Class 465 and 466 set for storage/scrap: possible uses for them in future?
Journeyman
16 Apr 2014
Are Southern even remotely bothered about replacing the 313s? I know they're getting on a bit, but they seem to be well enough looked after, and I'm not aware of any reliability issues.
Doomotron
25 Jun 2018
Kent
They keep them (and presumably the 455s as well) because they are incredibly cheap to lease - possibly the cheapest in the country.
It's possible, but at the same time so much house building has taken place within SE London and other parts of Kent I recent years that this could offset any reductions in travel caused by more WFH practices.
Yes I suspect in the medium term many inner-suburban routes will bounce back. It's the "home counties" commuters which will likely be slower to return.
Doomotron
25 Jun 2018
Kent
Well, I guess no-one else particularly wants them!
Nope, but I suspect that's because of their age and not their quality - the 313s in particular are still quite reliable units, even if they do have quite spartan interiors.
cnjb8
26 Feb 2019
Can’t help but wonder wether this is a nationwide thing against smaller trains. Operators seem to now order trains at 12-cars rather than 3 4-cars for example. And if you look at GWR and EMR withdrawing their 153s, maybe the 466s fit into their pattern. Makes more sense to have a longer 707 then a 465 coupled with a 466.
61653 HTAFC
18 Dec 2012
With rising passenger numbers (up until last year) there was certainly an element of there being less of a need for lower-capacity units... but a big part of it is the requirement for universally accessible toilets: as these toilets take up more space, they eat into the space for passengers to occupy. The shorter the train, the greater percentage of useable space lost.
There's arguably still a niche usage case for a 2-car EMU such as a 456 or 466, eg Bromley, Sheerness, and Guildford to Ascot off-peak... but with 3rd rail you're also increasing the risk of gapping, and with electric units there isn't the same cost penalty to adding a third vehicle that there is with diesel units.
As for Networkers to Southern, that's one of those things that makes more sense in theory than in practice. Had BR continued, a further build of Networkers might have gone ahead to get rid of the last VEPs and may even have found themselves on the Coastway, but the reality is that there isn't a huge benefit in replacing 40 year old trains with 30 year old ones. Newer isn't always better, such as when the aged but adequate heritage DMUs were replaced by Pacers... or when those same Pacers were replaced by older but more pleasant 308s.
D365
29 Jun 2012
What's the going rate for approved-supplier decoupling capacitors? :D
The capacitors aren’t the costly bit, it’s the safety/risk assessment exercises that rack up the bills!
Greater Anglia have modified their Class 720 order to remove the ten-car units in the wake of COVID.
hwl
5 Feb 2012
It was more to do with being too long for the depot facilities at Ilford post-cancellation of Brantham depot.
43102EMR
28 Mar 2021
A topic for a different thread, but it was principally down to increasing fleet flexibility due to the demand slump resulting from the pandemic.
Journeyman
16 Apr 2014
That's what I figured. They seem to plod on dependably, and do the job, even if you can't see out the windows...
aleggatta
28 Sep 2015
At least you can be sure they will be cold in winter and hot in summer - even if the hot in summer might simply be down to them being on fire!
Journeyman
16 Apr 2014
Plus, of course, all PEP-derived stock has two heater settings - "off" and "nuclear".
physics34
1 Dec 2013
Their lease runs out in December as does the 455s. This of course is easily rectified. The 313s could be replaced by 377/5, with SE keeping the networkers with the 707s arriving too, but i dont think the numbers quite add up.
Class 466
5 Mar 2010
Atherton, UK
377/5s are staying at Southeastern. 313s will be replaced by other means eventually.
In the short term I imagine the lease would be extended would it not? Unless it was already in motion the various rolling stock cascades you describe won't be completed fast enough.
A0
19 Jan 2008
Not even close. The reductions due to WFH are over 50% - there's been nowhere *near* enough housebuilding to offset that.
ScotGG
3 Apr 2013
I think they mean in 2-5 years.
No one knows what will happen.
physics34
1 Dec 2013
Someone said it all depends on Bombardier delivering the Greater Anglia stock..... which hints at cascades regarding 379s going to GN and 387s moving to SN from GN.... but just speculation and also going off topic.
So what networkers and how many are being stored. ?
According to the below post, taken from the Beckenham Junction thread, the units below are planned (465236 and 465246 in that list have already moved to store):
No idea about reliability, but some of those going to store are BREL examples. As for the 707s... if that's the case, then they'll need quite a few more over quickly, but the 701s aren't in service yet to replace those at SWR. I suspect they're probably just going to run a tighter fleet for the short term.
According to the se-gen postings, the ones going to store at Worksop are apparently:
465 004
465 010
465 019
465 236
465 245
465 246
466 004
466 024
466 033
Wolfie
17 Aug 2010
You miss the very important word currently. I have been in the office three times in 15 months. Initial thoughts are that we will be expected to be in the office at least 50% of the time. We have also been told that there will be measures to spread office attendance through the week. That will mean the reductions will be much less than you postulate. Removing large quantities of stock now, before the longer term situation is clearer, would be foolhardy.
Class 466
5 Mar 2010
Atherton, UK
This lists is incomplete and is missing 465017, 466016 & 466043 at least. (I say at least because two of the three units at New Beckenham will also be heading there)
Wolfie
17 Aug 2010
I was trying to work out how this related to Networkers and Southeastern. The answer is only marginally (as in it may rule out the requirement for some stock moves from Southeastern which some have proposed without regard to the impact to Southeastern itself).
Not a dig at you, there are lots of off-topic posts, but yours was the one which confused me for a couple of minutes.
59CosG95
18 Aug 2013
Beeston (Notts)
Keeping tabs here on this thread:
465004 - still with SE
465010 - still with SE
465017 - still with SE
465019 - still with SE
465236 - stored at Worksop
465245 - stored at Worksop
465246 - stored at Worksop
466004 - stored at Worksop
466016 - stored at Worksop
466024 - still with SE
466033 - still with SE
466043 - still with SE
'The Beckenham 3' - to return to Slade Green tomorrow (22/6):
466006
465247
465913
Wolvercoter
29 Sep 2010
Exeter, Devon
Thanks for the updates all.
Didn't know 466016 was heading for storage - in my mind, it's the closest to a 'celebrity' 466 in that it was running on the last day Elmers End to Addiscombe on 31st May 1997.
Tynwald
18 Mar 2016
Are 465/466 still fitted with those Ansaldo ICMU devices. They realy were very troublesome.
