For any TOC other then Abellio Greater Anglia to use them they'd likely have to pay however much it'd cost to have new cabs built with corridor connections
No, we here could use that ninth or thirteenth coach...
That would make sense.Nvm said:Or send them to LM to replace the 319s?
One might need to have the Abbey Line handed over to LOROL to operate, or LM pay LOROL to operate it in a long term agreement, so the train to operate it comes up from Willesden perhaps?
Preferable, as LM or SWT use fully gangwayed existing Desiro fleets, but definitely not essential.
SWT have any number of routes they could use a few single 5 car EMUs on, such as Ascot to Guildford, or Portsmouth to Southampton. Even Lymington with another short platform extension...
I know this will probably start a major argument but could the fifth carriage be used in any other formations of similar units (350/444/450/185)?
What's the reason they can't use 350s on there at the moment? Is it cheap to fix?
Not necessarily, I'm sure that they could still operate with no corridor connections, as it happens across the network.
The dwell times would be worse than horrible...
The doors used on 378s and 700s are much quicker to cycle, and the LOROL depot at Willesden is a lot closer to get a spare on/off the line.
I'm not sure why 350s have never been cleared for the line, they'd do better with poor railhead conditions than the 319s.
4 diagrams are needed for Guildford-Ascot, so 5 5-car 360s would free up a further 4 450s (once they return to that route) for the mainline, 4 in service and a maintenance spare.Can't use 5 car sets on Lymington Pier line, power constraints, can't use 5 cars on Guildford to Ascot platform lengths too short (Wanborough, Ash (Down), Frimley and they can't be extended at Camberley (Up) easily due to grade, level crossing & signals and Bagshot also suffers from grades either end & which again will require signals to be moved if they want platform extensions but then again NR very wisely put a RRV access point just off the end of the up platform, so that would probably knacker that.
Which is somewhat ironic for these 360s as they would have originally been built with cabs as 350s, before removal/conversion to 360s for HEC.
Presumably the 350s cost more to lease, so there's little use in using them on a route which I assume only generates marginal revenue compared to the WCML services.
If the old cabs were removed what happened to them, were they stored somewhere or scrapped?
I think they were originally designed with corridor connections rather than actually being built with them.
3 diagrams are needed for Portsmouth-Southampton. Quite a few of the Netley platforms would take 5 coaches, and ASDO would be fine at those that didn't (Hamble). I wonder if with 5 units you could operate a half-hourly service on the route? I reckon you'd grow passenger numbers with a better frequency, and the number of bikes you get anyway means 360s might be a good solution. Even if you kept the hourly frequncy, you could use the other two units on some of the Basingstoke-Portsmouth/Southampton Hants local services. Again, would free up some 450s for use elsewhere.
