DynamicSpirit
The Woolwich line timetable is currently a mess, and I'm wondering if it would work better if the 2tph Thameslink Rainham trains went via Lewisham, with all the Cannon Street trains going via Greenwich?
Some years ago, before Thameslink was running on that route, the pattern was:
That meant the pattern was simple and every station west of Slade Green got at least a train every 10 minutes. But then Thameslink started running on that route, it screwed up the regular intervals because Thameslink replaced 2tph of the via Greenwich trains but (for reasons I don't fully understand) apparently has to run semi-fast east of Charlton. So you ended up with:
That pattern makes it impossible to run a regular 10-minute frequency at all stations via Greenwich because different trains are stopping at different stations. Not only that but Thameslink timetable constraints make it hard to fit their trains evenly into the gaps between SouthEastern trains. And to make it worse, SouthEastern have currently removed 2tph of the all stops via Greenwich (might be reinstated in the future). The result is that some stations on the line now have regular gaps of as much as 24 minutes between services, followed by two trains arriving in quick succession.
I'm thinking it would be better to have:
You'd still need SouthEastern to restore the 2tph that they removed to get back to a proper 10-minute interval, but even without that, it looks to me like running Thameslink via Lewisham would allow a better, more passenger-friendly, timetable.
Thoughts? Could that idea work?
- 6tph via Greenwich to Cannon Street - running every 10 minutes and stopping everywhere.
- 2tph via Lewisham to Charing Cross - running every 30 minutes and semi-fast.
- 4tph all stops via Greenwich to Cannon Street
- 2tph semi-fast via Greenwich to Luton/Thameslink
- 2tph via Lewisham, all stops east of Charlton, at the time to Charing Cross but now those trains run to Cannon Street.
- 6tph (currently reduced to 4tph) via Greenwich to Cannon Street - running every 10 minutes and stopping everywhere.
- 2tph via Lewisham to Luton/Thameslink - running every 30 minutes and semi-fast.
