Class 810 for East Midlands Railway Construction/Introduction Updates
liamf656
2 Aug 2020
Derby
thanks - useful reminder. Can you recall how many seats were on an EMR HST by any chance (before they started shortening them in the final period)?
I can't remember the direct answer, but also remember the 360s helped replace the HSTs through cascade so if we compare the capacity of 222/HST vs 810/360 we have to include all fleets (not saying that's why you're asking but others may not understand fully)
I think they should have just ordered enough to run the vast majority as tens.
Maybe, but that's precious wasted space with two extra cab cars in the middle of the consist (the vehicles already needed to be shorter to cram into St Pancras). In the UK units are rarely strengthened according to sudden demand so I think he we need to assess whether buying so *many* 5 car units serves any purpose other than satisfying the bean counters.
In standard class there are still more seats in an 810 than that of a 7 car 222.
That isn't correct. Given the 7 cars have a declassified first class vehicle, a 7 car 222 has more standard seats.
YorksLad12
5 Feb 2020
RTT is showing slightly extended dwell times at Long Eaton, Loughborough and Leicester, losing a total of about 6 minutes. I wonder what the reason is? Staff being extra careful about the dispatch and door operation process due to lack of familiarity?
To let passengers off to use the station toilets?!
But more seriously…phew. Glad to see (read about) one finally running in passenger service. Just in time for a C6 overhaul ‍
dosxuk
2 Jan 2011
It's not that long ago that this service would have been a 8 car HST set, with even more seats :'(
43074
10 Oct 2012
No they don't, there is no declassified First on the 7-cars. Some of the 5-car sets do where they were reformed from 4 or 7 car sets but an 810 has around 10 more standard seats than a 7 car 222.
liamf656
2 Aug 2020
Derby
None of the 7 car 222s have declassified areas unless decided by traincrew
You're thinking of the reformed sets (222005/6 and 103/104) which do have declassified areas to match the capacity of a regular 5 car
Edit: beaten to it!!
Whoops, you are right. I stand corrected!
Spartacus
25 Aug 2009
Then you'd have to reduce the service as you wouldn't be able to double up at St Pancras any more.
It's almost like 5 car trains are not suitable for Intercity trains travelling into our capital city. Who'd have thought it?
It's the relatively short platforms, and there only being a pathetic 4 of them, at St Pancras that's the problem. Build more and they can run longer trains, as they are they need to double up.
43102EMR
28 Mar 2021
The 7 car 222s don’t have a declassified first class vehicle. All 3 are active first class
NSEWonderer
5 Dec 2020
Social media post with photos of today's first run
Didn't expect them to run this early, the special engineer for the toilet must have worked some magic on that unit.
43102EMR
28 Mar 2021
They should have at least ordered more to allow most services to be 10 car. Or at least a like-for-like replacement with the 7 car 222s for some of the sets, it’s clearly obvious 33 5 car sets were not enough. Weren’t EMR even planning on retaining the 180s at one stage as they admitted the amount of 810s ordered was insufficient?
Even then, the 810s stepped away from the base 80X design in part to accommodate the shorter STP platforms to allow 10 car trains to fit.
Trainman40083
29 Jan 2024
Derby
And one platform almost exclusively used by the 360s on the Corby. Then we have the times when Thameslink has to use the main station... And the days when both the Sheffield and the Nottingham trains have to use the same platform.
WesternLancer
12 Apr 2019
For completeness here are EMT 222 and HST seats:
810/5: 54 first, 247 standard
810/10: 108 first, 494 standard
HST 2+8: 109 first, 359 standard
HST 2+6: 65 first, 252 standard
222/10: 100 first, 380 standard
222/9: 83 first, 338 standard
222/7: 106 first, 236 standard
222/5: 50 first, 190 standard
222/4: 33 first, 148 standard
many thanks!
fair point too
InTheEastMids
31 Jan 2016
And even doing that neglects fleet utilisation, which I recall posts here saying was pretty poor when the fleet was more diverse. Didn't a number of the HST fleet sit at Cricklewood all day. And wasn't there also a very long turnaround at Nottingham that effectively soaked up one diagram?
Probably best to look at peak-time seats into/out of the 4 key destinations to get a good feel about what's changed.
Spartacus
25 Aug 2009
Tell me about it. The rebuild of St Pancras is a great example of how not to do it, at least if you don't want to hobble the entire service forever more.
ChrisC
7 Oct 2018
Nottinghamshire
They’ve got far more capacity than most Meridians and it’s also a first run in service, so it’ll be full to the brim with enthusiasts and railway press.
They do have far more capacity than the trains they are replacing and I agree about today’s train being full of enthusiasts and railway press. However, many of the journeys currently being operated by the 5 carriage 222’s are full and standing and some, especially at weekends, are absolutely rammed. The extra seating capacity on these busy trains will allow some of the standing passengers to sit down but I’m not sure that a 5 carriage 810 will be enough.
liamf656
2 Aug 2020
Derby
Yes that was pretty much the case for both of those points
Trainman40083
29 Jan 2024
Derby
Maybe the plan was for HS2 to take some of the load. Now they seem to talk of enhanced Euro services, so fat chance of more EMR services unless you build out over the road or go deep underneath.
duffield
31 Jul 2013
East Midlands
Toilet related question: On the 222's the non-accessible toilets have manual sliding doors with manual locks. Is that the same on the 810s?
Also, a question for anyone who's covered the Leicester to Market Harborough section today, what's the noise difference like when the diesels start/stop?
liamf656
2 Aug 2020
Derby
Just a heads up for those wanting a ride on the 810, EMR services may get busy as LNER tickets are now being accepted due to a fatality
Banham7
12 Aug 2020
Lincolnshire
Will be interesting to see how it will cope with ECML pax as well on the 17.05 to Nottingham if the incident isn't resolved by then.
