Devon problems
richw
10 Jun 2010
Liskeard
This has been a recurring issue for almost 2 weeks now. Trains are getting stuck on the bank between Totnes and Newton Abbot.
Captain Chaos
31 Jan 2011
Worst affected seems to be the 16:06 Paddington to Penzance at the moment. Poor Rail Conditions through Dainton Tunnel in both directions appears to be the cause.
Goatboy
23 Jun 2011
This looks like a different issue as the huge delays are being picked up around Teignmouth.
Captain Chaos
31 Jan 2011
That's what has been messaged out. Says they are having problems at Dainton Tunnel between Newton Abbot and Totnes. Service is being run back to Teignmouth for another run up. Might be why it's showing the delay to be there?
Pacerpilot
7 Jun 2010
Network Rail are not laying sandite this year, just jetting. And this the the result.
455driver
10 May 2010
The problems were getting up Dainton bank, they were not getting to the tunnel.
Hemerdon bank has been an issue as well.
brillopad
5 Feb 2011
And so it goes on...
14:06 London Paddington to Penzance due 19:33 This train has been delayed at Bodmin Parkway and is now 31 minutes late.
This is due to poor rail conditions earlier. Message Received :06/12/2013 18:43
KA4C
7 Mar 2012
16.06 Padd to PZ got stuck on Dainton bank due to getting stopped on the bank behind a late running XC service, it eventually went bang road to Newton Abbot and then on to Teignmouth in order to get a run at the bank without a stop at NA. In the meantime, however another XC service was sent from a standing start at NA up the bank and got stuck although it did manage to get to the tunnel eventually. The delays shown at Teignmouth were due to both the 16.06 ex Padd and 17.03 ex Padd both waiting at the station at the same time waiting for the down line over the bank to become clear. the 16.06 eventually making it to PZ somewhat late
Woody
10 Dec 2006
I was on the 1506 ex Paddington from Exeter to Plymouth which when it arrived at Exeter was already 30 minutes because of "poor rail conditions" according to the train manager. However 30 minutes delay became 50 minutes delay by Plymouth as we barely made it up Rattery bank after stopping at Totnes and 50 minutes became 77 minutes in Cornwall by the time the train reached Penzance.
KA4C
7 Mar 2012
Yeah, I was on the 16.06 :(
Whistler40145
30 Apr 2010
Lancashire
Has someone at Network Rail got a screw loose?
Why the heck would they remove the requirement to apply Sandite on the South Devon Banks, especially when trains are struggling?
Sent from my iPad using Tapatalk HD
I've no doubt that questions will be asked come Monday when the delay minute figures are totted up.
scotraildriver
15 Jun 2009
Not sure of the areas down there but here is Scotland Network rail are actually increasing sandite using automatic applicators which apply sandite as the train passes over. They are on the approaches to problem stations and gradients and they do work very well. (Except in good weather when you slide on the sandite instead!)
TEW
16 May 2008
The train I was on this evening lost 40 minutes between Totnes and Plymouth, eventually arriving nearly 60 late.
Goatboy
23 Jun 2011
Were you on the Paddington to Penzance service? I was stuck behind that at Totnes on an XC Voyager yesterday. We were told the train in front had 'failed' but given the area it had 'failed' in I wondered if it was more adhesion issues.
455driver
10 May 2010
If your train was 1V46 0750 Glasgow to Plymouth (due Totnes 1716) then I was on that train as well. ;)
Do you know what unit was it, I didnt make a note, cheers.
TEW
16 May 2008
Yes I was. We certainly didn't fail. We kept moving the whole way up the bank, but it was at a crawling speed.
starrymarkb
4 Aug 2009
Exeter
I was on the XC HST going the other way around that time ;) (1724 from Plymouth) - we didn't get caught too badly but still lost 10 mins by Exeter (meaning I just missed the train up the hill to Central, the next was very delayed so had to walk home from St Davids!)
Going down on the 1145 from EXD earlier in the day I noticed that an HST going up from Totnes towards Newton Abbot was passed much slower then normal!
Parham Wood
13 Jun 2011
OK can someone please advise why, when it is known that the bank is slippery, that rail treatment cannot be applied to the rails or is there no technical answer that works? This problem has been going on for several days, enough time to get a treatment train out at intervals. Sounds as though NR managers have their heads in sand rather than the sand being on the ralis:D
If there is a problem, fix it and keep it fixed!
455driver
10 May 2010
Thats because the MOM (Mobile Operations manager) was hand sanding the rails in front of the HST, you cant expect them to run! ;)
Who/what is going to apply the 'treatment' and when?
Your post smacks of knowing very little about how things are on the railway!
You could say the same about roads in snow, "why isnt frost prevention sprayed on all motorways/ main A roads when snow is forcast", can you see any problems with that?
DarloRich
Fenny Stratford
whilst i am sure you know best perhaps you could present some options as to how, when and where this treatment shall be applied taking into account all of the restrictions on locomotive and driver availability, route knowledge, operable staff hours, the time taken to replenish treatment trains and the location & availability of replenishment facilities.
In any event - what is causing the issue with rail head adhesion?
VP185
13 Feb 2010
You've got TGAs, MPVs, Road/Rail vehicles or even a member of p/way staff who could manually apply sandite to the railhead.
These issues have been ongoing for a considerable length of time. It must be costing NR a fortune in delay minutes and damage to the railheads as well as costing the TOC for damaged wheelsets
DarloRich
Fenny Stratford
yes but the point is what is causing the problem?
VP185
13 Feb 2010
It is leaves. You can see there is contamination on the railheads.
Network Rail has a 'plan' which says leaf fall season has finished and so have stopped jetting the railheads, the reality is very different.
43094
19 May 2010
14/12 - 0750 GLC - PLY (due Totnes 1716) is 1V56 (not 1V46) and was 221125 if that helps.
For completeness, 1V46 (0617 YRK - PLY) was 220027 on this date.
