Cottam Parkway - Compulsory Purchase Orders Confirmed, Station To Be Built
I’m guessing Salwick will be closed once this station opens and anyone for westinghousing power plant will be required to use cottam parkway
I don't believe that is the plan. It will be interesting to see how they deal with the stop on the Blackpool South services as it doesn't fit in the existing schedules. It also makes the Liverpool turnarounds tight and the York ones less resilient. Fit for 8 x 25m too.
Llandudno
25 Dec 2014
Matlock
Maybe only the Manchester’s will call every 30 minutes?
Some guy
6 Feb 2022
Preston
That’s if they fit into the castlefield corridor as it adding time could slow down a service behind it or reduce the turnaround time at Manchester airport. That seems the most likely do west of Preston has a direct Manchester service
GRALISTAIR
11 Apr 2012
Preston Lancs
I’m guessing Salwick will be closed once this station opens and anyone for Westinghouse nuclear facility will be required to use Cottam parkway
I thought that, but Salwick station received a major refurb when the line was electrified 5 years ago.
BTW - the number of new homes being built in the surrounding area is eye-watering.
Topological
20 Feb 2023
Swansea
Maybe makes a case for a loop to enable Blackpool South to go to half-hourly?
Assuming the demand is going to be there then it is probably worth looking at the interworking of diagrams and/or the Blackpool turn-around times to facilitate more stops.
Manchester services would be sensible as it would be logical that some residents would work in Manchester (also to a lesser extent Liverpool).
As @GRALISTAIR notes there is a lot of development going on and a station could be very useful for the new residents.
You wouldn't alter the times east of Cottam, you eat into the Blackpool turnaround. Arrive later, leave earlier.
Doubt it. Anyone from Cottam wanting the Blackpool South line will be forced into a change at Kirkham. It would be about a 6 minute connection off the York into a Blackpool South and 11 going the other way.
Topological
20 Feb 2023
Swansea
Thanks as always.
I do quite like the fact that you will have a train that stops at some very small places (e.g Moss Side) then running non-stop through the new Cottam station.
It would be nice if there was a loop on the Blackpool South line, but it is very much a speculative discussion to talk of it.
Like you, I can only see the turnaround at Blackpool North being played with to accommodate Cottam. I do not know whether there is wriggle room there or not, but with similar units used on Liverpool - Blackpool North and Manchester - Blackpool North then maybe there is more interworking.
Maybe a second Liverpool - Blackpool North even (but again that is hugely speculative).
GRALISTAIR
11 Apr 2012
Preston Lancs
So this is Salwick from fairly recently. Quite a bit of money spent refurbishing. As the crow flies, Cottam is less than 1 mile away. So even when Cottam Parkway is open, I would be surprised if Salwick as depicted below is closed.
Tender for £10-20m station construction issued 10th March 2025, two platforms suitable for 8car operation
1 buyer​
Description​
The prospective scheme at Cottam Parkway Station, is for a new two platform station with footbridge & VLB lifts on the Preston - Blackpool line (PBN) between 2m 77ch and 3m and 33ch. Platform lengths suitable for 8 car operation. The scope of works include two platforms, one station building circa 200m^2, one footbridge (700 series, open) with one lifts and stairs per platform, the lifts will be a Serapid VLB lift used as an evacuation lift, OLE modifications, East and west car park banks, track renewal and new track drainage, the current station design includes booking office, booking hall, community space, parking for 300 cars, cycle storage and possible bus interchange. The funder is Lancashire County Council who are funding the scheme via the Transforming Cities programme. The ES4 Approval in Principle design is complete and planning permission has been granted based on previous ES3 design, however material change is needed based on the current ES4 design. Octavius' ES5-8 estimate, informed through this market tender exercise, is to give Network Rail and Lancashire County Council confidence in cost & programme before submitting a final business case, seeking final investment authority & subsequent contract award.
CPV Codes​
  • 45213312 - Car park building construction work
  • 14213000 - Macadam, tarmac and tar sands
  • 71355000 - Surveying services
  • 71311000 - Civil engineering consultancy services
  • 45232452 - Drainage works
  • 71320000 - Engineering design services
  • 34946200 - Railway-track construction supplies
  • 45230000 - Construction work for pipelines, communication and power lines, for highways, roads, airfields and railways; flatwork
  • 71220000 - Architectural design services
  • 38290000 - Surveying, hydrographic, oceanographic and hydrological instruments and appliances
  • 34946000 - Railway-track construction materials and supplies
  • 45234000 - Construction work for railways and cable transport systems
  • 71321000 - Engineering design services for mechanical and electrical installations for buildings
  • 45262520 - Bricklaying work
  • 45221112 - Railway bridge construction work
  • 22314000 - Designs
  • 45223210 - Structural steelworks
  • 45213320 - Construction work for buildings relating to railway transport
  • 34632300 - Electrical installations for railways
  • 34942000 - Signalling equipment
  • 44212310 - Scaffolding
  • 71311230 - Railway engineering services
  • 32500000 - Telecommunications equipment and supplies
  • 45316200 - Installation of signalling equipment
  • 31600000 - Electrical equipment and apparatus
  • 45200000 - Works for complete or part construction and civil engineering work
  • 71353200 - Dimensional surveying services
  • 45262500 - Masonry and bricklaying work
  • 45111240 - Ground-drainage work
  • 45314000 - Installation of telecommunications equipment
  • 71250000 - Architectural, engineering and surveying services
  • 79311000 - Survey services
  • 79311100 - Survey design services
  • 38296000 - Surveying instruments
  • 45221213 - Covered or partially-covered railway excavations
  • 71322000 - Engineering design services for the construction of civil engineering works
  • 71327000 - Load-bearing structure design services
  • 44212400 - Piling
  • 45234115 - Railway signalling works
  • 34632200 - Electrical signalling equipment for railways
  • 45234100 - Railway construction works
  • 71325000 - Foundation-design services
  • 31000000 - Electrical machinery, apparatus, equipment and consumables; lighting
  • 31682400 - Overhead electrical equipment
  • 45232450 - Drainage construction works
  • 45213321 - Railway station construction work
  • 79311200 - Survey conduction services
Indicators​
  • Contract is suitable for SMEs.
Other Information​
Please follow this link to view the notice https://www.competefor.com/business/viewOpportunityDetailsSupplier.html?id=91404...
Reference​
  • C4N91404189
  • CF 54cf7db4-f086-4a2e-a2b0-c185a8d8139e
GRALISTAIR
11 Apr 2012
Preston Lancs
Thanks for the update. I am home in Preston on Saturday and was going to ask my councilor friend for an update. Looks like they will start on site in 2026 as I am retiring so I will be able to post regular photographic and other updates.
Excellent news all round. Thanks again.
GRALISTAIR
11 Apr 2012
Preston Lancs
Here is the BBC article. Looks like boots on the ground January 2027.
A long-planned railway station serving a growing community on the western edge of Preston has moved a step closer to becoming a reality after funding for the project was finally secured.
Lancashire's Combined County Authority (LCCA) has approved £28.2m towards the construction of Cottam Parkway, a new station on the line between Preston and Blackpool.
The money plugs a funding gap that had threatened the future of the scheme, which was first proposed more than a decade ago.
The station will be built on land between Lea Road and Sidgreaves Lane in Lea and is intended to serve the expanding Cottam and North West Preston areas.
Work is expected to begin next year, with the first passenger services expectee to call at the station in December 2030, the Local Democracy Reporting Service, external has learned.
When it opens, passengers could reach Preston in around five minutes and Blackpool in about 20 minutes. The station will also provide direct rail links to Manchester.
The LCCA has now agreed the funding taking the total budget for the project to £56.6m.
The government announced last year that it would contribute £28.4m towards the development, subject to approval of a business case. However, rising costs had pushed the overall price of the scheme to more than £55m, leaving a significant shortfall.
The latest funding allocation means the project can now progress, with Lancashire County Council set to deliver the station on behalf of the combined authority. Around 17,000 people are expected to live within the station's catchment area when it opens, with forecasts suggesting about 644,000 rail journeys each year will start or end there. Plans for the site include two platforms capable of accommodating eight-carriage trains, a station building with waiting facilities, lifts and a footbridge, a 250-space car park and bus connections. The scheme was first proposed as part of Lancashire County Council's Central Lancashire Highways and Transport Masterplan in 2013.Planning permission was granted in 2023 and most of the land required for the development is now in public ownership. The project is designed to support more than 6,000 homes planned for Cottam and North West Preston over the coming years, providing a new public transport option for one of the area's fastest-growing communities.
Quite eye watering imho.
childwallblues
3 Jul 2014
Liverpool, UK
When the lin was electrified in 2015 Cottam Parkway was just a blink in the eye. Times and plans change and Salwick will aimost certainly close as it only has a peak hour service.
Salwick is the only station in Fylde that I have never visited and am unlikely to as I no longer drive. At least I can say that I have been on a train to and from Fleetwood.
Kite159
27 Jan 2014
West of Andover
Salwick will probably remain open, similar to when Warrington West effectively replaced Sankey station. Will cost more for the paperwork to close it than what would be save
