Following from the other thread where XC say that separate tickets are separate contracts, looking at the NRCoC, this does appear to be the case, at least for compensation:
General start bit about "you can"
and item 43.b specifically
Appendix A has definitions, but there isn't one for what a "destination station" is. To me it'd be reasonable to assume it's where you're getting off, but it could just as easily be argued that it's where-ever the specific ticket says.
This is actually important because it varies compensation in some cases. Consider:
In the above scenario, a split ticket (at least if it named Station S) would get a refund, but a single ticket wouldn't.
But then what starts happening if I split the ticket in the middle of the delayed journey?
Would you get a 30min compensation for the first part and a 60 minute for the second if you had a split ticket? But the full 60 minute affair for a single-ticket?
And if there was a train before that (Train P) that wasn't delayed and you had a separate ticket for, would you get no refund for that portion?
What are the expect opinions on this?
Claim compensation if your arrival at the station on your ticket is delayed by...
It depends what they mean by "destination station"? If it's the station on the ticket then they could just refund depending on the delay of the leg. But if it's the end of the journey that's a different matter.if you arrive more than 60 minutes late at your destination station
Code:
Train A is delayed 30 minutes getting to station S.
Train B was a 45 minute transfer, so was easily caught (15 mins to spare).
Code:
Train Q is delayed 30 minutes by the time it gets to Station X, but by 1hr when it gets to the final destination of Station Y.
