Tin Rocket
What are the arguments in favour of class 66's and 60's and the arguments against the use of 66's and 60's by TOCs/freight operators?
60s are expensive to maintain and unreliable in comparison to 66s.
It is also worth noting that the number of 60s we have in traffic now (14) is the number of diagrams that ACTUALLY NEED the superior pulling power of a 60 rather than are a 60 'just to make the numbers up' because there is nowt else available.
I'm not quite sure which part of my previous post you are commenting about, however in reply to yours...Id beg to differ, hauling Kingsbury oil tank trains with a class 66 with 3000 tonnes behind you doesnt offer the most robust performance, especially when you see the mini beach it tries to create when it loses traction. Not good when it ends up in pointwork.
can be passed onto the customer thereby giving them an incentive for keeping traffic moving by rail...
Speaking as a Driver who was trained on pretty much everything in the East Mid's during the late 80's early 90's, i'd have to say that 60's were the best thing since sliced bread. Nice and comfy, warm, decent stove that didn't take all shift to heat up, quiet, and the only loco that, with 42 HAA on, would get you up to the rapid loader at Bentinck Colliery first time without having to take an almighty great run at it.
I can't remember ever failing with a 60.
20's were ok. People say they kept going no matter what because there are two of them, but the argument doesn't really hold up on the routes we drove because the gradients were quite steep and when at full whack one of the pair would often overload, and if you didn't shut off quick and open up again you'd come to a stand. Darn uncomfortable rattly things as well.
58's were comfy, but couldn't pull the skin off a rice pudding and they'd slip in the Sahara desert, partially because the sandpipes were too narrow and clogged up easily.
The dashboard had a tendency to fall off when going along as well.
56's, now they were my favorites! Good looking, phenominal sound, and i always found them pretty reliable too, and although a fitter might disagree with me, i preferred the Romanian ones which seemed to pick up power a lot quicker than the BREL ones. Only downside was that due to a stepped brake handle with set notches, rather than the infinitely variable one on a 58 or 60, it was a bit of a pavlova loading in collieries on slow speed. You'd have to hold a little brake on to stop the train running away, but as the train loaded up and the weight increased gradually, you needed a bit more, but the next notch was a little too much, so you had to constantly play with the brake to stop the slow speed unit going mad! Brake changeover cock was in an awkward place on the Romanians as well.
I'd forgive them anything though, it used to make my day being routed main line at Tapton and opening them up as i hit Chesterfield with a big blast on the horn to annouce to the passengers that they were about to be showered with a load of blowing coal dust!
Never learnt 66's, got out of Toton before that, but from what my colleagues say i'm mighty glad i've never been near one!
The class 60 looks better it makes a better sound and it was made in britain. The class 66 looks plain it makes a non distictive sound and it was made in canada thus it is a rubbish engine
What about the class 37's ???
James
Happened at Newcastle to me too, once he finally sourced a spare key, driver was seen rather red faced...! oops!Lol at drivers not being able to get back on! That's happened on a certain unit type in recent years with an ECS move - driver got out to talk to the signaller on the SPT but neglected to take his keys with him and the cab door closed behind him! A monumental error!!!
Cant they use the class 59 for 60 workings as I heard they are the most powerfull diesel in the UK?
