"Copilot needs an update" pop-up notifications.
SargeNpton
19 Nov 2018
If you don't use Copilot, go into Control Panel on your PC and uninstall it.
Buzby
14 Apr 2023
Glasgow, Scotland
You can remove all of the Windows 11 bloat with a free utility called ‘Sparkle’. It allows you to unpic all the unwanted AI carp and has worked well for me for 2 years (where MS updates re-install the bloat again)!
Broucek
13 Aug 2020
Just make sure you disable it directly. Asking your co-pilot "assistant" to stop doing stuff seems to be impossible which raises interesting questions about the power dynamics in the relationship...
Harpers Tate
10 May 2013
I believe you can do exactly as SargeNpton says. Start > Add or Remove Programs ... find Co Pilot and uninstall. Pretty sure that's what I did and I see no evidence of it being here on my Win11 Home system here.
That's a change then. When it was initially rolled out to PCs it was almost impossible to remove completely. A bit of quick Google-fu suggests that they made it easier to remove with an update back in April/May.
