disused level crossing
DavidBrown
29 Mar 2011
North Devon
I think that silk mills level crossing is still there, on the Great Western main line near Taunton. Gates never opened to road traffic which now passes over a new bridge.
I think that it was/is? used for access by road/rail machines during engineering work.
Apart from a tiny bit of tarmac, there's nothing left of the original crossing - lights, barriers, road surface - all gone. As you say, however, it is now used as an access point by Network Rail.
broadgage
11 Aug 2012
Somerset
I stand corrected.
It was still there when I lasted visited, but that must have been longer ago than I realised.
IanD
18 Sep 2011
Newport Pagnell
Nice to see some more quality driving from Google in that sequence. Follow the coach a little further up the road and we're quite blatantly overtaking him against a double solid white line :roll:
I'd guess the 2 vehicles were travelling in opposite directions.
michael769
9 Oct 2005
Follow it far enough and you can see the Google car stays on the "wrong" side of the road all the way along - so yes the camera is pointing "backwards" in that shot.
A0
19 Jan 2008
I don't think anyone's mentioned it, but there are a couple in Ipswich on the old line to the docks - one at Bridge Street (A137), another on Ranelagh Road.
John Webb
5 Jun 2010
St Albans
They were both mentioned several pages back. The Bridge Street one was visible on Goole Street view, but has been entirely removed since the Streetview pictures were taken, so I have been informed.
richw
10 Jun 2010
Liskeard
20 Mar 2012
I found one on a branch off the east coast mainline north of morpeth, can't tell if its still in use the crossing or the line.
It may not be disused but there's a crossing right next to morpeth station showing a rail missing but a class 142 stabled in the distance.
John Webb
5 Jun 2010
St Albans
If it's the crossing on Coopie's Lane, then the 'rail missing' is an effect of the Streetview photo joining when you are on the crossing. Other viewpoints show the rails to be intact.
According to Baker's 2010 Atlas these sidings and connections are still in use. They are part of a network of freight lines connected to terminals at Blyth and other industrial plants around that part of Northumberland.
bailey65
11 Dec 2011
Does the infrastructure of these disused crossings often get left where it is because it is cheaper than sending out a team of engineers to dismantle it all ?.
John Webb
5 Jun 2010
St Albans
In a word "Yes." This is particularly true where tracks abut a still used line and removing signals etc will require the interlocking to be altered and completely retested before trains can move again on the still used line.
14 Aug 2012
Stratford
Yes I believe so, however it depends where the crossing is, for example the one over the A47 at Wisbech has been removed due to how busy the road is and the fact that NR are still liable for its maintenance, so therefore its cheaper to lift the crossing, but if you go down the back roads in the same area you cross the same railway route but the crossing is still intact
With regards to the infrastructure on the rest of the route I believe NR have to wait several years before they can lift the track,
