Class 88 UKDual & EuroDual
Bobcp
4 Apr 2016
Hinckley, Leicester
Forget Eemslift Nelli for a while, it is now heading south to the Ivory Coast! Eemslift Ellen is lying offshore at Alger port and I can now confirm the other 68 is indeed 68026, the steel coils blocking the view having been moved yesterday. Perhaps a ship will turn up next week, currently a huge bulk carrier is occupying the berth. I'll maybe be back there on Sunday.
Portuguese registered 'Christina', which has cranes, due Sagunto early morning on 25th. March.
Be interesting to see where it docks within the port.
Bobcp
4 Apr 2016
Hinckley, Leicester
Dutch registered 'Atlantic', with cranes, now docked at Sagunto.
I believe it is berthed in a position suitable for loading the locos.
Incidentally this is the vessel that delivered 68006/7 & 8 to Gladstone Dock, Liverpool and 68020,1 & 2 to Workington.
Bobcp
4 Apr 2016
Hinckley, Leicester
MV Atlantic now showing its destination as Workington on Marinetraffic.com
Sunbird24
26 Oct 2013
La Mont Ravana
MV Atlantic has now departed Sagunto.
Currently showing an ETA Workington of 13.00 hrs. on March 29th.
The timing coincides with high tide - ships can only berth at Workington a couple of hours either side of high tide, at other times the dock gates are closed to maintain water levels.
Bobcp
4 Apr 2016
Hinckley, Leicester
I note that late evening yesterday marinetraffic.com changed the scheduled ETA Workington from 13.00 hrs. to 19.00 hrs. on 29th. March.
59CosG95
18 Aug 2013
Beeston (Notts)
That tweet was 2 days too late when it was posted last Thursday, The 88 had been doing OLE tests since the Tuesday afternoon.
Ooops, my bad! :lol: Didn't see any mention of it here though, so I thought I'd toss my hat into the ring. However, WNXX has said that mainline testing is due to begin this week.
Sunbird24
26 Oct 2013
La Mont Ravana
Per RTT, 88002's test run to Crewe and back today has got as far as Preston and been cancelled (due to "unknown cause"). Was this (semi-)planned after 4 days of successful runs, or has it encountered an issue of some sort?
http://www.realtimetrains.co.uk/train/R00098/2017/03/31/advanced
This was always in the plan, from the driver's mouth on Thursday night the run would terminate at Preston. Return to Carlisle later but timing not known at the time.
Next week it starts loaded test runs with 1500 ton train of loaded ballast wagons, one loco, to Crewe and return only, initially.
TimboM
12 Apr 2016
Thanks for the info. Hopefully catch it on Monday on its first loaded run then :)
Sunbird24
26 Oct 2013
La Mont Ravana
rebmcr
15 Nov 2011
St Neots
TimboM
12 Apr 2016
Where is the 68 located in the consist? Behind the 88 to continue the run if it's taken off, or on the rear to pull it back?
Here it is on the return leg through Winsford - 68025 tucked in behind 88002 enjoying the ride.
https://youtu.be/Bi8LkL-G62s
There was an extra path available if they'd wanted/needed to take the 88 off at Crewe and run it back light engine (and the 68 return the ballast wagons), but this was cancelled as not required.
Provisional outbound times are here: http://www.realtimetrains.co.uk/train/R00474/2017/04/03/advanced
This weeks runs are for running in electric mode. Tests on diesel power are not planned yet. Load is 15 loaded ballast wagons plus a dead 68.
Return timings: http://www.realtimetrains.co.uk/train/R00475/2017/04/03/advanced
Thanks Sunbird24!
robbeale
14 Jan 2016
At Lowgill today.
sluf
15 Aug 2016
hi guys
anybody know what time it is expected to pass through preston on the return journey? - might nip out of work!
Can't work out from the link in an earlier post in this thread as WTT says 12.45 but RTT states 12.05 3/4
Pardon my ignorance guys but all this is new to me.
Anybody who can explain the difference would help greatly.
thanks for any help
sluf
15 Aug 2016
Oh thanks for that. Saves me nipping out of work and standing on station for an hour.
once again thanks for your prompt reply - much appreciated ac6000cw
