Class 175s to GWR
I suspect the danger here is if a unit fails, the trek back to Laira is longer and potentially more disruptive if breaking down near Taunton.
Yes, but generally faults are going to show up quickly, within a few miles
Of course, longer journeys will eat up the miles quicker, but on the other hand, things like keeping swapping ends, opening and closing doors and generally having someone acting like a passenger using everything from door buttons, toilets, moving to every seat and socket, and occasionally using emergency alarm is much more realistic test threshold than running empty for 1000 miles
RPI
6 Dec 2010
Anyway, back on topic, 004 emerged from Exeter Depot today and when I left it was over the back in one of the sidings, moved under its own power.
REVUpminster
3 Jan 2021
Paignton
Trying to work out realtime trains. 175115+175112 came out of Laira to Plymouth. One train left late possibly 112 to Exeter missing out the Paignton run only going as far as Newton Abbot then now back to Exeter.
Goldfish62
14 Feb 2010
To put 1000 miles into perspective
Penzance to Exeter about 10 times (or 5 return trips) for 1000 miles
If they did Penzance-Taunton instead, then about 4 return trips
Taunton isn't in normal operating area, but they are delivered via Taunton
The update from Modern Railways states that it's Penzance-Exeter runs and each unit is expected to take around a week to complete this.
And, as trains start accumulating fault-free miles between Exeter and Penzance – around seven round trips – it is expected each train will take around a week to complete this.
REVUpminster
3 Jan 2021
Paignton
Exeter to Penzance is 131 miles so one round trip and 260 miles. 2C05 diagram does that twice in a day so half the mileage done. 003 was regularly doing but has disappeared. 115 doing it today though running late.
112 running between Exeter-Newton Abbotand Exeter-Plymouth accumulating mileage
RPI
6 Dec 2010
112 is currently in service on the 15:27 Exeter to Penzance, rather cosy too as Crosscountry have just terminated one at Newton Abbot and piled them on here!
BillStampy
6 Jan 2024
Llanharan
115 is meant to be on that according to RTT, are the units the wrong way around?
Apedlar12
13 Apr 2017
Can confirm 112 is on the training runs as I just saw it pass the cameras in Dawlish.
RPI
6 Dec 2010
Could have sworn it was 112, but didn't take too much notice :D
REVUpminster
3 Jan 2021
Paignton
Just clocked on and 115 cancelled Par to Exeter and it's the connecting train at Exeter for Bristol.
5E90 150 to Exeter was in the platform at Par and went off. I'm sure the passengers were impressed, not.
115 as 5E28 terminating at Plymouth
When the two trains were at Par, I wonder if they asked the guard of 115 to go on the 150 so it could go passenger to Exeter.
5E90 has gone into the siding south of platform 3
XFeed
25 Nov 2025
Chester
AWS sunflowers that are not visible in the hours of darkness. Union has stepped in and told drivers to fail sets where the sunflower isn't illuminated properly.
I don`t know if the sunflowers themselves have since been modified or not but I have seen one picture within the cab that shows that the sunflower mounting was now angled towards the driver with the probable intention to make it more visible, is this the case on all the units now ?
Prior to storage sunflowers were not illuminated but the yellow petals were painted with fluorescent paint for visibility during darkness and in a depot environment during the hours of darkness the sunflowers were visible. I don`t recall any driver defect reports asking for them to be replaced due to poor visibility.
irish_rail
30 Oct 2013
Plymouth
I don't know the reasons why, but Aslef are inisiting that the sunflowers be luminous in darkness. I suppose it's to match the rest of the GWR fleet, ie it's something that drivers are accustomed to. You point out that the sunflower is visible on depot, and that's half the problem. They are mistakenly coming off depot, then the driver at Plymouth station has to either fail set, or wait for daylight before working the train.
Siemens Staines
30 Jul 2015
Would waiting for daylight be the reason that 175006 only worked 2C05 0655 Exeter St Davids to Penzance forward from Plymouth today? A 166 deputised between Exeter and Plymouth.
Brush 4
25 Nov 2018
Is that the crux of the problem with all these failures then, sunflowers not illuminated?
REVUpminster
3 Jan 2021
Paignton
Quite a ridiculous state of affairs if so! I suspect that the sunflowers are only 1 issue of many...
Maybe the drivers don't want to stop listening to music on their earbuds.
Can only see 006 in passenger service and 112 out and about.
Still nothing from Wolverton this week. 10 weeks now.
Jrocks
27 Apr 2021
Torbay
Correct, and thats only because we had a spare turbo. If there was no spare then 2C05 would have simply started at Plymouth
REVUpminster
3 Jan 2021
Paignton
A train that can’t be used during the hours of darkness? Not sure I’ve heard of that before?
That explains why 115 was cancelled Par-Exeter last night. Did the guard have to act as ears for the driver in case he was deaf, or how did it get back to Laira?
