Climate adaptation challenges facing a railway built for a very different world?
minimann
12 Aug 2020
Moderator note: Split from
From the suggestions above wasn't something similar experienced in the recent Spanish incident where the driver didn't realise/wasn't notified an incident had occured further back (most likely due to the light in that case). Naturally thoughts with all involved.
If, and it's a big if, this is climate related I do hope we consider a proportionate response and start to take seriously - with appropriate investment - the climate adaptation challenges facing a railway built for a very different world.
norbitonflyer
24 Mar 2020
SW London
Wasnt there an incident in Manchester recently when a freight train ran derailed for some distance without the driver realising, yntil a coupling parted.
deltic
8 Feb 2010
And what would a proportionate response be?
HIghly likely to be withdrawing services when the temperature exceeds a certain level just as happens now with storms. We dont have a resillent railway and no chance of investment to make it one.
Mcr Warrior
8 Jan 2009
Yes. September 2024. Audenshaw area. Track closed for around 8 weeks. Cause was reportedly due to a section of the track having widened after a number of retaining screws had failed.
GRALISTAIR
11 Apr 2012
Preston Lancs
Sadly, I fear you are correct.
SynthD
4 Apr 2020
To know how that counts as a proportionate response, what temperature do you have in mind, and how wide an area is closed for one temperature reading? How much must it lower to reopen the line?
speedy1
1 Sep 2023
Mossley
Great British Railways: let the train take the strain, but only in March, April#, May, September^ and October*
For everything else, there's the road network.
*Depending how many leaves fall
^After the kids are back at school
#If there isn't too much rain
The way things are going those temperatures could easily continue for weeks a time.
If you start withdrawing services on mass for weeks a year, people will start to question why the taxpayer is providing a billion pounds a month in subsidies. The railway will lose the political argument - and if it does it is doomed.
The railway will have to learn to operate at least the existing level of passenger service, in what would today be considered extreme conditions, without serious increase in subsidy.
If it cannot do this, it is ultimately condemned to a long slow death.
Freight services do not have anything like the same level of political resonance in my view - and in any case aggregates shipments during extreme temperatures seem futile as noone will be building anything.
Ashfordian6
2 Feb 2022
East Region
Much more likely the solution will be speed restrictions, and this happens already
Obviously this could lead to cancellations due to services running too far behind time.
Annetts key
13 Feb 2021
West is best
So, if the issue is rails buckling, due to the expansion of the steel in the heat, there are things that can be done:
  • Paint the rails with white paint, that helps to reflect some of the heat from the sun,
  • Stress the rails more often (CWR/LWR has a stress free temperature, above this temperature, if the rails get hotter, this is when there is a risk of the rails buckling, but if you cut-out a small section and then weld up the rails again (to join them), you increase the stress free temperature, however, when the hot period ends, the rails need stressing again, to reduce the stress free temperature otherwise the risk of a broken rail increases as the weather gets colder and all of this work costs money).
  • The position, inspection and maintenance of expansion joints will likely be needed,
  • For jointed track, more management of the the gap in the joints may be needed,
  • The ballast level may need to be better maintained, as a lack of ballast may in some cases increase the risks of the rails buckling,
  • The metal anchors/plates (sorry, can't remember their proper name) fitted to sleepers to reduce the sideways movement may need to be fitted in more areas,
  • Increased maintenance of the track formation may be needed,
  • More frequent routine track inspections may be needed.
Then there are other measures that may be needed for structures, embankments, cuttings etc.
For wetter weather, other measures will be needed.
devon_belle
21 Jul 2022
And all the above could be done, then we'd only have to deal with drainage, soil moisture deficit, flooding, foliage/wires/trampolines in storms, etc. I don't think the railway is ready for what is likely to be coming. If climate change brings a wider range of weather conditions to the UK then the railway will have to adapt (and cope) with increased levels of nearly every environmental challenge it currently faces.
minimann
12 Aug 2020
Agree. For the most part our network was built for a world that no longer exists. Being the first also means everyone else learns from our mistakes.
We will see greater extremes and shutting down UK plc when the wind blows, the rain falls or the sun shines clearly is not a sustainable response if we want a growing and thriving railway. That said the level of investment required is money the railway will never get, asset conditions are not the best anyway so adding this dimension is a challenge.
One suspects tactical interventions in high risk areas, more active management of the estate and sensible restrictions alongside possibly restressing the rails is where we will need to head but increased weather closures will be the short term response.
speedy1
1 Sep 2023
Mossley
Agreed
...the railway will have to adapt (and cope) with increased levels of nearly every environmental challenge it currently faces.
But it won't. The UK likes to ignore problems for decades then drag its feet.
The gov knows tackling all the issues will result in a large expense and a more expensive railway going forward. It's already one of the most expensive railways in the world. What more can the treasury and the public take?
Envoy
29 Aug 2014
I drove from Pwllheli to Cardiff today. Temperature in the 30s, no melted roads and air con working fine. Basically no different to driving the route on any other day.
Good job you did not use the trains as the entire Cambrian line got shut down - presumably because the Class 158 trains don't have working air con and only 4 small hopper windows per coach. Goodness knows when the new Class 197’s will take over the Cambrian routes?
Bantamzen
4 Dec 2013
Cheshire
Long term that simply isn't going to be economically viable. Even the odd day every year of shutting down large parts of the network can cause serious economic harm, but it becoming a regular go-to every time the temperature goes over a certain amount will have a massive & negative effect. If people can't get to work by train, many people don't get paid, many businesses don't make sales, tax revenue is lost, and money doesn't reach the parts of the economy that need it the most. Over a sustained period of time that would lead to more job losses as business call it a day, meaning even less people in employment, paying much less tax and relying more heavily on benefits.
So somewhere along the line the industry is going to have to decide how to best mitigate future issues, whilst continuing to provide some kind of service. But just giving up every time it gets a bit difficult is not an option.
KevinTurvey
9 Oct 2016
I am speaking from a north of England perspective, but I recall the later 80's and earlier part of the 1990s we had a run of hot summers, much warmer than the early 80's. I recall 1984, 1990 and 1995 being particularly warm and sunny, 1981 to 1983 the exact opposite. From 2000 to 2006 we had a run of mild winters. From about 2007 to about 2015 some very disappointing summers with a lot of rain, and very cold winters. We have not had a summer like this since 1976 (without ladybirds, and also a new Prime Minister, and a Chancellor called Mr Healy!)
Can we really predict accurately the weather over the next 50 years, as there are so many organisations with vested interests on both sides of the climate debate.
Zomboid
2 Apr 2025
Oxford
It's not just the rail industry of course.
The roads might not be melting too much this year, but that does happen in extreme heat, and whilst there are many factors involved, the increased numbers of potholes are also influenced by the winter effects of climate change.
The schools infrastructure is also struggling, we had a week of early finishes in the July heatwave because the buildings aren't designed to cope with such conditions. Homes weren't designed for it...
When it eventually does rain, there will most likely be some serious damage caused by flash flooding, and we will have more serious winter storms to contend with.
Every single part of our national infrastructure is being taken beyond it's normal operating window and things are failing. Rail will have to make the adjustments it can, but I don't think anyone really grasps the scale of what we're staring down the barrel of.
PartyOperator
26 May 2019
A few simple things - paint the rails white, increase the stress-free temperature (winter minimums are up too), get better at cutting back flammable vegetation.
Develop a hot weather timetable and try to announce it a couple of days in advance so people can make plans. Trying to run the best possible service that then falls apart is much worse. Obviously can't plan for a derailment or loss of power, but it would help to run fewer, slower, longer, air conditioned trains with sensible connections rather than fast frequent trains from everywhere to everywhere.
Long term - build HS2 in its entirety, to a modern standard that can cope with the temperature range (still much less than China and Japan experience every year). Ideally keep building. Then don't need to flog the conventional lines quite as hard.
Magdalia
1 Jan 2022
The Fens
I have been restricting my travel by rail almost entirely to these months since Covid.
Some mild winters I have been able to travel in early November or late February. This year I haven't travelled by rail since 8 May because the summer heat started so early.
devon_belle
21 Jul 2022
The weather? No. Climate trends? With increasing certainty, yes. We are seeing more frequent, longer, and hotter heatwaves in the UK, with recent decades being hotter on average than all those back to when records began. There is consensus on that because of the available data. As for the future, we can only extrapolate what is a practically intractible problem, but for example wars over food, water, and fuel are considered to be a considerable threat to UK security in the future (e.g. this report). Globally, there's a lot going on with the emerging El Nino (related to above-average tropical Pacific Ocean temperatures) which is ramping up to historic levels meaning a very serious summer for Australia with poorly-understood effects for the rest of Europe. I know several climate scientists who expect 2027 to blow 2026 out of the water.
Issues on the railway are comparably minor compared to all that, but lots of people and businesses rely on rail and I agree with above posters that the railway just giving up every time it's very hot, very cold, very wet, or very dry is not a sustainable strategy. The fact that some (ex)-TOCs seem to handle the heat fine and others fall apart almost immediately with no chance of recovery should be seriously investigated. For unavoidable work reasons I have had to commute into London on every one of the hottest days so far this year, and I am fortunate not to have been disrupted so far (Southern). Other companies may have a lot to learn.
Presumably this will end up with the rails being tensioned for higher routine temperatures.
Presumably the next problem is going to be that we now have millions of stressed trees, so presumably can expect issues if/when we do get heavy rain or wind.
Well various slab track systems are reportedly much more resistant to these sorts of temperature-induced buckling events.
But I'm not sure we can fundamentally escape surface conditions whilst the railway remains in the open. As storms, heatwaves and (depending on what happens to AMOC) even coldsnaps become more extreme, surface conditions are going to just keep getting worse.
It'd be very expensive, but there are locations where relatively short sections of new railway (including in tunnels) could replace larger lengths of the older railway. Much of the old railway infrastructure predates modern standards and I'm not sure how much we can depend on it to hold up.
And then there are locations like Shap where the high altitude sections of the railway are very exposed to climatic events.
Waterlemon
18 Sep 2023
Waterloo
I believe it was part of the HS2 rolling stock spec that passenger trains would be able to monitor track geometry to save them from needing a dedicated high speed track recording train. As GSM-R is replaced with a much higher bandwidth system I hope we see a large % of passenger fleets fitted with track recording devices.
That way track quality data can be captured and analysed at multiple points daily rather than once every 2 weeks or so when the yellow trains happen to cross over a particular section.
This would enable a much more proactive maintenance approach than currently as instead of getting a load of defects in every few weeks from the yellow train. Maintenance crews could see sections deteriorate in real time and triage/plan accordingly.
eldomtom2
6 Oct 2018
I believe this is fairly normal for HSR today. I know Japan is retiring the dedicated monitoring trains for the Shinkansen.
Annetts key
13 Feb 2021
West is best
Already there is video recording and monitoring of the OHL from some regular passenger service trains. You don't need to wait for a higher bandwidth radio link, the recorded data can be downloaded when the train returns to the depot for overnight light maintenance / cleaning. Of course, the trains would need to be fitted with the required equipment.
PMN1
20 Sep 2013
Interesting development in South Korea.
https://techxplore.com/news/2026-09...l&utm_campaign=daily-nwletter#google_vignette
Cooling overheated summer railways with 'thermal-blocking textile' technology
by National Research Council of Science and Technology
edited by Sadie Harley, reviewed by Andrew Zinin
As extreme heat waves intensify due to climate change, rail temperatures now exceed 60°C (140°F) during summer, increasing track-deformation risks. This has necessitated speed restrictions, causing delays and raising safety concerns.
The Korea Railroad Research Institute (KRRI) has developed the world's first "rail-mounted thermal-blocking textile with automated installation and retrieval system" to mitigate temperature rises on railway tracks during extreme summer heat.
The work was published in the journal Construction and Building Materials.
Currently, rail-temperature reduction during summer relies almost entirely on water-spraying systems, which have significant limitations, including high installation costs and continuous water consumption. Therefore, a water-free, cost-effective alternative is strongly needed.
KRRI's technology lowers rail temperatures by attaching a special heat-blocking textile to the rail using magnetic force to block solar radiation. The "heat-blocking textile" features a multilayer structure composed of a special coating that reflects more than 85% of solar radiation, combined with magnets and fiberglass layers.
Once installed, the system requires no additional operating costs and poses no risk of failure, offering both stability and economic efficiency.
Field demonstrations were completed on the Gwangju Line of the conventional railway network in the summer of 2024 and on the Jungbu Inland High-Speed Line in the summer of 2025. The results verified a maximum rail-temperature reduction of 10.9°C, with no performance degradation observed after testing.
The technology was stably applied to both conventional and high-speed rail types, and certified testing confirmed outstanding durability, with performance maintained for more than 10 years.
KRRI also developed a fully integrated "all-in-one automated system" that covers the complete lifecycle from installation through retrieval of the thermal-blocking textile. The system enables all operations, from cleaning foreign substances off rail surfaces to applying the textile and retrieving it after the summer season, with a single piece of equipment.
Its modular design allows two operators to easily transport, assemble and disassemble it, and the system can operate at speeds exceeding 2 km per hour (1.2 miles per hour), significantly reducing both time and cost.
KRRI verified the safety and durability of the thermal-blocking textile technology. The system remained secure even under strong opposing winds generated by KTX trains traveling at 300 km/h (186 miles per hour). The magnetic attachment force was optimized to withstand wind speeds of up to 66 m/s (148 miles per hour), 1.5 times as strong as high-speed train-induced wind, and additional dual fastening mechanisms were added to ensure that the textile remains firmly attached even during high-speed train operation.
The technology's excellence was further recognized at the "2025 Seoul International Invention Exhibition (Dec. 3–6, 2025, COEX Hall C, Seoul)," hosted by the Korean Intellectual Property Office and the Korea Invention Promotion Association. The thermal-blocking textile patent won the Grand Prize, and the automated equipment patent received the Silver Prize.
Additionally, at the "2025 New Technology Commercialization Promotion Conference (Dec. 10, 2025, Peace & Park Convention, Seoul)," hosted by the National Institute of Standards and Technology (NIST) and the Korea Industrial Technology Association, the technology received National New Excellent Technology (NET, Ministry of Trade, Industry and Energy Certification No. 1594), further validating its innovation.
KRRI has finalized a technology transfer agreement with PITCHCABLE Co., Ltd. for the heat-blocking textile and its installation and retrieval technology, ensuring full linkage to commercialization and completing the research-to-application cycle.
This technology was developed as part of KRRI's in-house research program under the National Research Council of Science & Technology (NST).
Chief Researcher Kang Dong-hoon at KRRI stated, "This technology goes beyond simply lowering rail temperatures—it presents a new paradigm for protecting railway safety in the era of climate crisis. We plan to expand its application beyond railways to various fields that require heat mitigation, such as building exteriors and roadside facilities."
Sagong, president of KRRI, said, "This is a demand-driven research outcome that allows the public to use railways with confidence even during extreme summer heat. In an era where climate crisis directly translates into national risk, we will further advance this technology to ensure safe railway operations and expand its application to overseas markets."
Piccies fro the original link
