Class 458/5
hassaanhc
5 Jan 2014
Southall
Oh Christ,that's horrendous...today? :( Sorry for the driver and punters.I doubt if it will be the 17:52 unless they take the unit out of service.They may have a Cover driver for the next part of the job after grub break.(Which isn't the 1752)
I normally let the punters off first,I've done that job before.
Yeah it happened today. Not sure any passengers were on it, unless they were too slow to leave before the doors got closed in order to attach, and I'm not aware of the platform number being advertised at any point. The doors had been released again before they realised what had happened, and it seemed a nearby member of crew saw me and my brother looking at it, before taking a look himself and shaking his head while looking at the dispatcher! :lol: Not good for the driver :(. The next two services, 1752 Weybridge and 1937 return, were cancelled, and Real Time Trains suggests the platform was blocked for about 2 hours (the length of time the platform 19 number doesn't appear next to any service).
infobleep
27 Feb 2011
Yeah it happened today. Not sure any passengers were on it, unless they were too slow to leave before the doors got closed in order to attach, and I'm not aware of the platform number being advertised at any point. The doors had been released again before they realised what had happened, and it seemed a nearby member of crew saw me and my brother looking at it, before taking a look himself and shaking his head while looking at the dispatcher! [emoji38] Not good for the driver :(. The next two services, 1752 Weybridge and 1937 return, were cancelled, and Real Time Trains suggests the platform was blocked for about 2 hours (the length of time the platform 19 number doesn't appear next to any service).
Would it have damaged much if anything given the low speeds?
randompixel
31 Jan 2014
Brookwood
An empty 10 car set went through Vauxhall which I assumed was the cancelled Weybridge service a couple of minutes before it was due.
fgwrich
15 Apr 2009
Hampshire
Possibly Depends on if the overiders came into contact with the buffer stop before the coupling did. May then be a case of replacing the coupling and checking over the corridor which has some contact with the stop as well.
SpacePhoenix
18 Mar 2014
Reminds me of a vid that I saw once on youtube where a HST had gone slightly into the buffers
Juniper Driver
17 Jul 2007
SWR Metals
Need to know what happened here.That looks bad.:(
Thanks for the pics.
A forlorn looking 8015 on Wednesday afternoon 08/04/2015.Now hasn't moved a wheel in over two weeks.
SpacePhoenix
18 Mar 2014
Apart from that unit how many of the "old style" units are left? I'm wondering if 8015 might be booked to do the Juniper railtour which must be coming up fairly soon
It would be 16, if you subtract the list of 20 posted a couple of days ago from the 36 total in the fleet?
Juniper Driver
17 Jul 2007
SWR Metals
SpacePhoenix
18 Mar 2014
http://www.ukrailtours.com/tourshow...trains&tourfile=150523_THE_JUNIPER_FACTOR.txt
Damn,it's fully booked.Oh well guess im working.;)
I'd love to take it to Bournemouth but I guess it wasn't to be.
Someone mentioned in the thread about the tour that there might be a few tickets available (probably as a result of a few people cancelling), might be worth contacting UKRailtours just in case there are the odd tickets available.
There's probably a chance that you'll end up being the driver for part of its journey anyway
Juniper Driver
17 Jul 2007
SWR Metals
Would doubt it,im 1400AO that day.Good chance I will get a Salisbury.
ARoo21
17 Mar 2015
Pictured a couple of the 458/'s today. 458 015 still sat in Clapham, picture to follow!
Peter Mugridge
8 Apr 2010
Epsom
That's a lot further back in the yard than when I photographed it on the 30th March! So they do seem to have been moving it around within the yard.
Unfortunately I was using my film camera that day so I haven't got the picture yet... I did my picture from the footbridge; it was only about one or two car lengths back from the bridge then.
Juniper Driver
17 Jul 2007
SWR Metals
I think they are supposed to move it every now and again anyway.Shunter told me it could move about the yard.
5 Jan 2014
I walked past it and never noticed. I saw the do not move board at the side, but was deciding whether to run to platform 20 for the Reading 16:50 service or take my time and get the 16:58 Windsor from platform 18.
I came in via the gates at platform 19 so was very close.
In the end I sat in a nice first class compartment on the Windsor.
hassaanhc
5 Jan 2014
Southall
I believe there were 458/5 units out today, as at least one diagram (possibly two) were showing 5 coaches instead of 10 (along with a Reading being 4 instead of 8). Not aware of anything at Twickenham, but there was the Oxford v Cambridge university boat race on the Thames. Matters not helped by a signalling problem at Queenstown Road, which for a time saw stopping services start from Clapham Junction, the Windsor services diverted via Wimbledon and Kingston, and the Reading services diverted via Wimbledon and Weybridge.
On Thursday I got 458531 (with 458502 as part of a 10-car, 2015 from Waterloo) where again both toilets in my unit were not working. Both had the engaged light flashing and the open button for the accessible one was lit but not working. The small toilet wasn't locked and was overflowing, nor did any of the electrics work (tap, flush etc). Had to tell the guard when I got off at Hounslow so he could lock it out of use.
RobShipway
20 Sep 2009
458530 & 458503 where connected together and in Clapham Junction stabling area earlier this evening.
Juniper Driver
17 Jul 2007
SWR Metals
Probably doesn't work if the water has run out.
455driver
10 May 2010
Presumably that's to stop the wheel bearings etc from seizing up while it's sitting around?
Its to stop the bearings getting small flats on them caused by the vibrations of passing trains, it does take quite a while for it to happen though.
The 47s stabled/abandoned at Cardiff a few years ago suffered from that hence the slow speed move to where they could be transferred onto the back of lorries.
Juniper Driver
17 Jul 2007
SWR Metals
[nothing to see here]Was on 458531 today which behaved perfectly fine.[/nothing to see here] although I couldn't tell if the toilets were working ok.
Most ExGats out and also 502/503/504.
Bigfoot
2 Dec 2013
Another being delivered today. Currently in Staines down goods loop. Didn't get the number...
WWTownEnth
21 Mar 2014
458501 Out of service - fire damaged
458502 In service
458503 In service
458504 In service
458505 Wimbledon testing
458510 Wimbledon testing 17/03/15
458511 Wimbledon testing 01/04/15
458018 Doncaster 26/03/15
458020 In service
458024 Wimbledon testing 14/04/15
458025 Doncaster
458026 Doncaster 06/04/15
458027 Doncaster
458530 In service
458531 In service
458532 In service
458533 In service
458534 In service
458535 In service
458536 In service
Juniper Driver
17 Jul 2007
SWR Metals
So here's a weird one.Working up road to Wimbledon from Hampton Court in a 455 a Class 47 with two barrier wagons passes me down road towards Raynes Park.So we terminate at Wimbledon as booked and work it over the LUL to Clapped Out Yard.Drop guard off at Clapham Junction Windsor Side.Draw forward to get behind dummy and change ends.Just as I get up the other end to work it into Clapham Yard a Class 47 with two barrier wagons passes me down the freight and 378 line to West Brompton direction.
How the hell did it do that so fast?
There can't be two Class 47 sets with barrier wags and did it really get round the Kingston Loop that fast?
Im baffled.:oops: Im sure im missing something here.
