Class 93 Tri-mode Loco
172007
2 Jan 2021
West Mids
Yes, I meant that its there in case the 93 fails, similar to how all of the 99 tests so far have had either a 66 or 69 tucked in behind.
Hence my question as to whwther a 93 can work in multiple with a 66. A 99 can so of the 99 fails then all beind well the 99 can still contine with the 66/69 powering.
99 is the same family as a 93.
4S48 Cancelled as per Realtime Trains
24 Oct 2015
It's just departed Daventry 1925.
cj_1985
6 Mar 2010
Lanarkshire
As far as I've seen from the 93s and 99 at the Greatest Gathering and at the Polmadie Open day... I don't believe the 93s have AAR compatab.... at least not to the point of having a visible socket
800001
24 Oct 2015
Made up 15 minutes by Carnforth Junction (now at +12) . Definitely got a wiggle on
Beat me to it.
Although it will be running at class 66 timings, so with the performance of a 93, it will be gliding up the Hills
Harlequinuk
15 May 2025
Tim Moran is posting a photo or 2 he took on social media.
edit: @ Milnthorpe, now at +9. Its flying along. Who ever the demo is for, might actually be impressed. Its hauling 20 x IKA with the DIT Cl66, makes it 1650tons or so
D1511
29 Jul 2023
WCML N
It's really gaining time now it's in the hilly section. I'll bet it's on time by Shap at this rate.
Harlequinuk
15 May 2025
Now at Tebay, at -3 early going up Shap
Now topped Shap and is 11 minutes early - did Tebay to Shap summit in 6 minutes. In the rain, hauling 1650 tons oO
D1511
29 Jul 2023
WCML N
I'll amend my previous estimate to 10 early at Shap!
Since it's had a clear run from Wigan, it's made up 27 minutes, and probably 30+ by Shap. To repeat myself, pretty astonishing.....
Edit: 33 mins made up by Shap!
Edit2: at the risk of stating the bleedin' obvious, the 66 timing Tebay to Shap is 14 minutes......this thing did it in 6 minutes towing the GM junk as well!
Class15
30 Dec 2021
North London or Mildmay line
The 93 beat the previous night’s 4S47 for Grayrigg to Shap timings, which had a pair of 90s at the helm as opposed to the single 93 and also did not have to drag a 66 along with the train, which the 93 had to do!
Peter Sarf
Croydon
Tebay yo Shap summit in 6 minutes, schedule allows 14 minutes.
How does that compare to a 90 or a pair of 86s ?.
@Class15 just saw your post !!!.
Harlequinuk
15 May 2025
Its the trickery for the computer controlled anti slip i bet - driver keeps the power in and the computer does the rest.
Holding -11 early at Long Ashes
D1511
29 Jul 2023
WCML N
I'm tempted to stay awake until Beattock, to see what it does there, as that's a steeper climb over a much longer 15 miles. I'll bet it flies up that 1:69 like it isn't there.......
popeter45
7 Dec 2019
london
-24 already at Kirkpatrick
if the 93 can do this with ease on 4.6kW, a class 99 will fly on 6.1Kw
Suraggu
23 Oct 2013
The Far North
Even on a class 66 timed load at 1600 tonnes, it managed Beattock Summit with ease. The weather in the Beattock area is rather wet shall we say as well.
Harlequinuk
15 May 2025
20 minutes to climb Beattock (timing is 31) , in horrible conditions. Ended at Mossend PD Sterling , -49 minutes early.
