Class 458/5
Juniper Driver
17 Jul 2007
SWR Metals
458025 left tonight northward behind a 66.
Didn't know what the 458 (although you just said) was but the 66 was 66848.I was on the 455 (Which was supposed to be a 458) which had come from Reading and I took it to Wimbledon yard.66848 was pushing the 458 around the big bully ;) right in front of my eyes and pushed it to the second barrier wagon.458009 was also in attendance nearby.
I took a 459 ten car to Clapham yard later (cant remember the numbers) and ended up having to wait half an hour for the last train.So I popped into Clapham Yard to talk to the shunter.He wanted me to shunt a 459 from ten to nine road...then slipping in slightly later that he also wanted me to couple the 459 I had shunted to another 459 making it very tight for me to catch the last train.The 0102 from Clapham Junction Plat 4 to Waterloo.While in the shed I bumped into 458503 literally with its nose poking out the shed and 458504 which was in the shed on 11.I managed to make it to the last train with four minutes to spare.
On my count there were at least six 459 units in Clapham.
HarleyDavidson
23 Aug 2014
What's the idea of clearing the Portsmouth/Eastleigh/Netley lines for use by 458's, albeit with some length restrictions?
WWTownEnth
21 Mar 2014
458501 In service
458502 In service
458503 Crew Training Clapham Yard
458504 Crew Training Clapham Yard
458505 Doncaster
458510 Doncaster
458511 Doncaster
458020 Wimbledon testing
458024 Doncaster
458025 Doncaster
458530 Wimbledon testing
458531 In service
458532 In service
458533 In service
458534 In service
458535 In service
458536 In service
Juniper Driver
17 Jul 2007
SWR Metals
YESTERDAY:
I went down to split a desiro (as it said on the diagram but it was actually a 459 which turned up) and I was waiting for it on Platform 15.It was late in due to cab door interlock trouble reported by the guard.So the fitter was there but NFF.So I did my first split which is easier than coupling them and it went out again.Then later on on platform 19 I had to couple up the 459's and had no problems...(for the 1615 Hounslow.Have heard they have had problems coupling on 19 due to the curves.If the problem persists I guess they will change the booked platform.Back on them Monday.Also 458536 seems to be around a lot now when im working these units.
Updated.Mistakes in original post.
RobShipway
20 Sep 2009
Not sure if the class 458 with the moustache in Juniper Drivers profile photo is the only train like this, but I saw it at about 2pm today at Martins Heron station doing I believe a service to Waterloo.
I was on the path below the station on my cycle on the down side to Reading when I saw the train arrive.
Juniper Driver
17 Jul 2007
SWR Metals
picture.php
That's last years photo,this years mustache is slightly different.I think there are a few units with it on.
Was at Weybridge (Bay) with 458531+458536 (Getting on 536 quite a bit at the moment)...Signalman called me up to put the signal back because well I actually thought one was coming from Addlestone to cross in front of mee but one was actually crossing from the down main to go via Chertsey.When I glanced up it was 458520+458530 on a testrun.Im sure all the doors were locked out.On approaching Staines with my train I think it was coming the other way meaning it must have gone into Staines up loop.
SansPareil
29 May 2013
I'm sure I saw a 458/0 out on it's own this morning. Looking at Realtime trains It may have been 2C18 0742 Reading to London Waterloo. If it was then that must have been fun.
5 Jan 2014
Yes it turned up at Feltham as the 8:35, I declined to try and board it and waited for the 8:46 where I got a seat even though itbusier than normal.
61653 HTAFC
18 Dec 2012
Even in the days of the slimmers, 4-car was a pain in the evening peak. Trying to get from Twickenham to Reading with luggage at 1730 on a single 4-CEP was quite a challenge!
Driver@swt
31 Aug 2014
I think the 458/5s accelerate slower, but do get up to speed pretty fast...you can feel the weight when braking though, bit more push than the 458/0s. It is odd having the female voice on the PIS though!
HarleyDavidson
23 Aug 2014
OMG. They've installed Sonia! :roll:
nuts & bolts
24 Jan 2015
B & H
As we approach May we approach the month in which the new hybrid Class 458 units are delivered and enter service. I'd imagine that Mays issue of modern railways will have some images of them and with articles like this surely it won't be long until we see the finished product compete with its 450 style front end?
Article http://www.rail.co/2013/04/19/first-class-4585-nears-completion/
Any predictions on when they come to London and entry to service?
I am (almost) confused by the front /rear ends, identical to 450's, tell tale sign is the it's a 458 - drip rail above vestibule doors. Is therre callaboration with Siemens for the remodeling?
Bigfoot
2 Dec 2013
None that I am aware of. The gangway supplier may be the same but other than that no link with siemens. They are easy to tell apart. Numbering location and colour. Headlights different. As is the whole cab... Plus they sound pretty different too.
5 cars gives it away for me...
