Class 93 Tri-mode Loco
AndrewE
9 Nov 2015
Judging from RTT the timing load is heaver going back to Seaforth from Mossend (1475 tonnes vs 1000 tonnes). I assume that makes the last few miles on the return to Seaforth easy (downhill iirc) but Shap and Beattock will be the test.
it was as good as the northbound train.
https://www.realtimetrains.co.uk/service/gb-nr:R32491/2026-02-11/detailed shows that it gained 4 minutes on the schedule Carstairs to Beattock summit and 7 Penrith to Shap summit.
(Why would the southbound train be heavier? Whisky going for export, or maybe a second portion added to this train?)
Wavertreelad
24 Feb 2013
Empty containers northbound. Bear in mind northbound movements would normally be for laden import containers, but if there are no ships there is no containers to move. Last weeks arrivals were all disrupted by weather delays so it's possible in these circumstances that they may have loaded empties especially if the shipping line(s) are short of empties in Scotland which is not unknown.
Geeves
6 Jan 2009
Rochdale
Certainly is an interesting working. As I understand it DB in Germany is selling its own locomotives and leasing them back so perhaps they are also looking at leasing here? A 93 would look good in red!
43096
23 Nov 2015
They are also selling locos and not leasing them back!
cj_1985
6 Mar 2010
Lanarkshire
AIUI that's more to do with reducing the overall debt from DB... sell the locos, get a lumpsum of cash back to pay against outstanding debt
Harlequinuk
15 May 2025
It does look as if they left on battery, added the diesel (hence the speed up) and when under the wires, went to electric
Other than the number of boxes, many containers heading back to Felixstowe / Soton / Gateway are loaded with scrap, which is rather heavier than most of the consumer goods they come in with.
BRX
20 Oct 2008
I didn't know scrap generally travelled in shipping containers...how do they get it in & out without making a big mess?
I wouldn’t say it’s the normal route for scrap exports, but it’s a cheap way of doing it, filling a box that would otherwisebe hewding back to China emoty. Just chuck it in, and close the doors. It doesn’t need to be full. Lots of plastic goes the same way, albeit that’s lighter, obviously.
Geeves
6 Jan 2009
Rochdale
It only seems to be a recent thing where someone must've been stood there scratching their head. Now they have hoist type thing that stands the container on its end so that the mechanical grab just drops it neatly in from the top. Before it's lowered to the ground and man goes up the top and closes the doors so it doesn't all fall again when it goes back to horizontal
Wavertreelad
24 Feb 2013
There are different types of scrap so the payload will vary slightly, but by and large scrap containers tend to weigh about 25mt, or 12.5 mt per teu which is heavier than consumer goods. However, it's very unlikely that the southbound containers carried any scrap because Liverpool does not currently have a regular direct service to China or other areas which are known to recycle scrap materials.
It depends on the type of scrap. Waste paper and card is generally baled, plastic scrap may also be baled or it may be in big one tonne bags in granular form. Non ferrous metals will almost certainly be either in drums or palletised. Scrap tyres will be loose. There are very strict regulations for shipments of scrap and the shipping lines demand sight of the paperwork at the time of booking, in addition containers may be subject to random inspection at the port of loading to check compliance.
Sadly it's not as simple as that, the movement of scrap or all types is highly controlled and as I mentioned earlier is subject to very strict regulation. It's also very competitive and I can assure readers that beneficial cargo owners (BC0) will switch volumes between carriers for US$25.00 difference in cost. Because of the competitive nature of the market BCOs like to ensure the occupancy of the container is fully utilised hence why most scrap is shipped in 40ft units with payloads of around 25t. How plastic scrap is shipped depends a little on it's source, but packaging scrap of the type used in supermarkets etc will likely be in highly compressed bales, whilst scrap plastic from the manufacture or windows and doors may be in granular form in bags which can mean payloads can reach 25t.
Most shipping lines no longer accept loose scrap in their containers because of the damage it causes to the container walls and wooden floor. It's an expensive operation reflooring a container and the freight revenue generally does not justify the cost or the repair and the lost revenue whilst the container is out of commission at destination. For these reasons these movements tend to be accomplished by one way shipper owned containers.
hwl
5 Feb 2012
Liverpool has two direct scrap loading terminals (EMR in Alexandra Dock and Norton in Canada Dock) which probably export around 1Mt per annum between them, ~10-15% of UK scrap steel exports (the majority to Turkey, Egypt and India) so as far as I understand it very little steel goes out from Liverpool by container most goes directly into the ship holds however the Aluminium content post fragmentation (hammer mill) and sorting does go into containers and out by road.
It will be very difficult for Port Talbot and potential Scunthorpe EAFs to get enough scrap volume unless some is diverted away from Liverpool exports.
EMR Liverpool also does lots of scrapping old containers for several container lines.
Agreed.
Wavertreelad
24 Feb 2013
Agreed.
Just to be clear, I'm well aware of the EMR and Norton facilities and whilst the latter has access to a rail connection the EMR site processes all it's output from scrap materials delivered by road. However neither site would likely take laden containers of scrap and reprocess it on site so it's very unlikely to answer the original point that the difference in the weight of the train was due to scrap materials in the containers.
As far as EMR scrapping old containers for several container lines, I would not disagree, but I suspect the majority of those containers sold off by the shipping companies in the UK go into the secondhand market were they can attain a higher price. That said there will always damaged containers beyond any sort of repair which will be disposed of for their scrap value, whilst entities like EMR may take limited numbers of short life certified containers for one way trips to smaller or niche markets that cannot support a bulk ship movement. The aluminium content like other none ferrous metals recycled from the fragmentation process will almost certainly be packed into drums or bags before export as the value per tonne of these commodities is considerably higher than the ferrous scrap with is the mainstay of the bulk ship movements.
Wavertreelad
24 Feb 2013
47286Dan
27 Dec 2018
Monday morning movement
93002 GROG WORKSP DY 260Q561C02 F CDON EMDC N
Dan
MikePJ
10 Dec 2015
Modern Railways March issue has a story about the Class 93 trial with DB Cargo.
Mark Sargeant, head of Operations at DBC is described as "impressed" with the 93, but later on an unnamed DBC source is quoted as saying that there are no immediate plans to use 93s and there's a direct quote "for the time being, the Class 66 remains the backbone of our fleet".
The optimistic read of this is that DBC like the idea but are still negotiating the price and conditions for 93s - whereas the pessimistic read is that they're not interested but were happy to help ROG find other customers through an easy press story.
pokemonsuper9
20 Dec 2022
Greater Manchester
Or maybe Stadler's sales team just got an email.
Northampton
Considering DB Cargo have a fleet of 150 or so Class 66s and there are a grand total of 10 Class 93s, I think it's somewhere close to your optimistic read, with the proviso that they need to understand the impact on their current resource plan (or how to generate the finance for a much bigger order).
HST125Scorton
4 Jun 2019
Atherton
93002 currently on 0Q72 08:54 Crewe South Yard to Wembley (due 12:38)
Heads back North later to DRS at Gresty Bridge. Not sure what ROG/DRS have in plan.
802020
4 Sep 2021
Somerset
0Q42 showing as cancelled on RTT
Peter Sarf
Croydon
Also two fly pasts of Wembley yard reveals no sign of a 93. RTT stops getting reports at Wembley central. It was running 65 early mainly by skipping the Northampton loop. Wonder where its gone ?.
Peter Sarf
Croydon
Apparently 93002 went to Euston instead. I worked out I could have got it at Euston as I dashed for the 12:09 to Harrow & W.
I returned to Euston at 12:27. Something flashed past as I got on.
93002 on a different 9Q42 from Euston
Passing Bletchley on down fast at time of posting
Thanks.
Rail Quest
8 Apr 2023
Warrington
47286Dan
27 Dec 2018
Wednesday morning movements
93003 GROG WORKSP DY 260Q451E04 F PETERBORO N
93009 GROG WORKSP DY 260Q451E04 F PETERBORO N
Dan
