Could Open Access Operators operate on HS2?
Fazaar1889
5 Oct 2022
South East
moderator note - split from:
Could open-access operators run on the HS2 lines? Similar to Lumo (London to Edinborough) or Italo in Italy? I think it could become a viable alternative to cheap domestic flights.
Would depend on capacity and take-up of paths by the DfT HS2/WCML operator (presently Avanti).
But it seems unlikely the HS2 operator will use all 18tph paths with the cut-back of the eastern and Golborne legs.
So capacity is likely to be available to Birmingham, and to Manchester when the HS2 extension is built.
But capacity on to the classic WCML will be limited as it is now.
Open access might also be viable on the classic WCML (south) when Avanti transfers to HS2.
I must admit I like the idea of a codeshare.
Bit of thread crossover, but really all the major airline alliances should codeshare onto HS2 normal services (not just a few open access ones) and we can then get rid of Manchester to London domestic flights and probably reduce the Glasgow ones a bit.
Roast Veg
28 Oct 2016
As long as the OOC transfer is well signed, that would be a great solution too.
GRALISTAIR
11 Apr 2012
Preston Lancs
Yes great ideas.
Winthorpe
18 May 2019
I read the other day that Delta / TransPennine Express are starting an Air+Rail scheme:
Delta Air Lines is partnering with TransPennine Express to bring its Air+Rail programme to the UK, connecting northern and Scottish cities to the US via Manchester Airport.
Let's hope HS2 put in place a similar scheme with airlines at Heathrow / Manchester...
Northampton
I expect Airlines will be looking at HS2 with great interest, especially once it reaches Manchester Airport. However the need to offer 2 connections from Heathrow (Elizabeth Line & HS2) may restrict the opportunities.
Winthorpe
18 May 2019
I suppose Birmingham Airport will be the big winner. The 38 minutes journey time to Euston will turn it into an extra London airport.
Northampton
Certainly from phase 1. I wouldn't be surprised if lots of Airlines are looking to offer Loyalty points on HS2 tickets and other similar incentives.
camflyer
13 Feb 2018
Some airlines in the US are even doing Air+Bus services for short connections to hubs mostly driven by pilot shortages but it also allows them to offer through-ticketing to towns which can't support an air service.
United and American Airlines are among companies introducing bus services on some routes, a report says​
  • Some US airlines are introducing a bus travel service on short routes.
  • United and American signed contracts with the bus-as-flight company Landline, Bloomberg reported.
Winthorpe
18 May 2019
Thanks, very interesting. I didn’t know about this.
In theory - probably not. It would be very difficult to find a market that passed the ‘not primarily abstractive’ test fir anything that used HS2. Certainly not in competition with Domestic air, fir which the only possible markets are Glasgow and Edinburgh.
In practice - almost certainly not. An OA operator would have to lease an HS2 spec train, and they will not be cheap.
Fully HS2 spec, or just a UK gauge high speed train? For instance a 373?
But then brand new 80x are the train of choice for OAOs now, and I doubt those are much cheaper.
