Clearly, since then, demand has changed (ie. no collieries/steelworks, the original raison d'etre, to serve) but contour lines largely have not, and areas that were built-on then are now mostly still built-on, leaving the flattest, least-obstructed possible routes as being those used in the past, at least if going via Stanley and Annfield Plain (to some degree there would be more flexibility if going northwards from Consett,as this area is more greenfield).
Thanks. I spent some of my childhood in Jarrow in the 60s and remember a freight line running through it which is now a cycle track.Best I can do remotely is http://www.railmaponline.com/
You have two options:
Derwent Valley Railway via Rowlands Gill and Shotlrey Bridge (https://en.wikipedia.org/wiki/Derwent_Valley_Railway_(County_Durham) )
or
Stanhope & Tyne Railway via Anfield Plain and Washington (https://en.wikipedia.org/wiki/Stanhope_and_Tyne_Railway)
Both lost routes their passenger services in the 1950's. (http://disused-stations.org.uk/c/consett/index.shtml )
Houses in the way are a relatively minor matter (apart from to the occupiers) when it comes to major projects with government backing. Houses on an old railway alignment were removed when Croydon Tramway was opened. Houses are removed when motorways are built. Hundreds of houses could be affected by HS2. And over 1000 houses will go if Heathrow Airport gets its third runway.Right. There was 2 lines from Newcastle to Consett and sometimed timetabled to acted like a loop service. Which closed from the 30s to the 50s. The last bit closed in the 80s and quickly was roaded over. Then the houses crept closer to those alignments as did even more roads. Even just during the last few years the remaining bridge was eventually brought down in Leadgate.
And then this mp appears and says, 'Lets rebuild the line'. And wastes time in The House by stating the case.
Until that mp can convince a few thousand homeowners and a few more thousand more car drivers to give there houses/cars up then, what a cretin if he thinks that thus is an actual plan.
rant rant
durhammagazine.co.uk
