Class 701 'Aventra' trains for South Western Railway: progress updates
norbitonflyer
24 Mar 2020
SW London
Nice to finally get a daytime Chessington South service. Up to now we've been stuck with the last service only, which is effectively a way of moving a train into Wimbledon Park Depot.
I hadn't actually realised any had got there yet. Diagram 6 started on 28th April, so if that diagram was worked in full, that would presumably have been the first working on that branch?
bb21
Emeritus Moderator
4 Feb 2010
We must be near the point where 701 diagrams outnumber 455 diagrams....
Very close. From this morning it is 15 vs 33, but obviously the latter run in pairs. Next week with more of the former appearing that would flip the balance. Afternoons see more 455s running.
The favourite railway game of finding someone else to blame does not apply in this case. The buck stops with SWR.
Not everyone is out to find excuses. I will leave it at that.
Stephen42
6 Aug 2020
That new diagram usually works a Hampton Court return journey (which is cancelled due to summer timetable) instead of Chessington South so possibly might change back in September.
Did Diagram 6 start before the timetable change? It was definitely in place since the timetable change (aside from 2O01), would have thought the first working on that branch would be the same as Hampton Court/Guildford as also visited by that diagram. Dorking was earlier as the 701 Surbiton starter switched to work Dorking then empty to depot with the alternative stock for the Surbiton starter taking over the rest of the diagram.
Meglos
19 Dec 2020
london
I stayed out late on the first day of the timetable change, and travelled on the 2M71 / 2M96 (albeit only Chessington North to Chessington South and return) . SWR were actually out taking photo's of the first 701 arrival at Chessington South. Can't honestly remember which unit it was, as I'd already travelled on it elsewhere.
TEW
16 May 2008
It may well switch to the Hampton Court then but hopefully by that point they will be on more Chessington diagrams. The end of the diagram is also an alteration, but I don't believe that is related to the Summer timetable.
mansonlo49
11 Dec 2023
uk
May I ask please, is it covered previously when’ll the 701s operate on the mainline, to Guildford, or the Woking stopper, thanks
norbitonflyer
24 Mar 2020
SW London
I have Diagram 6 (that starts 2O01/1D05) running with a 701 from 28th April, but don't know if it ran the full diagram that day or indeed any day before the timetable change.
If the first to Chessington was on the day of the timetable change (actually the second as there was only a Shepperton and Windsor diagram on Sunday 18th May) the unit would have been 701034
Nice to see a tipping point has/is being reached on the 701 rollout.
Bessie
30 Oct 2017
701s better acceleration is really obvious on Reading services. On the 9:20 service from Waterloo last night and at most stations we had a much longer dwell time as service arrived early at each station.
Peter Mugridge
8 Apr 2010
Oakham
I've just seen 701 002 testing at Waterloo; only the driver on board so unlikely to be crew training - is this unit likely to be in service soon, I wonder?
GW43125
8 Dec 2014
I hope so as if #14244 is to be believed, I make that 17 diagrams from 17 units...
bb21
Emeritus Moderator
4 Feb 2010
002 has just joined pre service inspection so not going to be in passenger service for a while yet.
There are already seven others which are ahead in the process of getting approved for passengers service so it will likely be one of those if another one is passed out in the next few days.
GW43125
8 Dec 2014
Hearing 701017 has got a bit toasty at Winnersh Triangle on 2C46...
800001
24 Oct 2015
Elaborate?
Service has moved ecs from there to somewhere and services now arriving/departing Reading on time.
davews
24 Apr 2021
Bracknell
Await more details..... I arrived back at Reading on the Elizabeth line at 1438 and saw 701017 about to leave. Went for lunch at the Spoons in town and when I came back found everything stopped with two stacked Gatwick trains and the 1609 I intended to catch cancelled. Not much in way of announcements at the station but found out from RTT what had happened. When I got to Wokingham it said trains delayed due to 'a fire on a train'. Delayed 30 minutes in the end though as you say everything now seems to be running on time.
Goldfish62
14 Feb 2010
Yes, I caught the 1809 from Reading, 701012, and all was running fine.
I see on the 1950 from Waterloo, which should have been 017, 035 was substituted instead.
26 Jun 2019
I believe the fire brigade were called, and the 3rd rail was switched off too. The latter caused 2C39 to be stuck at Early for 50 minutes.
Towers
30 Aug 2021
Indeed, the third rail would have to be isolated if the fire service were in attendance, quite understandably they won’t go trackside otherwise.
Class455
19 May 2016
Well you're in luck! The Reading 455 diagram this week is booked 8-450 next week.
Wonder if the SO 455 diagram will still be in operation tomorrow? It ran last week but the week before it was subbed for an 8 car 458
swr444
26 Aug 2008
Given that it berths at Reading overnight off 2C81, it likely will still be a 455. Today, 455s 738 and 911 are on the diagram that should do 2C81, meaning they will start on 2C12 tomorrow.
yup, still a 455 tomorrow. Just had a look at the diagrams
bb21
Emeritus Moderator
4 Feb 2010
058 should be the next unit to enter service next week
NSEWonderer
5 Dec 2020
Leaves 005, 021 and 057 out of the last grouping to roll a dice on which is next after 058(Ignoring the other recent additions to the pre service inspection / training units). Good stuff
Bikeman78
26 Apr 2018
701017 is back in service today. They seem to be short of 701s though. 5860 did 0800 Shepperton to Waterloo then off to Wimbledon Park. 701039 did the 0850 Reading off 2J92 from Surbiton. It departed from platform 5 at Waterloo. Some rare crossing moves there!
