Derailment near Watford Junction (16 September 2016)
IanD
18 Sep 2011
Newport Pagnell
More crass reporting of the incident (eg the Mail).
Apparently it was a "slow tunnel", and it was on "the busiest rail line in Europe".
They seem to be mashing up railway parlance with Wiki entries on the WCML.
"the busiest rail line in Europe" was a phrase used by the Network Rail spokesman on the radio. He went on to add "that carries both passengers and freight" but in essence the Mail were simply repeating what Network Rail told them.
And what is wrong with the phrase "slow tunnel"? It's no different to saying "slow lines" - neither the tunnel nor the lines actually move. Maybe it's not strict railway parlance but the Mail is not a journal aimed at rail staff or enthusiasts so what does it matter?
Taunton
1 Aug 2013
Retorus
30 Mar 2012
It's only the pedantic people on here who get upset. And there are a lot of them.
D365
29 Jun 2012
By the Mail's own standards, their reporting could have been a lot worse.
sd0733
7 Nov 2012
264 has now been rerailed and will go to watford yard where it will be fitted with skates to get it presumably to Northampton.
The other unit with 264 was 117 I've read somewhere.
Heartland
26 Mar 2016
Stechford, Birmingham
Infrastructure failures like that at Watford by the tunnel are a serious matter of concern. Imagine a situation where a train passes at speed and a similar event occurs. Whatever people feel about HS2, a new route north from London for fast trains is something that deserves support and not continual erosion to preserve ancient woodland, hedgehogs, newts, rich peoples private acreage or the diverse views of eco-warriors.
33056
12 Nov 2007
On a train somewhere in Europe
350 264 is now in Watford Yard. Would have thought that they might try to park it somewhere a little less conspicuous.....
toppington
19 Mar 2016
There are certainly a lot of people eyeballing 264! 117 is currently sat a little further south. Both are very dusty.
9 Feb 2009
Whar difference does HS2 make? It could just as easily have been the fast line tunnel with one of LM's express services that was derailed of which there are meant to be more post HS2. Then there are the several hundred other tunnels across the network...
Class 170101
1 Mar 2014
The real question is will Southern be running... I suspect not but they have not said anything one way or another, perhaps they forgot they run on the West Coast Main Line now!
Terminating at Shepherd's Bush. Through passengers should travel via Victoria and Euston (LUL).
A0
19 Jan 2008
Why is where it's parked an issue? It wasn't a fatal accident and there were no serious injuries. So apart from a few enthusiasts most people aren't going to be bothered.
talltim
17 Jan 2010
The pictures on BBC News show a Virgin train. Is this the rescue train that they are talking about and, if so, how to they 'transfer' passengers from one train to the other?
A Virgin Voyager is about the only train* on the network suitable for this kind of work, diesel powered and fitted with a steering wheel to go round the landslip debris....<D
*I assume the VTEC HSTs are being retro-fitted but they aren't as close to the scene
I that 33056's comment was from a brand image point of view. It's not uncommon for airlines to hide/remove the titles from airplanes that have been involved in even minor accidents where the craft can't be moved immediately.
QueensCurve
22 Dec 2014
Oh I see,you mean the press...I understand your thinking....:)
Steve Eusden (a pseudonym???) tweeted a picture of another derailment.
Steven Euesden on Twitter: "Train leaves tracks at Watford Junction due to torrential rain https://t.co/bzhFAATwSk #News https://t.co/xEd0Rrc8e1"
It is the continual erosion of the WCML by rainwater that worries me.:D
sng7
22 Oct 2013
Edinburgh
The picture you linked on twitter is from the derailment of an ECS working at Welwyn Garden City on the 13th so nothing to do with Watford Junction or rain.
transmanche
27 Feb 2011
I think that was rather the point...
FWIW I was out on the WCML today (which was nice and quiet - LM were still posting "avoid, avoid, avoid" though a reasonably punctual 2-line emergency timetable was in operation) and was surprised to note that all the delays/cancellations on the PIS had a note "due to a derailment" on them - I wasn't expecting it to be that up-front, I was expecting an "operating incident" or similar.
I'm not unduly clear what HS2 has to do with WCML slow-line stopping services. The embankment on the fasts is nowhere near as steep.
The lead coach is going to need a lot of work but at least looks repairable!
Agreed, that will get fixed.
And then there's the curious TfL bus thing, where they obsessively blank the destination blinds of any bus involved in a collision, even though it is obvious to just about anyone who cared to look that it most certainly isn't going to the place on the blind any time soon.
transmanche
27 Feb 2011
Isn't that the 21st century version of leaning a seat cushion up against the rear of a bus? :)
33056
12 Nov 2007
Not just from a brand image p.o.v. - it might un-nerve passengers who notice it, which was why rolling stock involved in past accidents was usually sheeted over when it couldn't be moved immediately from view. The unit could have been put down the further reaches of the yard away from the station though I realise that might have caused a problem if it came out under its own power or coupled to the other unit as there is no OHL down that end.
Alternatively it could have been sent up and hidden somewhere in Wembley though that would have caused issues moving that far on a damaged wheelset / on a skate; a case of being between a rock and a hard place!
Ianno87
3 May 2015
Slow Lines blocked => Stopping services diverted to Fast Lines (between Wembley North and Bourne End) => Disruption to/thinning out of Fast Line services
HS2 will have properly designed earthworks and geotechnics from the start, so in future the long distance London-Birmingham/Manchester markets will not be affected by such incidents*
*Except where HS2 trains will operate on the exiting network, of course!
itfcfan
7 May 2011
I'm booked on the 18:08 Euston to Chester this evening and I'm struggling to find out if it's still running or if I'll need to swap to a different service and change at Crewe, etc.
On realtimetrains I can see no trains direct from Euston to Chester until 15:08. The 18:08 is shown as due to run. But maybe the xx:08 trains are being removed from the system gradually as the time gets close to each departure?
Has anyone here got the latest news or any first-hand experience of Euston today.
sd0733
7 Nov 2012
Looks to be running that one, it looks like its formed from the 16:44 arrival from Holyhead which is on its way to Euston, currently in the Rugeley area. Allocated from platform 16 at Euston.
itfcfan
7 May 2011
Great! Thanks for the info.
