Double heading of Flask trains
paul40122
3 Aug 2015
Can anyone enlighten me as to why Nuclear Flask traffic always has double headed locos on it, as one loco should have enough umph for one or two wagons?
I can only assume it might be for security reasons (train is not stationary for long)
Thanks
Crossover
4 Jun 2009
I've always understood it to be for redundancy - as you say, the powers that be tend to get (understandably) a little nervous of them being a sitting duck for too long!
pompeyfan
24 Jan 2012
In that situation how would that work? Do you fire up the second loco and drive it from the controls of the first loco? Or does it have to be run round?
Peter66
2 Aug 2015
Cardiff
A spare loco may not be readily available or some distance from the failed train, so it makes sense to have a redundant loco attached to enable self rescue in case of failure.
10 Mar 2015
Depends if through wired or not. Speaking to one of the DRS guys who do the sizewell flasks the other week it's basically there to be thrashed in any direction should and "undesirables" decide they'd like a ride.
sprinterguy
4 Mar 2010
Macclesfield
As far as I know, both locos provide traction on the nuclear flask trains so it wouldn’t be necessary to fire the second loco up as it would already be running.
DRS locomotives are fitted with the company’s own multiple working system, except for their class 66s and 68s which are fitted with the AAR system that is standard on these classes, so it should be entirely possible for the second loco to be driven from the first, should the leading loco fail.
Bertie the bus
15 Aug 2014
... it's basically there to be thrashed in any direction should and "undesirables" decide they'd like a ride.
I'm not entirely sure what that even means but it certainly isn't true for many reasons.
Not always. There can be any combination of locos, some which can't multi.
father_jack
26 Jan 2010
Saw a pair with the leader failed at Bristol Temple Meads a while back, both hooked off, ran off via North Somerset junction, the Rhubarb curve and Dr Days junction, back on the move in 10 minutes.
156441
30 Aug 2011
Manchester
Nuke trains always have a second man (Guard) on the rear loco. The rear loco will be left ticking over in the event of them being 'non-compatable' for a quick change over if necessary. (As happened last month at Bristol to bury a fault.)
They are usually diagrammed to be comparable locos though.
Father Jack beating me to it with the Bristol example there!!
Bertie the bus
15 Aug 2014
They're not always left ticking over. In fact there aren't always 2 loco's; normally there are, yes, but not always.
Bertie the bus
15 Aug 2014
57/20 and 57/37 combinations on the flasks are becoming more common. There are also 66/37 combinations occasionally, though 66s on the flasks are becoming rarer. Although single loco's are rare, they do happen from time to time. I took this photo earlier this year.
Where they perhaps empty flasks?
Bertie the bus
15 Aug 2014
I didn't take a look inside to check but it was the daily Crewe - Sellafield service.
And your basis for that statement is what exactly? I'm talking about anyone who might fancy some nuclear detrious......still not getting it? :roll:
Nope. Still haven't a clue. It's the 'thrashed in any direction' which is baffling. If the DRS driver was suggesting to you that it would be like an episode of a 1970s US cop show with the undesirables clinging on whilst the train goes round corners at unfeasible speeds, don't you think he might have been pulling your leg?
headshot119
31 Dec 2010
Dubai
Because no driver in there right mind is going to throw it into refresh and "thrash it".
What's the basis for your statement, other than platform end wibble :roll:
SpacePhoenix
18 Mar 2014
Don't all trains with dangerous goods onboard have to have barrier wagons at both ends?
10 Mar 2015
"Thrashed in any direction" was (I thought) quite clearly a way of expressing maintaining the ability to get out of situations quickly. Of course limited by signalling and the rule book, but thought that would be evident.....
RichJF
2 Nov 2012
South London
Didn't 31's used to work the flasks on their own with barriers & a guards van back in the day?
221129
21 Mar 2011
Sunny Scotland
The Regular flask trains don't run with Barrier vehicles (and the waste they carry isn't particularly dangerous) however the MOD Flasks do.
TheEdge
29 Nov 2012
Norwich
I do wonder why the MOD flasks get barriers and guards and the civil ones don't. They both carry spent fuel so both are equally leathal in the wrong hands so why are civil ones "safer" and don't need a guard?
221129
21 Mar 2011
Sunny Scotland
I believe the MOD ones carry a higher level of material.
Most civilian nuclear waste isn't really that dangerous and would only have local effects if released. US studies into the effects of a dirty bomb using civilian grade fuel indicated that a few city blocks would be affected and that cleanup would take several months to a couple of years.
Military 'research' reactors on the other hand burn much 'hotter' and produce more highly-active and longer-lived products. This is as a result of them being used to breed plutonium, etc. Hence any dirty bomb would be much more destuctive.
TheEdge
29 Nov 2012
Norwich
Without going too far off topic these are carry the spend fuel from the subs at Devonport and Rosyth. Are they actually used to breed plutonium? Always thought that was for, as you say, "research" reactors like Dounreay.
hwl
5 Feb 2012
Civilian reactors use fuel rods that are circa 3-5% U235 when new, submarine reactors use fuel rods that are circa 24% U235 which is much closer to weapons grade and far easier to refine into weapons grade so is potentially a much bigger "target" for those who are so inclined.
