DCR locos
Loadhaul60059
3 Feb 2025
David Fletcher has also posted in the Class 60 including photos of 60022 and 60060 with details of ongoing work.
Photos here (https://www.linkedin.com/posts/davi...p&rcm=ACoAAAoy8y4BR3SpdLaswiS8ALwgwk-4oRUvigA), and posted below for those that don't have access to LinkedIn.
The 60's are my favourite class of loco, so seeing all this work being done to bring some of them back to life is fantastic.
1769721170240
Inside of 60022.
1769722643811
Inside of 60060.
1769721206223
18 Mar 2018
37114
4 Jul 2019
Do we know if they're having the original spec engine put back in or will they be a different shaped 66
60099 was original engine so expect these to be the same. It would be a big job to put a 66 power unit in and arguably takes away one of the advantages a 60 has over a 66.
ExRes
16 Dec 2012
Back in Sussex
60055 worked 0149 6D23 Wembley Receptions 1-7 to Penmaenmawr Quarry empties
60095 worked 0500 6L92 Kings Lynn TC to Middleton Towers empties, loaded 0911 6M89 to Chaddesden and loaded 1543 6M91 to Ravenhead Sidings
It seems that 60028 worked 1737 0Z28 Leicester LIP to Toton TMD yesterday (Friday) for reasons not yet known, Rail Record are showing it as, rightly or wrongly, a GBRf operated service
23 Aug 2017
60095 working 0500 6L92 Kings Lynn TC to Middleton Towers empties, loaded 0911 6M89 to Chaddesden and loaded 1543 6M91 to Ravenhead Sidings
There are currently the following schedules showing for Tuesday - 1031 0Z97 Leicester LIP to Barrow Hill RS & 1310 0Z98 return, there are also 1630 0Z60 Leicester LIP to Wembley Loco Sidings and 2145 0Z61 to Willesden
60028 at TO for Tyre Turning, back Monday to be paired with its partner.
D365
29 Jun 2012
60014 is the designated 'concept' locomotive for any possible re-engineering by Progress Rail at Longport. The last I heard was that EMD engines have been conclusively ruled out.
Thus, DCR Class 60s will be retaining their as-built engines.
ExRes
16 Dec 2012
Back in Sussex
Thanks for the info @56091
*Updated Sunday 1st February*
60055 worked loaded 0947 6A25 Penmaenmawr Quarry to Wembley Receptions 1-7, 1647 0A25 to Willesden and 1746 0M23 return
60095 worked 1839 6H85 Ravenhead Sidings to Tunstead Sidings empties
*Updated Monday 2nd February*
60029 worked 0328 6C50 Bristol East Depot to Merehead Quarry (Fhh) empties, loaded 1020 6M51 to Quainton Railhead which failed and was moved to Westbury by 66035 as 1Z99 and after being fixed by roadside assistance loaded 2200 6Z55 Westbury Up Reception to Willesden
60095 worked loaded 0334 6M71 Tunstead Sidings to Humberstone Road No5 Top Sidings and 1516 6D59 to Chaddesden empties
60055 worked loaded 0438 6M23 Wembley Receptions 1-7 to Quainton Railhead and 1040 0A28 Aylesbury North Loop to Aylesbury Sidings
60046 worked 0803 0A21 Aylesbury Sidings to Quainton Railhead, 1034 6V37 Aylesbury North Loop to Tytherington empties and loaded 2158 6M29 to Wembley Receptions 1-7
60046 & 60055 worked 0953 6V37 Quainton Railhead to Aylesbury North Loop empties
56045 & 56103 worked 1034 6V23 Willesden to Merehead Quarry (Fhh) empties and loaded 1606 6M18 return
60028 worked 1442 0Z28 Toton TMD to Leicester LIP
60099 is at Leicester LIP
tugwatch
2 Feb 2026
Wiltshire
What's the status of 60029 after the failure today? Is it parked up at Westbury? And if so, for how long? Did the consist ger parked at Westbury too?
47286Dan
27 Dec 2018
It’s showing allocated 6Z55 Westbury to Willesden, leaving at 22:00. Issue must of been fixed as no other loco showing
Dan
ExRes
16 Dec 2012
Back in Sussex
56045 & 56103 worked 0236 6O34 Willesden to Cliffe Brett Marine empties and loaded 1840 6Z56 to Willesden, the 6Z20 Chessington South Sidings visit was cancelled due to the minor derailment of 56045 at Cliffe
60046 working loaded 0437 6M23 Wembley Receptions 1-7 to Quainton Railhead, 1040 0A28 Aylesbury North Loop to Aylesbury Sidings, 1638 0A52 to Quainton Railhead and 1935 6Z54 Aylesbury North Loop to Bristol East Depot empties
60055 worked 0803 0A21 Aylesbury Sidings to Quainton Railhead, 1034 6V37 Aylesbury North Loop to Tytherington empties and loaded 2137 6M29 to Willesden
60028 & 60099 worked 1031 0Z97 Leicester LIP to Barrow Hill, 1310 0Z98 return, 1630 0Z60 to Wembley Loco Sidings and 2145 0Z61 to Willesden
60029 worked loaded 1146 6Z51 Willesden to Quainton Railhead and 2010 0A54 Aylesbury North Loop to Aylesbury Sidings
60029 & 60046 worked 1852 6V54 Quainton Railhead to Aylesbury North Loop empties
60095 worked 2035 6M81 Chaddesden to Peak Forest D&C empties
Trainman40083
29 Jan 2024
Derby
56045 & 56103 working 0236 6O34 Willesden to Cliffe Brett Marine empties - 0951 6Z20 - 1942 6M17
60055 working 0803 0A21 Aylesbury Sidings to Quainton Railhead
60046 & 60055 - 0953 6V37
60028 & 60099 - * Scheduled 1031 0Z97 - 1310 0Z98 - 1630 0Z60 - 2145 6M71 *
60095 - 2035 6M81 Chaddesden to Peak Forest D&C
60029 is at Willesden
Thanks for this. I wondered what would work with 60099.
BRX
20 Oct 2008
56045 apparently currently the victim of a minor derailment at Cliffe, so the Cliffe-Chessington trip has not happened yet.
ExRes
16 Dec 2012
Back in Sussex
60046 worked 0345 6C50 Bristol East Depot to Merehead Quarry (Fhh) empties, loaded 1020 6M51 to Quainton Railhead and 2010 0A54 Aylesbury North Loop to Aylesbury Sidings
60095 worked loaded 0350 6L82 Peak Forest D&C to Eccles Road Johnstons Sidings and 1700 6M54 return empties
60055 worked loaded 0433 6M23 Willesden to Quainton Railhead, 1040 0A28 Aylesbury North Loop to Aylesbury Sidings, 1638 0A52 to Quainton Railhead and 1935 6V54 Aylesbury North Loop to Bristol East Depot empties
60029 worked 0803 0A21 Aylesbury Sidings to Quainton Railhead, 1034 6V37 Aylesbury North Loop to Tytherington empties and loaded 2137 6M29 to Willesden
60029 & 60055 worked 0953 6V37 Quainton Railhead to Aylesbury North Loop empties
60099 & 60028 worked 1034 6V23 Willesden to Merehead Quarry (Fhh) empties and loaded 1606 6M18 return
60046 & 60055 worked 1852 6V54 Quainton Railhead to Aylesbury North Loop empties
47286Dan
27 Dec 2018
600xx working 0345 6C50 Bristol East Depot to Merehead Quarry (Fhh) empties - 1020 6M51
60095 working loaded 0350 6L82 Peak Forest D&C to Eccles Road Johnstons Sidings - 1700 6M54
600xx working loaded 0433 6M23 Willesden to Quainton Railhead
600xx - 0808 0A21 Aylesbury Sidings
Scheduled (60099 & 60028) - 1034 6V23 Willesden to Merehead Quarry
Your missing 60s @ExRes
56045 DCRO WILSDNDCR WILSDNDCR 4 N
56103 DCRO WILSDNDCR WILSDNDCR 4 N
60028 DCRO WILSDNDCR WILSDNDCR F N
60029 DCRO AYLBYDMUD 700A21TC04 F QUNTNRLHD N
60046 DCRO MEREQFHH MEREQFHH 4 N
60055 DCRO QUNTNRLHD QUNTNRLHD 4 N
60099 DCRO WILSDNDCR WILSDNDCR F N
60095 GBTG PKFORSTDC 346L821304 4 ECCLESRD N
Dan
Loadhaul60059
3 Feb 2025
Morning All,
Considering making a special trip out to see the 1034 6V23 Willesden to Merehead Quarry if 60099 and 60028 are on it.
How far in advance are the loco's normally allocated in TOPS please?
I believe the alternative is that the 56's would work it, but I'm not as fussed about seeing them.
Thanks!
47286Dan
27 Dec 2018
Morning All,
Thanks!
Both 60s now showing allocated @Loadhaul60059
Do you need the consist?
Dan
Loadhaul60059
3 Feb 2025
Dan
Perfect, thanks Dan! I’m on my way to see it now.
No need for the consist - thanks for asking though!
And here it is! Great to see it back out on the rails.
47286Dan
27 Dec 2018
Wednesday afternoon update
60028 DCRO MEREQFHH MEREQFHH 4 N
60029 DCRO QUNTNRLHD 706V371F04 4 * TYTHRINTN N
60046 DCRO MEREQFHH 826M511G04 4 * QUNTNRLHD N
60055 DCRO AYLBYDMUD AYLBYDMUD F N
60099 DCRO MEREQFHH MEREQFHH 4 N
60095 GBTG ECCLESRD ECCLESRD 4 N
Dan
47286Dan
27 Dec 2018
Thursday morning update
56045 DCRO CLIFFE CLIFFE 4 N
56103 DCRO CLIFFE CLIFFE 4 N
60028 DCRO WEMRECP WEMRECP F N
60029 DCRO QUNTNRLHD QUNTNRLHD 4 N
60046 DCRO AYLBYDMUD 700A21TC05 F QUNTNRLHD N
60055 DCRO MEREQFHH MEREQFHH 4 N
60099 DCRO WILSDNDCR WILSDNDCR 4 N
60095 GBTG PKFORSTDC 346L821405 4 ECCLESRD N
Dan
ExRes
16 Dec 2012
Back in Sussex
Dan
Thanks for the updates @47286Dan been a bit busy the last couple of days
60028, 60029, 60046 & 60055 worked variously 0223 0M29 Willesden to Wembley Receptions 1-7, 0345 6C50 Bristol East Depot to Merehead Quarry (Fhh) empties, loaded 0437 6M23 Willesden to Quainton Railhead, 0803 0A21 Aylesbury Sidings to Quainton Railhead, 0953 6V37 Quainton Railhead to Aylesbury North Loop empties, loaded 1020 6M51 Merehead Quarry (Fhh) to Quainton Railhead, 1034 6V37 Aylesbury North Loop to Tytherington empties, 1040 0A28 Aylesbury North Loop to Aylesbury Sidings, 1311 0M37 Wembley Receptions 1-7 to Willesden, 1638 0A52 Aylesbury Sidings to Quainton Railhead, 1852 6V54 Quainton Railhead to Aylesbury North Loop empties, 1935 6V54 Aylesbury North Loop to Bristol East Depot empties, 2010 0A54 Aylesbury North Loop to Aylesbury Sidings and loaded 2137 6M29 Tytherington to Willesden
56045 & 56103 worked 0238 6O34 Willesden to Cliffe Brett Marine empties, loaded 0951 6Z20 to Chessington South Sidings and 1942 6M17 to Willesden empties
60095 worked loaded 0423 6L82 Peak Forest D&C to Eccles Road Johnstons Sidings, 188 late arrival due to 'track inspection
60099 is at Willesden
47286Dan
27 Dec 2018
@ExRes
For your information
60099 had a minor fault on route back to Willesden yesterday and has now been put in T status (transfer) at Willesden.
60099 DCRO WILSDNDCR WILSDNDCR 4 T
Dan
ExRes
16 Dec 2012
Back in Sussex
@ExRes
Dan
Thanks @47286Dan I saw on one of the gen sites that 099 had some sort of teething problem yesterday
Did they do a swap with 028 & 029 at Wembley on 6V37 today? I see there was a 1311 0M37 Wembley to Willesden
Thanks
47286Dan
27 Dec 2018
Thanks
56045 DCRO CLIFFE 886Z201F05 4 * CHSSTHSDG N
56103 DCRO CLIFFE 886Z201F05 4 * CHSSTHSDG N
60029 DCRO WEMRECP 706V371F05 4 * TYTHRINTN N
60046 DCRO WILSDNDCR WILSDNDCR F N
60055 DCRO MEREQFHH 826M511G05 4 * QUNTNRLHD N
Dan
ExRes
16 Dec 2012
Back in Sussex
Dan
Thanks @47286Dan I guess I'm just having one of my advanced age days today, I can't see how 029 can be on 6V37, 046 at Willesden and 028 at Wembley, to me that means there's nothing to release 60055 from Quainton after unloading, I'm sure I must be missing the obvious, not for the first or last time .......
47286Dan
27 Dec 2018
Looks like there’s been a bit of mix up on the system
Now showing this
60046 DCRO QUNTNRLHD 706V371F05 4 * TYTHRINTN N
Dan
ExRes
16 Dec 2012
Back in Sussex
A couple of bad days yesterday and today plus very light on info from most usual sources, so I apologize if there are any/many errors
60028, 60029, 60046 & 60055 worked variously 0345 6C50 Bristol East Depot to Merehead Quarry (Fhh) empties, loaded 0437 6M23 Willesden to Quainton Railhead, 0803 0A21 Aylesbury Sidings to Quainton Railhead, 0953 6M37 Quainton Railhead to Aylesbury North Loop empties, loaded 1020 6M51 Merehead Quarry (Fhh) to Quainton Railhead, 1034 6M37 Aylesbury North Loop to Wembley Receptions 1-7 empties, 1040 0A28 Aylesbury North Loop to Aylesbury Sidings, 1310 0M37 Wembley Receptions 1-7 to Willesden, 1420 0D23 Willesden to Wembley Receptions 1-7, 1638 0A52 Aylesbury Sidings to Quainton Railhead, 1834 6V54 Quainton Railhead to Aylesbury North Loop, 1935 6V54 Aylesbury North Loop to Bristol East Depot empties and 2010 0A54 Aylesbury North Loop to Aylesbury Sidings
60046 worked 0508 6O20 Willesden to Grain Foster Yeoman empties, loaded 0930 6Z20 to Chessington South Sidings and 1942 6M17 to Willesden empties
60095 worked delayed (1523) 1143 6H84 Eccles Road Johnstons Sidings to Kings Lynn TC empties
60099, 56045 & 56103 are at Willesden
