Class 180's to.....Northern?
devon_metro
11 Oct 2005
EMT want to have FC on the Norwich - Liverpool route apparently. Similar to XC on Nott - Cardefffff
Galvanize
8 Jun 2005
South East london
I can see the Pioneers being used on the route if EMT get them. By customer demand if anything.
I think he [Tim] suggested that if they had the Pioneers, it would go towards having a half hourly London-Sheffield service!
That's just gonna reduce the capacity considerably!
devon_metro
11 Oct 2005
Same concept as when FGW beefed up London - Cardiff to half hourly with 180s. They soon got too busy and HSTs were required. But none left!
class 313
10 Dec 2005
St Albans
Not if Pioneers or Meridians do the runs!
Galvanize
8 Jun 2005
South East london
Yet the MML has a max speed of 110mph.
Indeed. But maybe the 222s are 125mph to take advantage of speed increases if there's ever one planned to happen?
Seeing as HSTs are going onto the Nottinghams, then a few Meridians will be freed up
Don't forget Corby is going into the equation soon!
1D53
2 Apr 2006
EMT ran a 222 to Liverpool this weekend and doesn't seem like anything was flagged up. Its worth reminding that these 180's are going on a short term deal until they are demanded either by Nat Ex or First for Harrogate and Hull services. They would be sat empty at Oxley otherwise for 18 months.
class 313
10 Dec 2005
St Albans
I'm not forgetting. I'm saying that 222s could be used. Just because this person has said so now doesn't mean its going to be like that in the future! As with most things.
Galvanize
8 Jun 2005
South East london
Good to see your not forgetting Corby!
Besides, if they use 222s on the Liverpool-Norwich corridor, not only would they have the same weight restrictions as the TPEx 185s on the Hope Valley, it would also be restricted to a mere 45mph from Ely to Lakenheath! I suppose the 125mph speed would be used between Peterborough and Grantham to good effect, but balenced with the 45mph restrictions in Anglia, and the other restrictions, it would have very little effect on journey times!
And as seen on another forum, a 4 car 222 has LESS standard class seats (124) than a 2 car 158 with 139!
P156KWJ
26 Nov 2007
Nottinghamshire
I heard differently, as the 158s are being refurbished without FC. There would be no demand really.
When ex CT drivers were on strike, ex MML drivers were using 222s on the Nottingham-Sheffield part of the line, and I felt so much more relaxed on one than on a 158
alex57601
24 Feb 2008
I think it will be the 5-car 222s that would appear on the Liverpool services, as I heard the 4-car 222s from Hull Trains would be for the Corby services.
P156KWJ
26 Nov 2007
Nottinghamshire
all the way to Liverpool? Are you sure they didn't just do it to Sheffield and make everyone change to a 158? Unless the drivers were originally ex MML and transferred to CT, in which case they'd sign both the train and route?
class 313
10 Dec 2005
St Albans
Yes, all the way to Liverpool for driver training and to pass the class for the line.
P156KWJ
26 Nov 2007
Nottinghamshire
good - but I don't think there'd be any demand for first class - I think they should de-comission the first class like Central Trains did with TransPennine 158s and on SWT units
First class
9 Aug 2008
Will a 222 fit into Platforms 1-6 at Lime Street, or can it only use the long 7-9?
Think there would be FC demand between Liverpool & Manchester, TPE is usually quite busy.
There was a suggestion on another forum, (dartslf), for EMT to run to St Pancras with a reversal at Sheffield with these 222s, would give Virgin a run for their money I suppose...
P156KWJ
26 Nov 2007
Nottinghamshire
but that would mean either running 8/9 car trains and splitting them or getting rid of the extremely busy Norwich trains at some times
notaspotter
26 Aug 2008
Northern Rail are indeed getting 3 Class 180 units. They are to Run on Huddersfield - Blackpool via Manchester Victoria. These services start in December and I am pretty sure that the 180's will run from Dec also.
adambro
2 Dec 2006
Care to quote a reliable source?
First class
9 Aug 2008
Hmm, I don't think so...
1st post you made, and probably you're last...
Northern do not need 3 180s quite simply. A 150/156/158 is generally fine for this type of service, even a 142 occasionally pops up on similar routes. You're not seriously suggesting a 142 is replaced by a 180???
They need route clearance, new depot facilities and route learning for the drivers. now that is not going to happen by December.
Provide a source, or believe at your own risk of dissapointment. Why are people so interested in 180s? Have you not seen their failure rates?
P156KWJ
26 Nov 2007
Nottinghamshire
exactly, why do you think FGW are so quick about getting rid of them? Well I can only think of one answer :shock:
First class
9 Aug 2008
I was always surprised about their failure rates because the 175s are pretty reliable, and they are from the same family.
The 180s offer improved comfort and probably cheaper to run than a larger HST, but I would rather sit in a less comfortable seat, safe knowing I would probably get to my destination. If they did come, fares would probably rise as a result anyway.
Wouldnt trust Northern with them though, they would get wrecked...
1D53
2 Apr 2006
I've had and seen information from a number of sources within Northern and Network Rail that a very real effort is being made by Northern to get these units short term. A lot of preparation works are being done for this, route clearance and depot facilities are sorted and some initial driver route learning is being done....
P156KWJ
26 Nov 2007
Nottinghamshire
well judging by the state of 142035 today yes, I sat down and the chipboarded back of the seat gave way and fell out backwards! Good job no-one was sitting right behind me :shock:
First class
9 Aug 2008
Ok - assume Northern do get them. Aren't they only available for a year lease anyway?
Northern would be better concentrating on improving their exisiting rolling stock, which we're going to be stuck with for a good 10 years to come, rather than getting rejected trains with questionable reliability, excessive capacity and increased costs to the company and subsequently the passenger.
What happens when they have to return to HSBC Rail? The new, fancy trains have suddenly dissapeared from thousands of passengers, they will not be impressed, particularly as fares will not decrease again...
I'm all for Northern having modern rolling stock, but it needs to be consistant across their fleet, they even have various liveries... I would rather see the units be put to better use on services like Liverpool-Norwich...
rob s
8 Feb 2007
I was on a 180 at the weekend and the train suddenly stopped outside Didcot. A few minutes later the PA comes on and apparently a child had pulled the emergency alarm and they couldn't reset it :roll: After a few minutes of staff walking up and down the train it got going again. This was in addition to the bored sounding member of staff announcing that there were plenty of appetising beverages and drinks but no hot drinks due to a faulty boiler!
Philip
27 May 2007
Manchester
What's this about Huddersfield-Blackpool? Blackpool-Manchester's don't carry on to Huddersfield.
adambro
2 Dec 2006
Northern haven't submitted a proposal for a vehicle change to Network Rail as far as I can see from NR's website, assuming Nothern's plans to utilise 180's are genuine, in what kind of a timescale should we expect to see this? I must say that whilst doubting this it would certainly be very interesting to see a 180 in Huddersfield working a Northern service. It would just be nice to see some hard evidence as I'm always cynical about most of the rumours that circulate on rail forums.
