Class377/5
- Joined
- 19 Jun 2010
- Messages
- 5,594
It seems that 2T30 has been terminated at Haywards Heath due to " a problem with the overhead line power collection equipment (M1)"; although appears to be continuing now to Bedford. Not sure what that implies for the rest of the day, but combined with the disruption at CTK, I don't have my hopes high being able to try it this evening as scheduled.
Lasted longer than I thought.![]()
I was driving 2t30.
Where you got the rubbish about overhead problems I don't know but we were terminated because of the chaos at city thameslink. Three bridges didn't know what was happening so I sat on the loop outside gatwick for nearly an hour. Units are now in cricklewood and noone knows what's happening with them next.
I find your lack of faith disturbing...![]()
Any train cancelled due to delays caused by a failed train will show as 'cancelled due to a problem with the train' or similar in RTT though - so you can only really guess which unit is at fault by finding the train furthest along the line when the issues occurred. Would I be right in guessing the train in question here was 2V20?
http://www.realtimetrains.co.uk/train/G71761/2014/12/08/advanced
I was driving 2t30.
What was up with the actual train in city thameslink I've no idea so that must have been the overhead problem which led to me being cancelled. The 387 I had was absolutely fine.
Regardless of the events earlier, 387105 and 387106 are working 2T73 the 2122 Bedford to Brighton this evening so will be back in Brighton tonight.
And made all stations to St Pancras.
387114 was delivered tonight as well.
Hoping it's scheduled to run the same diagram tomorrow? Makes for a reasonable trip into work! :P
Is the first class sectioned off?seats no different from 377/6s and /7s.
Different seating moquette in the so-called 1st class area (same type of seating as Standard)........ then again Thameslink are only using the small area behind the drivers cab and the first set of doors as 1st class.
Ride does seem better than 377s...maybe because of their 110mph capability.
Had two trips on them now, and really, I don't know what the fuss about the seats is.
As for ride, at 100mph I found it the same as the 377s were when they were new.
The brakes however definitely work well. Tootling along at 100, the driver left the braking for St. Albans until just about the last minute, and it stopped on a sixpence.
