Class 458/5
Goldfish62
14 Feb 2010
I've been on the 1935 MF Waterloo to Reading a couple of times so far, this currently being the only Reading line service operated by a Class 458/5. On both occasions the PIS was not working and the external screen displayed "not in service".
I'm assuming from this that Reading line services are not programmed into the system. Is this true? Seems a bit of an oversight if so.
HeelBurton
10 Mar 2014
Wembley
Yep. No PIS codes available for Reading services. The same for Shepperton services.
WWTownEnth
21 Mar 2014
Any news on when the final unit will be delivered from Doncaster?
Also, have the remaining units being tested out of Wimbledon been brought into service?
Finally, any ideas when the Windsor services will go fully 459?
WWTownEnth
21 Mar 2014
458501 Out of service - fire damaged
458502 In service
458503 In service
458504 In service
458505 In service 21/04/15
458506 In service 04/01/16
458507 Wimbledon testing 26/01/16
458508 In service 02/11/15
458509 In service 29/08/15
458510 In service 28/04/15
458511 In service 04/05/15
458812 In service 14/12/15
458513 In service 14/12/15
458514 In service 04/01/16
458515 In service 14/12/15
458516 Doncaster 09/12/15
458517 In service 10/02/16
458518 Returned to service 12/01/16
458519 In service 14/09/15
458520 In service
458521 In service 19/03/16
458522 In service 02/11/15
458523 In service 10/12/15
458524 In service 26/05/15
458525 In service 09/06/15
458526 In service 29/08/15
458527 In service 20/07/15
458528 In service 14/02/16
458529 In service 28/09/15
458530 In service
458531 In service
458532 In service
458533 In service
458534 In service
458535 In service
458536 In service
In summary:
1 458/5 out of service and awaiting repair
1 458/5 in testing
1 458/5 in conversion
33 458/5s in service
5 Jan 2014
I noticed that the 08:41 service from Feltham to Waterloo via Hounslow was a 10 car 458/5 this morning. It has previously been an 8 car 450 since December and a 5 car 458/5 previously to that. I wonder is that a sign of increasing availability?
D6975
26 Nov 2009
Bristol
I had the privilege of travelling in a 10 car 458 set on Sunday for the first time ever. All the toilets were locked out of use. Is this a regular occurrence?
HarleyDavidson
23 Aug 2014
Not at all surprising considering that the clientele often use them for a smoking/drugs & sex den.
Last time I opened the door on a "Mobility Impaired" toilet, I found two boys having some let's say unorthodox entertainment that should be kept to the bedroom.:oops:
TEW
16 May 2008
Yes, the 458/5 toilets are very frequently out of use. Even when they're in use they're normally in a right state.
Kite159
27 Jan 2014
West of Andover
Getting the passengers ready for the toiletless 707s ;)
Agreed with TEW, even when in use the toilets are in a state, you need a gas mask to use them
28 Jun 2012
Epsom Downs
After the first batch of baby change tables were broken by their use as baby making tables, the new ones going in have apparently been tested to 80kg. That's some baby
61653 HTAFC
18 Dec 2012
Good to know SWT are an equal opportunities privacy provider... wonder what the famously liberal-minded Brian Souter would make of that! :lol:
WWTownEnth
21 Mar 2014
Has anyone seen 458507 in service? It's supposedly been at Wimbledon for testing since 26/01/16.
Thanks.
WWTownEnth
21 Mar 2014
458502 In service
458503 In service
458504 In service
458507 In service 24/03/16
458520 In service
458530 In service
458531 In service
458532 In service
458533 In service
458534 In service
458535 In service
458536 In service
In summary:
34 458/5s in service
TEW
16 May 2008
Not for over a year yet. There are platform extensions and power upgrades to be done on the Reading line first. And the 707s need to be introduced to Windsor/Weybridge/Hounslow Loop services to free up the 458/5s.
