Class 365 PBC Unit and PIS system
WMasterJedi
23 Nov 2023
England
They didnt make these for one only, they made them to be able to switch between operator anytime as both the controller and audio controller have both GT North and SE data installed by default.
WMasterJedi
23 Nov 2023
England
I think I may have found something.
I may be wrong but after checking the PCB the EPROM inputs and outputs appear to be going into two other chips, RAM chips to be exact, I think on start-up the EPROM data gets copied to the RAM chips because I think when it checks to see if the data is corrupt it doesn't check the EPROMs but it checks the copied data in the RAM chips.
More info to back this up is that the way it broke was because I was using it taken apart and a screw thread from the screen touched some of the pins on the RAM chips which would support the idea of the RAM chips not being corrupted because they don't hold data when turned off but just broken so they don't hold data properly.
Another idea is that one of the traces is broken meaning that the data isn't reading / being read properly causing it to think its corrupted.
With all this being said, I may be wrong.
365 Networker
19 Jul 2019
Alternatively, I have been able to track down another controller for £60 including shipping.
I assume you are referring to your original controller with the GN destinations? If so, you might want to try replacing the RAM chip before spending money on a new unit. This also doesn't explain why the audio announcements are not playing with the working SE controller. I do seem to remember that drivers had the option to set up the destination display without the audio announcements - perhaps the controller is currently in this mode - there may be an option within the menu somewhere?
WMasterJedi
23 Nov 2023
England
The reason the announcements are not playing will probably be due to the fact that the data lines aren't connected properly
Edit: POST 365!!!!!!!
WMasterJedi
23 Nov 2023
England
I've done a little testing with FFMPEG using ADPCM and although I haven't found a perfect solution as the clicking is still there, I've been able to have it not change volume randomly and stay the same consistent volume.
365 Networker
19 Jul 2019
I have a feeling the "clicking" sound is used by the controller software to stich the individual sections of audio together into announcements. Presumably the software was able to filter this out. Could you post the output of FFMPEG?
WMasterJedi
23 Nov 2023
England
That does sound plausible.
Here is the previous vs the newly found ADPCM.
previous
new
WMasterJedi
23 Nov 2023
England
What I have also noticed is that the repeated constant clicking sound does actually appear in the real thing
Although not as noticeable.
365 Networker
19 Jul 2019
The hissing sound was heard on the real thing, though not when the actual live PA was being used, only the pre-recorded stuff.
Yes - I do remember this - I’m pretty sure the amount of ”hiss” varied between units. There were also at least two variants of the manual PA chime.
I wouldn’t be surprised if that was present through the PA, though with background noise it probably would have been fairly imperceptible.
Well done on getting so tantalisingly close, seems like very nearly there now!
Good to see the 365s are still attracting attention!
365 Networker
19 Jul 2019
Have you been able to get the announcements working? Also, there is another Power / brake controller on ebay - https://www.ebay.co.uk/itm/286393447369 - it's interesting to see the Westinghouse label as I had thought that they were made by Davies & Metcalfe (I'm pretty sure the 465 ones were)
365 Networker
19 Jul 2019
Interesting documentary from 1999 with some 365 action from the cab (starting from around 22:49)
WMasterJedi
23 Nov 2023
England
Yeah I’ve seen that on eBay, the 365 parts that eBay seller is/was selling were from the east Kent railway, I know that because I remember seeing them when I picked up these. IMG_1148.jpeg
WMasterJedi
23 Nov 2023
England
Interesting announcement unit update!
Sorry for the long break however I'm back doing stuff!
I have put together this simple little circuit to lower the raw speaker level output (10V) from the unit to microphone level (10mV, 0.01V).
This allows me to do multiple things, including connecting it to a landline telephone and listening to raw announcements over the phone or connecting it to the microphone jack on the back of my computer.
From doing this, through audacity I've been able to record clear and raw announcements straight from the unit!
View attachment raw_output.mp3
Note: The audio is edited to the original recording however the audio itself is the same, I've just removed the quiet blank space between announcements.
365 Networker
19 Jul 2019
Excellent! Hopefully you will be able to get the other announcements working soon.
Class 466
5 Mar 2010
Atherton, UK
“Please listen for announcements” :lol:
WMasterJedi
23 Nov 2023
England
New Update!
After a while of cautious soldering, I have been able to read the program data off the EPROM on the working controller!
The reason I haven't done this sooner is because the EPROMs on that controller are soldered into the PCB unlike the corrupted controllers EPROMs which are in sockets. This means that the only real option was to solder a wire to each solder pad which could easily go wrong, either a burnt off solder pad or damaging the EPROM from excessive heat.
But I have done it! And have resurrected my corrupted controller!
I was curious to see how corrupted the controller was so I used a software to compare the two bin files and large sections in the corrupted data were blank while the non corrupted data was full of data including the entire section for the text that appears on each menu! -So yeah, very corrupted!
With all this being said, I now have access to GT North destinations. An interesting thing to note is that each controller holds two databases and the active database can be selected in a menu, but the reason I was simply not able to just switch the database on the previously only working controller was because on that controller both databases were the same thing (South East), they had the same version numbers and contained the same destinations. However on the newly working controller the database version numbers are not only different but one holds GT North destinations and the other holds South East destinations.
This is really good because I can use the one controller yet access both GT North and SE databases just by accessing a menu!
365 Networker
19 Jul 2019
New Update!
Very good - I wonder if the different version numbers was why you were unable to get the announcements working previously? Perhaps they will work with the newer controller.
