Class 175s to GWR
craigybagel
25 Oct 2012
I don`t know if the sunflowers themselves have since been modified or not but I have seen one picture within the cab that shows that the sunflower mounting was now angled towards the driver with the probable intention to make it more visible, is this the case on all the units now ?
Prior to storage sunflowers were not illuminated but the yellow petals were painted with fluorescent paint for visibility during darkness and in a depot environment during the hours of darkness the sunflowers were visible. I don`t recall any driver defect reports asking for them to be replaced due to poor visibility.
I don't know the reasons why, but Aslef are inisiting that the sunflowers be luminous in darkness. I suppose it's to match the rest of the GWR fleet, ie it's something that drivers are accustomed to. You point out that the sunflower is visible on depot, and that's half the problem. They are mistakenly coming off depot, then the driver at Plymouth station has to either fail set, or wait for daylight before working the train.
They were never visible in darkness when they were at TfW. Putting them in a more sensible position facing the driver won't fix that. It was accepted at TfW but the issue wasn't unique to that part of the fleet there.
This is not a criticism of either TOC or ASLEF - but it is good to see that ASLEF are insisting their members at GWR don't take a step backwards in terms of cab conditions.
BrianW
22 Mar 2017
Displaying my ignorance here, and not trawling back through 4141 posts- what is a sunflower? Sunflower stopped play?
tfw756rider
30 Nov 2024
Wales (sometimes in England), thanks for replying!
The 'sunflower' (AWS sunflower) is the round visual indicator of the Automatic Warning System (AWS).
Attached is an image (credit: To The Trains) that shows two stages of the AWS sunflower:
Left: AWS sunflower active. Right: Inactive; next signal clear.
Source page of the image
Siemens Staines
30 Jul 2015
To be expected as darkness falls
19:15 Penzance to Exeter St Davids due 22:37 will be terminated at Truro.
Last Updated:02/09/2026 20:01
devondonkeu
31 Jul 2011
Just clocked on and 115 cancelled Par to Exeter and it's the connecting train at Exeter for Bristol.
5E90 150 to Exeter was in the platform at Par and went off. I'm sure the passengers were impressed, not.
115 as 5E28 terminating at Plymouth
When the two trains were at Par, I wonder if they asked the guard of 115 to go on the 150 so it could go passenger to Exeter.
5E90 has gone into the siding south of platform 3
I was on this from Truro and yes, I saw 5E90 leave ecs (with a guard) and let the them know I wasn't happy. Especially when I found the pub closed too . 115 left ecs about ten mins after cancellation
REVUpminster
3 Jan 2021
Paignton
006 just passed Saltash as 5E28. 2Z28 is on it's way in it's timings 27 late. 150266 off Falmouth. Hopgood could replace Jethro on Cornwall radio.
5E28 shunted to the dock platform. Maybe the crew have to take 2Z28 which has arrived at 2136
BillStampy
6 Jan 2024
Llanharan
It's frustrating as it's only going to get worse if the problem isn't solved as we approach the winter time and daytime continues to be slashed daily!
REVUpminster
3 Jan 2021
Paignton
2Z28 arrived at Exeter and they didn't hold 2M77 the Bristol connection 10 minutes and it went 1/2 minute early!
The golden rule on GWR is "a train in the platform is worth two down the line". Take the first train and go as far as you can towards your destination.
RPI
6 Dec 2010
Surely if it's "not safe" to operate with a sunflower that doesn't light up then it shouldn't be running ECS either then? The risks are just the same.
sh24
28 Sep 2023
Sounds more like the union trying to justify their membership fees by creating drama.
Harpo
21 Aug 2024
Newport
Running ECS obviously reduces risks by taking passengers out of the situation and I’d guess that the procedure uses an agreed ‘Train Out Of Service’ protocol for AWS failure?
RPI
6 Dec 2010
It does, but, playing devil's advocate here, a risk of not correctly acknowledging the AWS could be that the driver has a SPAD, that SPAD could potentially result in rear ending another train with passengers, therefore IF the AWS sunflower not being illuminated is a genuine risk then it shouldn't be used after dark on an ECS move either.
I'm not sure what the answer to this will be, retro fitting all of the units with illuminated AWS sunflowers?
foggy69
28 Dec 2020
Or it could be the union making sure that it's members and the wider travelling public are kept safe.
If all the other stock you drive has an illuminated sunflower, it could be part of the company driving policy, or part of a drivers personal protective or development plan, so there are implications of it not been visible.
It is amazing how some people have such a low opinion of drivers and the union. There are very few jobs that just a moments lapse can cause death and injury to hundreds of people. It is a testament to the professionalism of drivers and the union for ensuring that train travel in this country is safe.
RPI
6 Dec 2010
What irks me is why didn't the union pick up on this when the 175s first arrived instead of a year and a half later??
I'd be inclined to make this observation too, particularly when it was picked up that new drivers seats would need to be fitted before the units entered service.
DelW
15 Jan 2015
If it really is just AWS illumination needed, a battery LED light of the type sold for map reading in cars could be sufficient as a short term fix. Example here (not saying this particular version is necessarily suitable, just a generic example)
Exclusive Clip-On Flexible LED Reading Light For Kobo, Laptops, Map reading, Books, E-Readers,
But I suspect there's more to it than just the illumination, since surely that would have been sorted out in less than 18 months ....
Or it could be the union making sure that its members and the wider travelling public are kept safe.
The first units have been there over 18 months, and there were a series of cab modifications requested. Meddling now is just the union being troublesome to justify its membership
If it was policy, would have been done as part of the agreed changes. It wasn't so clearly isn't policy. Either that or the union officials who agreed the cab changes were totally incompetent and forgot to check.
REVUpminster
3 Jan 2021
Paignton
003 operating 2C05 with 150246 doing the dark part.
As for the AWS if the driver ignored the sound or visuals then the train would be stopped by the safety systems otherwise what's the point of having AWS. The first passenger 175 operating to Newquay was last December and it was dark.
foggy69
28 Dec 2020
The sunflower isn't all about when you are actually passing the signal.
I do not know the railways in Devon and Cornwall, but I expect there are some quite long distances between signals, and looking at the sunflower between signals is a great visual reminder for a driver that the last signal passed was showing either a clear or a caution aspect.
Like you, I am guessing what the issue is.
It might have been requested and a timescale agreed, but the company hasn't done the work yet. As the nights are drawing in, maybe the union has taken this stance.
Maybe it was missed by the union when the units were introduced.
Whatever the reason, it is something that needs to be sorted out and blaming the union without a shred of evidence is not very helpful.
Jrocks
27 Apr 2021
Torbay
Yes, this is the answer and will ge what is happening very shortly!
Again, not to play devil's advocate but the 220/221s that *Some* of the drivers also drive do not have light up sunflowers. Yes, they dont drive them long distances on the mainline but they do drive the traction without light up sunflowers....
sh24
28 Sep 2023
I have plenty of respect for drivers who do a job I could not.
However I have a raised eyebrow about the position of the unions as I understand they are involved in signing off new stock? So either they missed this, agreed a plan of action that GWR haven't followed through on, or are using the situation to create leverage.
Harpo
21 Aug 2024
Newport
All responsibility for having fully operable AWS rests with the employer and not the employee. If AWS illumination was missed, it’s not down to employees whatever process is involved.
John R
1 Jul 2013
The point is that they were regarded as fully operable for the first 20 years of their life without illumination. Unless the Union said early on in the process that having examined the units they no longer considered that acceptable then it was perfectly reasonable for GWR management to assume that the "as delivered" situation was acceptable.
sh24
28 Sep 2023
It sounds like the AWS is operable, and aligned with other UK train fleets. So the employer has done their job with regard to risk assessment etc.
Harpo
21 Aug 2024
Newport
Agreed. But we are a quarter of a century on from when 175s were new. Much has changed in that time, especially where driving and its management is concerned.
