Class 717 at Farringdon
purple-Azumas
1 Jul 2022
St Albans
Annoyingly was on the wrong platform so couldn't see the departure boards ...
Yesterday (22/2) at about 15:44 (might have been a couple of mins before) I saw a Great Northern Class 717 (unit 717014) pass through Farringdon. I'm pretty sure it stopped, picked up/dopped off passengers and carried on, though must admit I only looked up as I saw it leaving.
I can't seem to find any service on RTT which it could be, and it's never something I've seen in the TL core before. Not very knowledgeable at all on route/traction knowledge required to operate a service, but can't see why GTR would train drivers on this traction through the core as surely there's plentiful 700s to operate all TL services.
Would this be a regularly working, or is it a one-off? What reason would there be to operate such a unit in this way? Is there any specific/different training that would be required if it was a TL driver in a 'GN' unit? And finally, would/could ATO have been enabled on this train? I'm assuming the answer to the last one is a no!
Apologies is this should go in 'Allocation, Diagrams and Timetables' - I'm more interested in the 'why' rather than the 'what service' so decided it was best placed here.
Thanks in advance for the help! :D
3973EXL
2 Feb 2017
Peter0124
20 Nov 2016
Likely a one off.
It also looks like it (or a different unit) returned back north to Hornsey that night. No idea why it ran.
Quite a lot of rare activity in the core yesterday going by this. I believe 5E88/5O88 were 387s if someone can confirm that?
class717
23 Oct 2019
It was moved to go to the lathe at TB, Hornsey lathe is being rebuilt
Fenchurch SP
11 Jan 2021
Merstham
It was going to Three Bridges for maintenance reasons (Don't know what specifically)
class717
23 Oct 2019
I wouldn’t be surprised if there are more moves like this, Hornsey Lathe is out until May 2023. Yes there is different training for 717s and 700s. There is no ATO facility on the 717s, so no, although there is the same auto traction changeover system as on 700s.
Peter0124
20 Nov 2016
On a side note, does anyone know why 387s have been running empty through the core quite often in the last few months? I have always wondered why but never found an answer.
class717
23 Oct 2019
I would assume it’s for the same reason, to use lathe at Selhurst
purple-Azumas
1 Jul 2022
St Albans
Likely a one off.
Thanks all! Serves me right for not looking properly!
16 Oct 2021
Uk
Is it even possible for anything that's not a 700 to run through the core? Considering the ATO.
Class455
19 May 2016
I saw 717004 passing Norwood Junction last night, took me by surprise at first but then realised it was returning from the lathe at Three Bridges
Northampton
It's possible, and one of the reasons why the Conventional Signalling was left in under the ETCS L2 Overlay, although it obviously impacts on capacity if non-ETCS trains are using the core, hence why they tend to do it outside of peak hours.
Doomotron
25 Jun 2018
Kent
You say it might have picked up passengers... Are you sure? I'd expect not but it could be an interesting situation if it did.
william.martin
18 Oct 2022
Telford
It shows that it was booked to stop there on RTT so maybe it could of been to do with train crew or pathing.
For the thread owners attention: Did you witness the doors open?
Stephen42
6 Aug 2020
Suspect it's that the train stopping at Farringdon to lower pantograph and then departing can look similar to a passenger stop if on the opposite platform and focusing elsewhere. As it's a rare move the driver might have to switch manually so would be stationary roughly the usual amount of time.
Doomotron
25 Jun 2018
Kent
Aren't 717s limited to 30 on third rail? The journey to Three Bridges must have taken a while!
purple-Azumas
1 Jul 2022
St Albans
Yep, think that's right. I was looking down and then looked up and saw it. Wasn't moving and didn't leave instantly so just assumed that it was picking up/setting down. Certainly looks like that wasn't the case.
OscarH
15 Sep 2020
Crawley
Would the 717 have run using the ETCS in-cab given they support it, or would it have just been using the overlay signals
315801
12 Jul 2022
As far as I know any trains which run on the moorgate service are automatically limited to 30 mph in the tunnels, this strict speed limit was introduced after the horrific accident at moorgate involving 1938 stock.
class717
23 Oct 2019
It would have been using signals. There aren’t many drivers trained on ETCS on the 717s.
notverydeep
9 Feb 2014
387s have definitely ran through. Not in passenger service though.
I have ridden on all of the first 29 of the 387/1 sub-class through the Thameslink core in passenger service!
To be fair, it was a while ago now though and I have since ridden on the same 29 units on Great Northern...
AlexanderC
12 Aug 2020
Ely
Quite a few 387s have been having the interior refurbishment at Selhurst which is why they go through the core. I know at least 4-6 have already been done.
AlexanderC
12 Aug 2020
Ely
If you’re talking about the whole project then 100s still. I have no idea about the 387s.
Fincra5
6 Jun 2009
Yes... 387s do it regularly atm, partly for the Selhurst Lathe or Arura Modifications.
717s are cleared through and might need to use the Lathe at Three Brides, as Hornsey is still O.O.U... The 30mph Limiter can be disabled for this sort of move.
pc3087L
Horsham
Yes... 387s do it regularly atm, partly for the Selhurst Lathe or Arura Modifications. 717s are cleared through and might need to use the Lathe at Three Brides, as Hornsey is still O.O.U... The 30mph Limiter can be disabled for this sort of move.
717007 at Farringdon today.
Presumably this working
And thanks for the explanations upthread about the why’s & how’s. Quite a surprise
