Class 701 'Aventra' trains for South Western Railway: progress updates
Domh245
6 Apr 2013
nowhere
Is ABDO intended for just door release, rather than automatic opening? That does seem the more sensible way of doing it.
Given the main benefit of ABDO is shortening dwell times, I'd be surprised they didn't go full release and open á la 700s in the Thameslink Core
spark001uk
20 Aug 2010
I doubt the time it takes pax to press a button on release is going to alter dwell time, in my experience most of them are hammering away at them almost before it grinds to a halt.! All I can see every door open doing is letting a shedload more heat/cool out.
Also wasn't the TL core auto doors more to do with the fact there (were) so many people to board/alight in such a short time in that section, in the planned 24 tph schedule?
Goldfish62
14 Feb 2010
London Underground removed door buttons to reduce dwell times and they're the masters of managing dwell times.
I think your second paragraph contradicts the first. You initially seem to be saying that removing door opening from passengers won't reduce dwell time then go on to explain exactly why it can reduce dwell time.
hwl
5 Feb 2012
Agreed, dwell time Earlsfield, Clapham Jn and especially Vauxhall is as important as Thameslink core as Vauxhall dwell time is effectively the main limitation on the entire service structure.
spark001uk
20 Aug 2010
Perhaps I should have been a little clearer, I agree it could help where boarding a huge number of pax at once in very frequent traffic is critical, but where services (and passenger numbers) are less intense, not so much so.
Domh245
6 Apr 2013
nowhere
Which given that ABDO is planned for Surbiton/Richmond - Waterloo is exactly that. The question really is if ABDO will be constantly operational or just during the peaks - if it is constantly operational then I expect that the ABDO will just initiate door release and then the train will either automatically open all doors on release or not dependant on time of day/direction
Val3ntine
29 Apr 2015
The irony of this is that the system is not connected to the signalling I believe, so if a driver is on a restriction they are not to accept ABDO as the train will not recognise a Red signal to slow down or stop for so will SPAD. Of course during the peaks more trains will mean more restrictive signalling so may even be a case ABDO is used more outside of the peaks.
Domh245
6 Apr 2013
nowhere
That's interesting. I would have thought that ABDO would not 'initiate' until essentially within the same signal block of the platform, particularly if the idea is to hit a (near to!) maximum braking curve. Surely it doesn't matter if the platform's starter is at danger when the train is going to come to a stop short of it
Val3ntine
29 Apr 2015
Yeah that makes sense! I don’t think anyone actually knows yet how exactly it would work, I do remember seeing/hearing something about not accepting it on a restriction. But regardless even if it’s a platform starter that is on red, a SPAD would still be down to the driver say during rain/leaf fall.
Pete_uk
28 Jan 2017
Stroud, Glos
Would it not be easier for the driver to press a button that releases and opens all the doors on one side when the train has stopped?
theironroad
21 Nov 2014
I'll take that, it beats the zero of the 455s/707s (and frequently oou on 458s).
While having toilets is undoubtedly a good thing for passengers, I hope the working of these new toilets isn't a step backwards. While the biodigester system is great for keeping toilets in use, how will the cleansed waste water be disposed of?
If the system is designed to only dispense the water to ballast when stationary and not at places like waterloo, then that would be good.
Dispensing the water while the train is at speed goes back to the days of track workers, s&t etc all being potentially showered . While they will be happy it's not sewage, I'm sure they don't really want to go back to being sprayed either.
supervc-10
4 Mar 2012
One thing that could help with dwell times, but without letting in unnecessary cold/hot air, is the system on the Manchester MetroLink where the door opening button can be pressed before the train comes to a halt. If ABDO is used like the automatic control on the ThamesLink core, then the doors could open immediately on unlocking by the ABDO system, rather than immediate activation of the buttons.
TRAX
2 Dec 2015
France
Meanwhile in some countries train doors are released automatically...
On trains with air conditioning, opening up the doors at every station for a cold / warm blast of air to come in is not necessarily a good thing.
That’s presumably why people thought it wasn’t a good idea on S stock, yet it seems to have turned out they’re fine. and they have far more door area per car length...
spark001uk
20 Aug 2010
Also I imagine they'll probably have a door timeout like most current stock, so shouldn't be too bad at longer stops.
DennisM
3 Apr 2016
+ 1 toilet in the shorter unit is very disappointing
Has the number of toilets per unit been confirmed somewhere then?
I think having the doors opening automatically for part of the route and not the rest just adds confusion, most customers are using the service regularly and are all used to pressing a button to open the doors. Also using automatic opening at non ABDO stations would mean should a driver stop short, any doors off the platform would be opening onto the track and seriously increasing the risk of passenger injuries.
fgwrich
15 Apr 2009
Hampshire
1 Toilet per 5 car and 2 Toilets per 10 car.
hwl
5 Feb 2012
Thameslink users adapted quickly enough
No they wouldn't as ASDO (automatic selective door operation) and CSDE (correct side door enabling) will sort that at all stations. ABDO is additional functionality to this for inner stations.
The 458s were retrofitted with ASDO, 707s came with ASDO. As a comparison the only stock at GTR without ASDO are the 313s 365 and 455s, everything newer has it there, SWT/SWR are a bit behind the curve.
Might I suggest researching ASDO before scaremongering?
spark001uk
20 Aug 2010
No it wouldn't, ASDO will prevent that.
I must say I'm somewhat surprised you know about ABDO but not ASDO.
DorkingMain
25 Aug 2020
London, UK
They also spend a significant amount of their time operating in underground tunnels, which is the same reason it's not a problem on the Thameslink core.
The ASDO technology that SWR uses on 444/450/707 will release the same number of doors no matter where the train stops.
spark001uk
20 Aug 2010
Yes, but we're talking about 701s. The ABDO will have to be happy a correct stop has been made before releasing doors.
Also on any classes where these out of course scenarios don't prevent door release, it is the responsibility of the driver/guard not to release doors until the train is in the correct position.
DorkingMain
25 Aug 2020
London, UK
Right, but that's not ASDO preventing it, that's ABDO preventing it. ASDO is nothing to do with stopping an out of course release, it's meant for short platforms.
hwl
5 Feb 2012
It depends what ASDO system you have...
There is ASDO and ASDO!
spark001uk
20 Aug 2010
OK I think the answer to the basic point that's been raised here is that safety is key, no doors are going to open onto the track, nobody's going to fall out.
What I'm keen to know is, will ABDO rely on information from the ASDO system regarding platforms, or is it totally separate, requiring new beacons to be installed?
hwl
5 Feb 2012
The aim is for new rolling stock ASDO systems to use ETCS balises (as ABDO would) and ASDO on Thameslink has. The question is where they would try to use the existing Tracklink3 ASDO balises outside the ABDO area or just place some new ETCS balises (no external power) at every platform as needed?
