Disruption at Werrington Junction [15/11/24]
Banham7
12 Aug 2020
Lincolnshire
It hasn't been a great few days for the East Coast with lots of major disruption, and this incident seems to be pretty major too and causing quite a few delays and cancellations.
Due to a fault with the signalling system between Peterborough and Grantham trains have to run at reduced speed on all lines.
Impact
Train services running through these stations may be cancelled or delayed by up to 60 minutes. Disruption is expected until the end of the day.
Further Information
An update will follow within the next 1 hour.
Delays Explained - Fault with the Signalling System https://www.networkrail.co.uk/runni.../delays-explained/signals-and-points-failure/
You can use your ticket on the following train companies at no extra cost:
TransPennine Express Leeds and York/Newcastle. Northern Trains from Leeds, Doncaster & York CrossCountry between Sheffield to Doncaster/Leeds, York and Newcastle/Edinburgh. East Midlands London St Pancras to Sheffield Great Northern and Thameslink between London Kings Cross, Stevenage and Peterborough.
Please see the alternative route map for more details:
Please be aware that other operators services are also likely to be busy.
Were working with Network Rail to get our services moving again as quickly as possible. We are sorry for any inconvenience caused.
https://www.lner.co.uk/travel-infor...isruption-id=8536D52383E543EFA7EE19EDCED22C60
londonmidland
22 Dec 2009
Leicester
A temporary block on departures at Kings Cross due to overcrowding at the station.
Tweet to this here
Picture shows a 'tweet' from LNER, advising services are to be held at London Kings Cross due to overcrowding issues.
800001
24 Oct 2015
If no-one is allowed to board a train, doesn't that make the overcrowding worse?
I think it stops more people entering the station, and joining the crowds kn the concourse.
It allows the station team to deal with the people already there.
takethegame
20 Feb 2024
Lincolnshire
More problems between Grantham and Peterborough this morning (amongst other disruptions) with the Up Fast out of action and everything southbound currently switching to the Up Slow at Stoke Junction. I didn't realise trains could cross back to the fast at Werrington though? I thought that crossover was only for northbound trains as part of the crossover from Down Main to GE/GN lines via Spalding?
800001
24 Oct 2015
Broken rail on the Up Fast,
Tomnick
10 Jun 2005
No, there's a signalled move over the crossover from Up Slow to Up Fast. Gets used reasonably often for regulating purposes.
takethegame
20 Feb 2024
Lincolnshire
Power supply problems at Newark as well as IS05 (0700 Kings Cross to Edinburgh) seems to have been stuck with several trains stuck behind, all mostly 801s so no diesel alternative
800001
24 Oct 2015
Well, depending on the nature of the ‘supply problem’ and the length of area it affects, then they can start there GU engine and move through the area at reduced speed until clear of the problem area.
Twingo37175
24 Mar 2019
I think the issue is North of Retford (looking also at the LNER website). 1D01 has terminated and gone back South with the LUMO 1S91 being front of the queue when the juice comes back, 50p in the meter anyone.
800001
24 Oct 2015
1S91 and 1S04 have just departed Retford
800Travel
3 Nov 2023
It has disappeared from TPE JourneyCheck now, but it said:
Update 09:20 Due to the power supply issues 1D01 5:55 London Kings Cross to Leeds had to switched over to the GU's. This has caused faults on the train. It then had to return back to Retford and terminate. Currently the Down Line is Blocked The SDT is currently working out a plan to get services moving LUMO ticket acceptance has been agreed
