Class 707 - SWT: Introduction into service
Feathers44
12 Aug 2014
The 707's are perfect for the 8 car limited Orpington-Vic & Dartford-Vic routes. These are crush loaded in the peak and need sorting- the infrastructure would require massive rebuilding (e.g Brixton) to allow even 10 coach 376/Networker operation which won't happen for years. This is a quick fix.
Sorry, I don't understand. You're proposing replacing 8 cars with 5 (since 10 won't fit)? What am I missing?
class387
9 Oct 2015
Could the 707s be reformed into 4 and 6 car trains so they can be used in 6, 8, 10 and 12 car formations on the Southeastern?
The 458s would make good 455 replacements on Southern as they already run in multiples of 5 with the newer Electrostars.
EDIT: Suggestion amended, see post #1150
Fincra5
6 Jun 2009
So would the 707s by that logic. 707's would be better for metro than the 377s/455s.
ScotGG
3 Apr 2013
Agree that line is packed and badly needs more capacity. 707s would be great if if 4-car doubled up but they're 5-car. How easy is it to now make 4 car? And more money wasted.
They only have the two motored end coaches, previous discussions about this (it has been brought up a few times) have suggested that the potential 6 car version would need more motor bogies added. So it sounds as though it isn't something that could be done quickly.
class387
9 Oct 2015
In that case, following on from my suggestion, would it be more suitable to keep the 707s as is (sending them to Southern), and then have the 458s converted to 4s (formed M-T-T-M) and 6s (formed M-T-T-M-T-M) and send those to Southeastern instead?
WWTownEnth
21 Mar 2014
Sorry if this has been discussed somewhere above but is it still than plan to use all 30 707 units on the Windsor lines until the new trains arrive in 2019?
We just don't know. As I posted yesterday, Roger Ford (of Modern Railways) is being quoted as saying in another mag, Rail Business Intelligence, that they will not enter service in the southwestern area at all.
Confirmation eagerly awaited.
pompeyfan
24 Jan 2012
Not seen this path before, running at the moment is 5Q80 Wimbledon - Bournemouth depot about 20 minutes late through Fleet, formed of 10/707.
Monty
12 Jun 2012
707s are running to Petersfield in the morning and Bournemouth in the afternoon due to Royal Ascot this week on the Reading road.
Eastleigh about 1540 this afternoon. For the avoidance of doubt, this is not meant to imply the start of servics to Bournemouth, maintenance at Bournemouth, or use by Alliance Rail on Southampton services... :D
pompeyfan
24 Jan 2012
What about the 458s, will they do any of the above? ;)
bgstrowger
20 Mar 2011
Whitstable
The Desiro city platform is supposed to be modular isn't it, so could an additional order of trailer cars be put in to make the Class 707s 6 cars?
Much better fit for the Southeastern suburban services I would've thought.
Roast Veg
28 Oct 2016
The 707s do not have enough motored bogies to make another trailer viable, as shown in the specifications upthread compared to other stock. A new motored car would work, but then there's the question of whether 6 cars is right for SE, which it probably isn't.
bgstrowger
20 Mar 2011
Whitstable
I'd have thought that 6-cars would be quite right for SE suburban services if the infrastructure is now based around 12-car working.
How many motored vehicles does a 12-car Class 700 have out of interest?
hwl
5 Feb 2012
6 with 50% powered axles overall. But the 707s also have smaller motors compared to the 700s and just 40% powered axles too and worse power to weight than a networker...
Bombardier Aventra have more motor cars but similar number of powered axles.
E.g. 345s 9 car with 8 motor cars but 20 of 36 axles powered.
D365
29 Jun 2012
Depends on sidings and depot road lengths as they might only be set up for four car units.
hwl
5 Feb 2012
Shouldn't be an issue unless you want to go all 6 car at the same time which is unlikely.
spark001uk
20 Aug 2010
I read somewhere that FMTR don't want trains with no toilets, so that justifies one reason for them wanting to ditch the 707s (unless they get the toilets retro fitted), and I also assume that means the 458s will get the push too, as the majority of those may as well have no toilets.
