Closed Stations Journey quiz
Xenophon PCDGS
17 Apr 2011
Having joined the short section of the Newcastle and Carlisle Railway, from the previous line, in order then to access the line of the Derwent Valley Railway (County Durham), the line to use has it first closed station at....
Elswick
Incidentally, Ryton was on the other line, but before it was reached, you had to pass through the open stations of Dunston and Blaydon first. The problem here is the approach line to the Derwent Valley Railway (County Durham) left that line between Dunston and Blaydon, so Ryton meant you had missed the connecting line junction.
DerekC
26 Oct 2015
Hampshire (nearly a Hog)
Scotswood Works Halt
Yes - apologies - got so involved in working out which way to go through Newcastle that I forgot where we were going! I would probably have ended up in Carlisle.
Xenophon PCDGS
17 Apr 2011
I presume mentioning Annitsford 1st (1860-1878) aka Dudley Colliery would be a contravention of Rule 4
Indeed it would as it was only a matter of about 10 chains in distance away from the newer station site.
Scotswood
Swalwell
DerekC
26 Oct 2015
Lintz Green
OK. Trying to work out what the criterion for inclusion (or not) is. Based on the examples in Rules 4 and 5 it seems to be about 400 metres (22 chains in old money). Is that a reasonable figure to keep in mind?
