Day return to Blackpool
wilbers
10 Mar 2022
Penrith
As I've discovered that a simple day return from Penrith to Blackpool (North or South) isn't an option with one ticket, but requires a split at either Preston or Kirkham I was wondering why more touristy destinations don't have longer distance day returns than some other places?
In a similar vein as I was curious, I tried a few other random places to see how far away from Blackpool day returns are offered. Out of those York seemed to be the furthest.
Llandudno
25 Dec 2014
Matlock
Nottingham to Llandudno via Chester - off peak day returns available
Chester to Llandudno - No day returns available
PMH
28 Feb 2022
Staffordshire
On a slightly related note Crewe-Llandudno advance singles are £10, changing at Chester, while an advance single to Chester on the same train is £14.
I'm new here and entirely ignorant, so can't begin to work out the logic behind that.
Mcr Warrior
8 Jan 2009
Chorley -> Edinburgh. Off Peak Day Return available.
Chorley -> Moston. No through Day Return fares showing as available.
CyrusWuff
20 May 2013
There's not a lot of logic involved in the ticketing system, it has to be said.
Chiltern, for example, sell Super Off-Peak Returns from London to Banbury for the same price as London to Birmingham and London to Kidderminster.
Starmill
18 May 2012
Bolton
There is no logic behind it. It's just a case of what type of fare the operator wants.
For example, Off Peak Day Returns are available from Newark to London, from Dover to London, and Banbury to Bournemouth. But they aren't available from Huddersfield to Manchester, Derby to Birmingham or Swindon to Reading, which are all only half an hour on a non-stop service.
It's worth noting that the Crewe to Chester ticket is probably not an Advance.
Kite159
27 Jan 2014
West of Andover
Salisbury to Cardiff, only ticket available is an Anytime Return. No day return fares or even a cheaper Off-peak return.
I know it's roughly 2 hours in each direction but logical for someone to have a day-trip to see the Welsh Capital
Mcr Warrior
8 Jan 2009
Actually, there are Off Peak Day Return fares from Huddersfield to Manchester.
However, these are routed "via Hebden Bridge" which effectively precludes using them on the non-stop service.
PMH
28 Feb 2022
Staffordshire
Completely new to all this, so don't understand the distinctions between fares, and the Llandudno fare jumped out as being so cheap.
Is there a way of finding similar anomalies, or is it just a case of trial and error?
I've moved near Crewe/Stoke/Congleton and am looking to plan some trips out of any of those stations. Suspect I've been paying over the odds for years.
Starmill
18 May 2012
Bolton
Not to worry, we're here to give what guidance we can!
It's worth noting carefully what the ticket name is. An 'advance' ticket always restricts breaks of journey, meaning that an advance ticket from Crewe to Llandudno cannot be used to travel to Chester (unless you were to go to Llandudno and then return to Chester, using a separate ticket from Llandudno to Chester, of course).
In general it is just about knowing where to look. Services such as trainsplit may be of interest to you though - try new.trainsplit.com.
Llandudno
25 Dec 2014
Matlock
Howabout an off peak day return Congleton to Macclesfield £5.80 and then use a Peak Wayfarer ticket £15.20, visit all of Greater Manchester plus Hope Valley line to Grindleford and parts of Lancashire, virtually all trains, trams and buses.
Mcr Warrior
8 Jan 2009
Approximate hourly daytime 58 bus service from Macclesfield to Buxton could be of use for a Wayfarer ticket holder and quite a scenic journey in its own right.
That is just a British Rail legacy. Network South East had day returns between all its stations. Intercity didn't.
Mcr Warrior
8 Jan 2009
Fairly sure there was an Off Peak Day Return (route Any Permitted) ticket between Huddersfield and Manchester, until just a few years ago (as well as the more restrictive but still available route Hebden Bridge variant mentioned upthread).
I'd be interested to know when Newark became part of the Network area? ;)
But regardless, @Starmill aptly illustrates that the availability of cheaper day tickets has little to do with whether a journey is feasible to do in a day, and far more to do with the pricing policy of the fare setter concerned.
Indeed. It was withdrawn for a while, but there is once again an Off-Peak Day Return from Leeds to Manchester - albeit it presents a very limited saving compared to the ("regulated") Off-Peak Return.
Starmill
18 May 2012
Bolton
I'm afraid that's incorrect. As has been pointed out above by Watershed London to Newark is a former 'intercity' fare. Lots of 'intercity' fares actually were the old cheap day returns. Furthermore the removal of the Off Peak Day Return between Derby and Birmingham is a recent thing - it still existed in 2018.
It is however true that nearly all journeys for Network South East only would have had a cheap day return. However there were some gray areas even there.
The bit about Network South East having off-peak day returns for all their flows is correct. I agree that you picked some examples that were outside the south east where there is less consistency. In the south east, the inconsistency is more around which routes have period returns, and the differential between day and period returns.
Starmill
18 May 2012
Bolton
It was correct once, however there were grey areas even there. For example at the origination of sectorisation, before the name NSE was even thought up, Yeovil - Exeter wasn't included. This meant that some journeys from, for example Axminster, didn't have cheap day returns to everywhere else when the NSE brand was launched and the Network Railcard extended to Exeter.
Nowadays it is even more of a mess, SWR recently converted all of their Super Off Peak Day Returns into period returns, except for the very shortest journeys which got the ridiculous evening tickets instead, for example.
Hadders
27 Apr 2011
There are lots of anomalies and good value fares but this forum is monitored by the train companies and mentioning an anomaly on here is a good way to get it withdrawn.
The forum runs fares workshops and forum meals where these sort of things are often discussed.
Deafdoggie
29 Sep 2016
I spent many years living in Brindley Ford. It's virtually always cheaper to split at Stafford if heading to Birmingham or beyond. Street parking at Longport is easy and cheap. Congleton isn't too dear for parking but can get full.
I am always impressed by the Preston-Glasgow/Edinburgh day return (£43.90, after 0930).
Especially as the Edinburgh fare is valid via Glasgow, so you can fit in both cities and any route between them.
There's an even cheaper TPE-only version (£40.20).
unlevel42
5 May 2011
Do not be confused by the two Wayfarers available:
The cheaper Derbyshire Wayfarer (£13.40, £6.70 for over 60's) is valid on the:
58 bus from Macclesfield to Buxton(Sun: Bakewell and Chatsworth)
the 60 bus to New Mills Newtown(Buxton trains) and Central(Sheffield Hope Valley).
also buses to Leek, Ashbourne, Uttoxeter, Burton and East Midlands Airport.
Train destinations (from 09.00)include Sheffield, Chesterfield, Derby, Ilkeston, Matlock, Burton, Uttoxeter(not via Stoke unless you pay extra)and Long Eaton.
30907
It is, you simply use an Offpeak Return. The same is true of many journeys (short or long) where fares are set by what used to be InterCity operators.
...which is cheaper, because Avanti offer an offpeak day return which is time-restricted but significantly cheaper than their no-restrictions single fare.
Whether it is coincidence that TPE offer even cheaper fares restricted to their own trains I leave you to judge.
...which I would guess is set by Northern who are not a descendant of Inter City.
miklcct
2 May 2021
Cricklewood
There isn't off-peak day return between Bournemouth - London. There is anytime day return and off-peak return. It's much cheaper to split at Basingstoke such that the whole journey is all done on day returns but it can only be done on Sundays because on weekdays not all trains call at Basingstoke.
PMH
28 Feb 2022
Staffordshire
Cheers, will just try trial and error and see where it gets me (Llandudno at this rate)
Cheers, will have a look.
That's absolutely ideal, thanks, and I'd just drive to Macc in that instance. That's my next day out sorted I think.
Handy to know, though I'd likely drive to Buxton and leave the car there.
Great stuff, thanks.
Thanks, and free parking is always on my list of things to recommend a station. I've found free street at Stoke (a faff, but just about worth the hassle), Macc, Crewe and Buxton. Liked that at Congleton parking could've extended on the app.
Cheers, will keep an eye out for that.
blakey1152
5 Sep 2011
I recently did a split from Manchester Picc to Edinburgh. I discovered that a TPE Ticket from Manchester to Edinburgh was considerably more expensive than getting 2 off peak day returns from Manc Pic to Preston and Preston to Edinburgh because there is no off peak day return available for the whole journey!
Despite the fact that it was the same train both ways... I felt sorry for anyone who ended up doing that journey on an off peak return without knowing...
To be fair it has to be a somewhat unlikely set of circumstances where you're doing a day trip between the two stations, given the journey time of over 3 hours. Though I admit it's not totally implausible. Even Preston to Edinburgh as a day return is pushing it, and it's very unusual amongst long distance IC flows to have a CDR.
blakey1152
5 Sep 2011
It was a long day! But still got five hours in Edinburgh :)
