Different Driver Depot, Route and Traction cards
LooperTrack21
27 Nov 2024
Southern
Hello, currently a trainee driver for SWR. Looking for some advice on where I can get some route maps put together in a separate and orderly way. I don’t have the time or facilities at home to print my own, and separate them all for each of the routes I’ll be driving. Any advice or suggestions are appreciated.
Grvrdvicdr
26 Oct 2021
You should be provided with any necessary materials. A forum probably can’t help with up to date materials. Speak to your line manager or trainer/ instructor
Val3ntine
29 Apr 2015
You will be granted access to Track Access which will have all of that.
Detor
2 Oct 2024
Worth asking someone at your Depot, they may be willing to print some for you, or they already have them ready.
class ep-09
5 Sep 2013
Worcester GWR drivers are learning Bristol Parkway to Bristol Temple Meads via Filton Abbey Wood.
Work starts in December TT.
craigybagel
25 Oct 2012
It's been a few months so I've gone through it this evening and made some updates. Some of this is based on logic and the passage of time, and some from details helpfully passed on to me from others, so as always please let me know if I've made any mistakes - and thank you to all who help keep this list going.
The changes I've made are as follows:
Chiltern - added MKV DT training to Stourbridge and Marylebone depots.
Great Northern - changed 379 from training to in service for all depots that I understand will sign them (Cambridge, Hitchin, Hornsey (link dependant), Kings Cross, Kings Lynn and Peterborough)
GWR - added Bristol to Exeter for Paddington GWR (thank you @800301 ) . Added Bristol Parkway to Bristol TM for Worcester GWR (thank you @class ep-09 )
Northern - changed 323 from training to in service for Buxton. Changed 333 from training to in service for Doncaster
Scotrail - added in details for new depot at Millerhill
Thameslink - changed "soon to learn" to currently signing St Pancras - Welwyn Garden City for Ashford
Transport for Wales - added 756 to "training to start soon" for Cardiff Mainline, changed "route learning soon" to currently signing Central Rivers TMD for Crewe, deleted Tyseley TMD for Shrewsbury
West Midlands Trains - added 730 to Coventry
Stigy
6 Nov 2009
One to amend: SWR London Waterloo to Guildford via Cobham for Fratton drivers is no longer link dependent.
stadler
5 Jun 2023
Horsley
This recent document i obtained may be of use to provide some other updates for SWR drivers.
On the traction tab the top is drivers and the middle is commercial guards and the bottom is metro guards.
On the route tab anything with the two digit depot code and no other letter means that all drivers and guards based there sign it. Anything with "D" after it means only drivers sign it. Anything with "C" after it means only commercial guards sign it. Anything with "G" after it means only metro guards sign it.
Anything in green means all sign it. Anything in orange means most but not all sign it. Anything in red means only a small amount sign it. Although note that the 701 will soon turn from red to orange to green for most depots if not already.
  • SWR Drivers Guards.xlsx
craigybagel
25 Oct 2012
Anything in green means all sign it. Anything in orange means most but not all sign it. Anything in red means either only a small amount sign it. Although note that the 701 will soon turn from red to orange to green for most depots if not already.
Thanks very much for this, I'll have to sit down and go through it properly at some stage and check everything is still up to date on the list here.
newtownmgr
2 Jan 2011
Birmingham Camp Hill line services are due to start in March 2026. The work will be shared between Worcester & Birmingham New St.
Training is due to start next month for New St depot, once the New St Instructors have been trained on the route by Worcester instructors. That’s due to take place early December once some final testing has took place.
Services will hopefully start late March 2026
youngiecj
26 Feb 2012
Slight update, from the December Timetable change, Boston Drivers will be working one extended service to Cleethorpes a day meaning they now sign Cleethorpes.
8 Feb 2021
Manchester
Update from December for TPE
York now goes to three links
Starter Link
185 only
Redcar Central - York
York - Manchester Vic via Leeds, Dewsbury, Huddersfield
York - Manchester Picc via Castleford, Wakefield, Guide Bridge
185 (Main) Link
above plus
Redcar - Saltburn
Manchester Vic - Manchester Airport via Ordsall Chord & Salford Crescent
Mirfield - Manchester Vic via Calder Valley
Leeds - Altofts and Whitwood Jns via Methley Jn
York - Scarborough
Northallerton - Darlington
Manchester Oxford Road - Manchester Vic via Salford Crescent
802 Link
185s and 802s
Newcastle - York via KEB + HLB
York - Manchester Victoria via Leeds, Dewsbury, Huddersfield
Manchester Victoria - Manchester Airport via Ordsall Chord & Salford Crescent
Manchester Victoria - Liverpool via Chat Moss
York - Scarborough
York - Mirfield via Castleford, Wakefield Kirkgate
York - Doncaster Carr via ECML
Hull only sign to Doncaster from Leeds via Wakefield Westgate, not from York
PudseyBearHST
28 Sep 2015
South West
That is excellent, thanks for sharing. Really interesting to see number of crew at each depot too, some are different to what I expected.
craigybagel
25 Oct 2012
Thanks both, will add to the list of changes to make next time I get chance to update.
RiverDon
11 Mar 2024
If you are doing changes then it might be worth mentioning Scotrail Aberdeen depot now only do Inverkeithing to Cowdenbeath and back rather than the full Fife circle route.
craigybagel
25 Oct 2012
Starter Link
185 only
185 (Main) Link
above plus
Redcar - Saltburn
York - Scarborough
802 Link
185s and 802s
York - Scarborough
Exeter has lost all Cornwall work to Penzance and work beyond Bristol to Cardiff. Still have the rest I believe.
Thanks to all of the above, all changes have been added (plus some additional changes at GWR brought to my attention privately)
Thanks, have added this in as well. It did surprise me somewhat as I'd always assumed Aberdeen's knowledge of the Fife Circle was diversionary rather than them working regular services over it but obviously that wasn't the case.
Incidentally, do you or anybody else know if Tweedbank still sign the Fife Circle? I was led to believe they did when the depot first opened, but I didn't hear anything about them signing Leven (which I assume is also the stumbling block towards Aberdeen retaining it's Fife Circle work?) when that opened.
RiverDon
11 Mar 2024
I think Aberdeen used to have full Fife circle jobs before I started but now there is only a couple of Cowdenbeaths. I don't know what Tweedbank cover but I am 99.9% certain the only depots that sign the Leven line are Leven, Edinburgh and Perth.
baz962
8 Jun 2017
Probably could add 810 traction to the EMR list now. Signed by a handful of drivers at St Pancras , Kettering and Derby.
craigybagel
25 Oct 2012
Thanks
Good point, will put it in now.
Mattplans
27 Sep 2024
London, UK
Does anyone know if TL drivers sign Blackheath tunnel? I thought they didn’t but a service went through there today on diversion
Galvanize
8 Jun 2005
South East london
Yes, Luton and Gillingham Drivers sign it.
321362
31 Oct 2023
A bit pedantic but the Overground in post #1 hasn't been updated to include Barking Riverside
