Class 89 updates
43096
23 Nov 2015
The DVTs are LHCS mark 3s and I linked you to a photo which shows a DVT with 125mph on the data panel. Also, I have seen other mark 3 LHCS with 125mph on the data panel (although some are 110mph as you say). For example, Arriva Trains Wales mark 3 buffet 10249 is/was marked as 125mph, were this and other 125mph mark 3s converted from IC125 vehicles?
There's only been a small number of vehicles converted from HST to LHCS spec: RFMs 10200-211.
The real issue is braking. The secret of the HST is faster brake propagation from the E70/DW2 brake units in both power cars. The LHCS DVTs also had such a brake unit, but AFAIAA they generally ran with just the leading brake unit (E70 or DW3) controlling the train, partly because the locos were 110mph limited so it wasn't needed and partly for reliability as the rear brake control unit could be isolated and not suffer spurious activations if, for example the TDM de-configured.
Rhydgaled
25 Nov 2010
Thanks. Was 10249 retrofitted with better brakes then to allow uprating to 125mph? Or are the brakes on intermediate HST and LHCS coaches the same and the key thing is having the brake units at both ends to apply the brakes simultaneously from both ends (in which case 89 at one end and mark 3 DVT at the other could do the trick)?
43096
23 Nov 2015
I have a feeling that the LHCS brake force was adjusted (in the 1980s?) from 7%g to 9%g. I think the lower rating was when they were largely in mixed sets with Mark 1s and Mark 2s and may have been adjusted to 9%g when the 110mph workings started - I'm sure someone else will confirm.
Otherwise, they're the same brake wise and the key to 125mph with the 89 would be having a DVT at the other end and operational E70s/DW3s at both ends.
Mag_seven
1 Sep 2014
here to eternity
wikipedia isn't saying a lot, and it'd be amazing to at least see this on a charter run, any news at all about the possibility of the class 89 being allowed a run out to track or will it just remain static until it fades away or is scrapped?
Thread reopened to allow @ExRes to provide an update.
12LDA28C
14 Oct 2022
I saw LSL and ETL have put out an announcement that the parts required to return the 89 to operational status have finally been obtained and the loco will be moved shortly Loughborough for the work to be carried out. I believe the plan is to have it working charter trains with their Intercity rake, possibly as soon as next Summer.
popeter45
7 Dec 2019
london
would it be cleared to run on the WCML? would be cool to see pulling the friday charter if that runs again
12LDA28C
14 Oct 2022
I don't see why not, although I don't expect to see the 'friday charter' running again, circumstances at Avanti have changed since that train ran, indeed LSL cancelled the trains planned for November/December.
Also, given the huge interest in the loco, why would they run it on what was essentially a service train when then could charge more money by using the 89 on dedicated charter trains?
ExRes
16 Dec 2012
Back in Sussex
Thanks to @Mag_seven and @12LDA28C
It's suggested elsewhere that 89001 has been moved ready for road transport from Barrow Hill to Loughborough Brush, parts have been obtained and due to the amount of work being carried out at Barrow Hill the move to UKRail at Loughborough is being undertaken
Mainline equipment installation will be carried out as well as replacement of a faulty blower motor, overhaul of the cab aircon units and fitting of the repaired traction motors, static testing will be carried out before a move to Crewe for movement testing
7 Jul 2009
Talbot Green
What, Paddington to Cardiff without bothering with gauge clearance? :)
:rolleyes: You knew what I meant! :p
No point me going all the way to Padd, just to basically come home again
In fact, take the thought further, as it is being operated by LSL:
Class 47 hauled (89 on the back) Crewe-Cardiff with Passenger pickups at Shrewsbury/Hereford/Abergavenny, say 6am for 9am/9:30.
9:30/10am Cardiff to Padd (now 89 hauled) should be there for about 1pm
Whatever for runaround and able to reverse the route
ExRes
16 Dec 2012
Back in Sussex
Just a quick mention of 89001, there are numerous pictures on Class 60 Group facebook of the DCR locos awaiting their futures at Loughborough, 89001 appears airborne in a couple of the photos inside the shed so work is certainly ongoing
D365
29 Jun 2012
Just a quick mention of 89001, there are numerous pictures on Class 60 Group facebook of the DCR locos awaiting their futures at Loughborough...
OT, but I doubt it's quite that drastic.
D365
29 Jun 2012
Thanks @yorkie
@Trackman shared the following update yesterday:
28/02/2024:
With it being a few months since we last updated you on the restoration of Class 89 89001 ‘Avocet’ we thought it was time we broke silence with a small update to let you know how things are going.
As with any one of a kind locomotive that hasn’t run for over 20 years there have been some challenges faced big and small, but working alongside the Electric Traction Limited has been an absolute pleasure whilst overcoming these challenges.
89001 is still currently at UKRL’s Depot in Loughborough where the majority of the works has been completed with final testing the only large item left to complete on the long list of jobs.
The fitment of TPWS 4, Compliant Fire Suppression System & OTMR are now physically complete which is a huge step forward.
It was noticed during static testing in the workshop that the brake frame had a few pneumatic leaks which needed resolving so the brake frame was completely stripped and replacement O-rings sourced. These are sandwiched in between two large manifolds which make up the entire brake frame, this hasn’t been a small job and we can’t thank Electrical Traction Limited enough for all their hard work and dedication to the project. Light is finally at the end of the very long tunnel!
Whilst spanners were being turned in the workshop ETL’s Paul Steane & our own AC Locomotive Engineer Robert Fenner have had several meetings with Network Rail regarding the return to service of 89001.
As you can imagine this is a process that needs to be very thorough and treated with great respect to ensure all parties are satisfied. A plan has been put together and the relevant testing is soon to be started to get the ball rolling for mainline approval. This process isn’t a 5 minute job and will take some time to complete but we think we can all agree .. it will be worth the wait for the badger!
Stay tuned for the next update in a few months’ time …
Strathclyder
12 Jun 2013
Clydebank
Just in case anyone here hasn't seen this yet (I hadn't until it popped up in my YT sidebar 10 minutes ago lol), 89001 hit a major milestone when she took power on all 6 traction motors for the first time in preservation (the last time was in her GNER days?) during testing at Loughborough eariler this month:
Towers
30 Aug 2021
Excellent news, very exciting progress!
DarloRich
Fenny Stratford
If they get the 89 running I might have to abandon my principles and book on an LSL tour! That aside to see this machine resurrected is really incredible. I assume the skills required are pretty niche.
Rail Quest
8 Apr 2023
Warrington
Fantastic to hear! Hopefully we'll see it out on a test run soon. Perhaps a test run up the WCML, maybe to Carlisle?
12LDA28C
14 Oct 2022
I suspect it will be some time before a test run is made. Plenty more work on the loco to be done first.
Grumpy Git
13 Oct 2019
Strathclyder
12 Jun 2013
Clydebank
Badger in the wild alert!
Booked on 0Z38 1228 Brush - Crewe dragged by 37521.
Well out of my area so I can't reasonably go out for this, but I expect the likes of Flickr to be well-furnished with photos of this move over the coming days.
They've managed to get all 6 traction motors to take power in the past month or so, but that doesn't in any way indictate that she's ready for a mainline trial yet as you say, let alone being let loose on a charter. Plenty more still to be done.
