Class 43 disposals
fgwrich
15 Apr 2009
Hampshire
Either being moved for more space at HA, or storage pending decision on its future?
I presume ScotRail will want a new spares donor.
They have a replacement spares donor, in the form of 43030. I believe 185s future has now been chosen, but taking it to Brodie’s will allow them & ScotRail to remove any further components Haymarket wasn’t able to remove.
nat67
23 Apr 2014
Warwickshire
43082 and two others are moving to the Colne Valley railway to join the 3 HST MK3’s that are already there.
Are the VP185 examples not more popular [than MTU] for further use?
Neither will be popular for further use if those uses can't be identified. The owners of the power cars have had long enough to exhaust the list of willing users now regardless of the engines fitted.
fgwrich
15 Apr 2009
Hampshire
Scrap movement planned for the last EMT branded power cars, although no movement is on RTT yet
I can't say I'm surprised, those two were stripped for spares before they left Neville Hill. There isn't much left inside them!
It seems to vary between Lessor - Porterbrook seem far more pro-active than Angel in finding further use for it's Power Cars, be it on the mainline or in Preservation, whereas Angel seems to be sitting on them in the hope that someone with some considerably deep pockets turns up tomorrow and asks for a fleet of PCs. At least one of those two knew how to 'Winterise' them correctly and didn't just park them up as well... :s
fgwrich
15 Apr 2009
Hampshire
A few knackered batteries?
There will be a few more issues than that. Most of Porterbrook's Power Cars will have been drained of the usual fluids, and had most of the exhaust ports covered over, whereas photos of the ever decrepit lineup of Power Cars at Ely seem to show that none of them have had the exhaust ports covered over - so at a bare minimum they'll be full of water and whatever else!
D365
29 Jun 2012
By the sound of it, no expectation of any future home for the Ely 43s.
Shuttle
4 Mar 2020
Stoke
I've seen a few posts elsewhere mention that these two were well picked for parts, and weren't in the best state to start with. Sadly the first of many, but their time has come.
DBS92042
13 Apr 2019
I believe it will be just the loco as it ran down under a 0 headcode.
I shall see it at Worcester to verify.
Thanks. I saw the return headcode for later as 5M57 (although that may've changed now) and wasn't sure which to believe
fgwrich
15 Apr 2009
Hampshire
I believe Porterbrook have ordered a Total Destruction Order on them - so nothing will be left. Not that SIMS is famous for souvenirs :'(
Probably because there both isn’t, and won’t be much left on them. Porterbrook will be collecting what can be re-used on their other HST fleet from SIMS. And as previously mentioned, both power cars have already had a number of parts removed from them prior to leaving Neville Hill.
158747
5 Aug 2010
Trowbridge
Total destruction order seems to be quite a new thing which is mentioned quite frequently these days. Is it an actual order in relation to rolling stock being disposed of or is it just the fact that as it is being scrapped at Sims it gets totally destroyed in the process of scrapping anyway. It’s not as if we are discussing the disposal of top secret military hardware or anything like that! Just the disposal of redundant obsolete rolling stock.
DanNCL
17 Jul 2017
County Durham
In this case it’s the latter. TFL have for a long time used so called total destruction orders on everything they send for scrap but other than that they’re rarely used.
Wyrleybart
29 Mar 2020
South Staffordshire
IIRC DRS have used destruction orders on some of their class 37s in the past
DBS92042
13 Apr 2019
Doesn’t seem to have left Long Marston, should be at Worcester T.C. Around about now but alas it is not.
I see on the live maps that it's now at Worcester TC, any ideas if its run around yet?
Edit: looks like its on the move now
Towers
30 Aug 2021
Can't really imagine why there's a need for a total destruction order on a pair of gutted 43s, a bit baffled by that. Particularly as they're in the livery of a defunct operator; odd!
D365
29 Jun 2012
By the sounds of it, "total destruction" can mean anything.
