn in each direction. With sequential single crossovers there is a string of left-right-left-right, which must be more wearing on the rolling stock, and sideways thrusts on the track. Noticeable, for example, on the Down Main approaching Didcot, turning to the Oxford avoiding line, a series of lunges and lurches, and squeals from the gangways, as each single turnout in succession is taken - seven required, I think.
Annetts key
13 Feb 2021
West is best
On late BR / Railtrack/ Network Rail infrastructure, now only installed where it’s too tight (space wise) for alternative layouts.
The bulk handling terminal at Avonmouth, Bristol has some. These were installed in 1992.
WAO
10 Mar 2019
....but the speed through the Didcot East ladder is (actually) 70mph, like Hanslope on the WCML.
Better a gentle lurch surely, than an approach controlled 20mph?
WAO
Senex
1 Apr 2014
York
What do we call in this country crossings with double slips where the point-ends are outside the trapezium (?) of the crossing, as in the accompanying picture (courtesy of Wikipedia)? They're "doppelte Kreuzungsweichen mit außenliegenden Aungen" in German, and not uncommon, although recognised as particularly (and perhaps undesirably?) complicated. Their advantage seems to be that they allow higher speeds — as far as I've noted, 60 km/h rather than the 40 km/h or lower of traditional slips.
snowball
4 Mar 2013
I have no idea what the answer to your question is, but I'd call the "trapezium (?)" a rhombus - four sides, all equal in length, and each parallel to the opposite one.
Railsigns
15 Feb 2010
A "semi-outside double slip".
Graham H
16 Apr 2018
Arent those called Outside Double Slips ? Serves the same purpose but higher speed and with more complicated frog setup. A more extreme example Posted before I saw "Railsigns" reply1645977384849.png
If I recall correctly there's an outside double slip underground at Heathrow T123 (National Rail not Piccadilly Line).
Along with another frowned-upon piece of ironmongery, the scissors crossover, they are more likely to be found underground because the extra complexity of track might simplify the tunneling.
AlbertBeale
16 Jun 2019
There's a scissors crossover on the Bakerloo Line, north of Lambeth North (just north of where the ramp down from the London Road sidings joins the northbound track). I have a feeling they're not that uncommon on the Underground?
I note the subtlety of the German one pictured (a type I've seen elsewhere on the continent) - although it might be an outside slip not an inside, and the two slips don't overlap, they do meet in the middle, with the same stretch of line being briefly the left-hand line of one slip and the right-hand line of the other.
Tester
5 Jul 2020
Watford
If you look closely you will see that they are two separate rails, albeit machined to fit together. A remarkable piece of geometry regardless!
Very common in Germany - almost unheard of here!
D6975
26 Nov 2009
Bristol
That's called a Baesler double slip.
O L Leigh
20 Jan 2006
In the cab with the paper
It was in terms of resignalling, but the track layout was left largely unchanged. I don't think there would have been any way to have fitted the necessary pointwork to have allowed access to the "Brickyard siding" from the Down platforms as well as preserve access to Canton depot in order to get rid of the slips.
Lucan
21 Feb 2018
Wales
A double slip is much shorter overall than having two points back to back for the same function. So when you need to dig tunnels to accommodate them, or have other space constraints, the double slip has its advantages. Here is my crayon diagram of a double slip used at the throat of a pair of bay platforms, allowing direct access to a stabling siding for both. Speed is not an issue, and it saves space. If you substitute (or add) goods sidings this was the typical layout of a country station with a small goods yard in steam days; the "stabling" siding would have been the headshunt, and the through lines would have had a second crossover at the far end of the station to provide the loco run-round.
Tumbleweed
17 Apr 2013
There used to be a Double Slip at the Cwm Colliery sidings in Beddau, as a train-mad child at the time I'll never forget this BR brake van crossed it when the rails were in a 'closed' position to the oncoming tram, as it was a manual set up the tram just forced it open with little effort!
Western 52
19 Jun 2020
Burry Port
Cwm Colliery and coke works also had an extensive narrow gauge system. That prompts me to ask if double slips have been used for narrow gauge anywhere? I don't remember seeing one.
Taunton
1 Aug 2013
Surely would be all one word "Doppeltekreuzungsweichenmitaußenliegendenaungen"
mit milch :)
Western Sunset
23 Dec 2014
Wimborne, Dorset
A new scissors crossover and a three-way point were laid over the past couple of years at the entrance to Southampton Maritime Container Terminal, when the sidings were extended.
EAD
14 Nov 2014
Worth noting that in the German speaking world, a doppelte Kreuzungsweiche is usually shortened to DKW while a single slip is a einfache Kreuzungsweiche (EKW). The ones referenced up thread are commonly known as a Bäseler DKW after the inventor, Wolfgang Bäseler as well as DKW mit außenliegenden Zungen.
Senex
1 Apr 2014
York
Or even more simply as DKW-500-1:9 (or EKW as the case may be), with the 500 giving the radius and the 1:9 the crossing-angle. They were introduced in 1935 as one of the DR standard designs. "Normal" slips were of a 190-metre radius.
EAD
14 Nov 2014
Yes exactly Senex - as someone who has grown up in part with German railways I have always liked the technical clarity they use. I would expect at an engineering level that is universal on the railway given the need for clearly defined geometry, though not as common in the enthusiast community as it is in Germany in my experience.
