Class 800 overshot Chippenham station (29/09)
Boilinthebag
12 Jul 2022
GWR
It might be worth referring to SS2 and the definitions of shunting/wrong direction movements for this (could be one or both for this) This type of movement involves rules in SS2/TW7 and TW1 possibly.
Horizon22
Jobs & Careers
8 Sep 2019
Yes and this is not one of those circumstances.
I should know because I have reversed a train before for a considerable distance, in one of those permitted circumstances.
I thought that reversing a train after an overshoot was TOC-dependent? I know some that are “forward-only” & others that will allow it. The rule book evidently allows it.
43066
24 Nov 2019
You would like to know that reversing is allowed by the Rulebook under certain circumstances .
Even if it was not one of them, unlikely driver would be sacked .
Meeting ( perhaps more than one ) with managers(s) without tea and biscuits , yes , but sacking very unlikely .
For driving a train backwards in a situation not permitted? That’s going to be treated very seriously.
Setting back - as distinct from reversing - is dependent on the signaller allowing you to do it, and very much involves changing ends.
Llanigraham
23 Mar 2013
Powys
In a multiple unit the driver is required to change ends. You're thinking of the rule regarding the maximum distance a driver may be permitted by the signaller to return to the platform after over-running a station.
That is permitted in the rule book, a maximum distance of 400m.
But isn't that exactly what happened in this case?
Therefore what was done was perfectly correct.
TurboMan
5 Apr 2022
It's not TOC dependent, it's rolling stock dependent. TW7 says:
If you are authorised to make a wrong-direction movement, you must drive the train from the cab at the leading end of the movement, if there is one.
If there is no cab at the leading end of the movement, you can drive from another cab as long as a competent person is available to control the movement.
Horizon22
Jobs & Careers
8 Sep 2019
Yes I was discussing setting back here, not reversing. Of course in this discussion, some were not aware of the technical language involved and were presuming one and the same.
I think however that even if it is dependent and physically allowed, some TOCs disallow it regardless and as states have a “forward only” policy and would not allow setting back.
fishwomp
5 Jan 2020
milton keynes
I’d be very surprised if it was as simple as ‘forgetting’, given every GWR service in the Up direction is currently booked to call.
I was wondering who was crewing the Oxford-Bristol services: is it Bristol based crew that have just learnt the route to Oxford, or Oxford crew that have just learnt it to Bristol. I was wondering having seen a few workings of Oxford-Didcot as ECS over summer - rather than because of this incident.
High Dyke
1 Jan 2013
Yellabelly Country
I must say, it's been fun seeing the various comments here. Those that know where to find the information can do so, if they choose. Suffice to say an station incident occurred and the matter was dealt with by the TOC and signaller/control as appropriate.
As an aside, if you are overcharged when grocery shopping, do you ever wonder what happens to the cashier after you've had the matter rectified and you have left the store? I don't!
Wilts Wanderer
21 Nov 2016
For all we know, they’re changing crews at Swindon.
12LDA28C
14 Oct 2022
Indeed, it seems so. I was merely trying to reference the significance of the 400m measurement which was being referred to in relation to something else.
OscarH
15 Sep 2020
Crawley
If they overcharge then I'd assume a handshake
If they underchange on the other hand...
(this should be read with the appropriate amount of sarcasm)
Sly Old Fox
21 Jul 2008
England
Or neither.
Class45
7 May 2011
There's probably a cash register enthusiasts forum on the web somewhere where they discuss such things in minute detail:lol:
Merle Haggard
20 Oct 2019
Northampton
When I worked on the railway (I'm long retired) this interest did puzzle me.
I think the answer is that the railway's production line is visible to the general public, unlike almost every other industry (buses are similar to railways, though).
I'm sure that, if the public could watch the production line at a baked beans canning factory there would be just as many questions/criticisms/suggestions about the faults of the process and personnel. But they can't...
InkyScrolls
20 Jul 2022
North of England
To clear up some misconceptions (and I am actually a driver, so I do know what I'm talking about!):-
  • This incident could be either driver error or due to poor adhesion, there's no certain evidence either way
  • Following an over-run a train may make a wrong direction move back to the station with permission from the signalman, but not if more than 440 yds (400 m)
  • The driver will most definitely NOT have 'reversed' but will have changed ends and driven from what had been the rear
  • For movements where the train is being driven from other than the leading cab, the movement must be controlled by someone competent in the traction and the route, i.e. another driver acting as shunter
  • There is NO chance that the conductor was acting as the driver's eyes - this would result in sacking for both of them
  • Some companies (including Northern) make a distinction between 'driving from other than the leading cab' and 'propelling', but the distinction is not relevant here
Surreytraveller
21 Oct 2009
I was wondering how prevalent 'propelling' is these days. Obviously freight going into yards, but with shunters present, but are there any instances of passenger stock, either ECS or otherwise?
sh24
28 Sep 2023
Night Riviera at Penzance ?
InkyScrolls
20 Jul 2022
North of England
It's pretty rare. One example is if the driving controls are defective in the leading cab of a MU, and you need to clear the line.
Tester
5 Jul 2020
Watford
As Sir Peter Parker (ex British Railways Board chairman) once famously said, 'On the railway, every day is an Open Day'.
Towers
30 Aug 2021
It’s exactly the same reason that production companies make and viewers watch things like Air Crash Investigation; people find process and procedure interesting, and there is curiosity as the cause when it goes wrong. It isn’t morbid or intrusive, it’s just human nature!
I’ve never really understood why some folk on this forum get so upset about it, it’s perfectly understandable for a discussion to happen when an operating incident has very obviously happened!
357
12 Nov 2018
I understand the ones that get irritated at the automatic accusations against the driver or staff involved.
I have no time for the "Rail UK Accident Investigation Branch" or the Soviet-esque "No discussion is permitted until the report is published" brigades.
12LDA28C
14 Oct 2022
Propelling movements of (empty) passenger stock take place regularly on maintenance depots up and down the country.
43066
24 Nov 2019
The “Strood Shunt” where a train is driven backwards from the London end cab, so that the driver can bring it back into the platform once it’s cleared the ground signal, with a guard in the country end to observe the starting signal. This was/is done because there’s no way to change ends on non gangwayed stock.
Less common now AIUI given that that 375s are in use on the route.
