Class 222 from EMR to Polmadie
thecrofter
16 Dec 2011
Seeing as how the Class 222 redeployment thread has been closed, it looks like the movement of an ex EMR Class 222 (222005?) from Barton Under Needwood RSMD to Polmadie has been rescheduled for Monday 27 October 2025.
dan4291
9 Dec 2019
County Durham
It has set off, so looks like Lumo are getting their first 222 today. Wonder if it's going to be worked on first or put straight to use with route learning and traction training for Lumo's drivers. There are STP Lumo paths from Polmadie to Stirling and Motherwell most days so they're ready to be used.
InvHst
9 Dec 2018
Presume it'll go straight into usage
InTheEastMids
31 Jan 2016
Given it's a 7-car set, there is presumably a "both" option where 1-3 centre cars can be removed for refurbishment teams to start pulling apart whilst a shorter set runs around doing crew training. Given Lumo intend to operate them in 6-car formations, I'd have thought removing 1 before any training starts was a bit of a no-brainer.
222001
1 Sep 2006
Chesterfield
005 is currently a 5 car set, it was reduced by EMR a year or so ago
hexagon789
2 Sep 2016
222005 has already been shortened, though to 5, not 6 cars.
InTheEastMids
31 Jan 2016
Oops. Thanks. Facepalm. I do remember that most recent reshuffle of the 222 formations.
Perhaps the point still stands as it could theoretically run around as a 4.
Am I right in thinking that this train was originally put into service as a 9-car? To potentially see it running around as a 4 car would surely make it the railway equivalent of the Black Knight from Monty Python and the Holy Grail (although perhaps HS2 already owns that dubious honour).
hexagon789
2 Sep 2016
Yes, though Lumo intend to run their 222s as 6s in service.
Correct. Shortened to 8, then 7, then 5.
All of 001-007 were originally 9-car.
007 went from 8 straight to 5, unlike 001-006 which all ran as 7s for many years, before 005 & 006 were also reduced to 5s, freeing up intermediate vehicles to extend the former Hull Trains sets from 4 to 5-cars.
D365
29 Jun 2012
So the gist is… no need to add any additional vehicles to 005 just yet. And certainly no reason to reduce it to 4 car.
InvHst
9 Dec 2018
Unbranded 222005 on route hasn't been put into Lumo colours. I presume that means the others as they go off lease will go for refurbishment before delivery
45076
4 Feb 2021
Midway, South Derbyshire
I wonder why they sent it to Stenson and then reverse to Crewe when it would have been much easier to go via Alrewas to Lichfield TV direct to Crewe. Unless of course the WCML has no gaps.
Peter0124
20 Nov 2016
Seen at Newton (Lanarkshire)
I take it Polmadie is where they will be based with Lumo?
LowLevel
26 Oct 2013
Unit 001 has been stopped and debranded so presumably will be leaving soon.
InTheEastMids
31 Jan 2016
What I am guessing was 005 (too far away to see the number) was out today, would this be driver training?
5M03 Polmadie to Preston and 5S02 return
https://www.realtimetrains.co.uk/service/gb-nr:A23274/2025-11-20/detailed
https://www.realtimetrains.co.uk/service/gb-nr:A23275/2025-11-20/detailed
Unless somebody better-informed tells you differently, I think it's the only one that is in Scotland.
My understanding is that 001-005 will go to Lumo
Neither 001 nor 002 appear to have been in traffic for a while, but again unless somebody says otherwise are still at Etches Park
003 and 004 seem to be both out earning money for EMR today.
LowLevel
26 Oct 2013
001 has been stopped for handover works and debranded. 002 has apparently been used as a bit of a Christmas tree for parts to get 001 back to condition for handover so neither are in traffic at the minute.
liamf656
2 Aug 2020
Derby
Internal rumours suggest that 222003/004 will be taken out of service at the end of 23/11/25. Whether that actually happens remains to be seen
Trainman40083
29 Jan 2024
Derby
I guess I have had my last ride on a 7 car out of Derby then. Had 222003 on Friday
Railperf
30 Oct 2017
Was 001 in such a poor state then - what parts needed replacing?
Any confirmation that 003 and 004 will NOT be out tomorrow now for EMR?
Royston Vasey
14 May 2008
Cambridge
So a double whammy for the passengers in this disastrous transition to 810s and the loss of their trains to a dubious open access route. Should never have been allowed to happen this way, but it's one more blow to a route that's as neglected and sidelined now as it ever was in the 90s/00s.
