Class 175s to GWR
XFeed
25 Nov 2025
Chester
Usually, and I don't mean this sarcastically, if it's dripping water inside a 175 it means it's raining outside very heavily.
You know them so well :)
Nope, no sarcasm here!
Looks like they locked a coach out of use because of it. Because of that, was better to swap if out and allow Laira that extra bit of time to look into the fault and fix it since we had a bit of wiggle room in our fleet that day
As @craigybagel has mentioned water ingress has been problematic especially during heavy rain.
If the water leak was in a central area of the saloon the most common fault is that the saloon HVAC unit " duck bills " are probably blocked with debris not allowing the build up of condensation to drain out into the drainage channels and then to down the side of the train, when this happens it overflows the channel or channels and leaks into the saloon.
Apedlar12
13 Apr 2017
Looks like 175009 which was supposed to work 2C32 has been cancelled between Exeter and Plymouth. 150246 taking over from there.
009 has gone down from Exeter to Laira as 5C32 (RTT quoting a problem with the doors).
XFeed
25 Nov 2025
Chester
Aaaaww I was hoping that the door problems were behind them now after the numerous reports at the beginning.
REVUpminster
3 Jan 2021
Paignton
Is this the abortive trip from last Wednesday.
I notice it's in the timetable Mon-Fri so hedging their bets or serious training.
BillStampy
6 Jan 2024
Llanharan
I've noticed reliability has dropped quite a lot again, lots of different failures stated such as traction failure, brake failures and door failures. It really isn't a good look!
Apedlar12
13 Apr 2017
175111 currently failed in Exeter by the looks of it.
BillStampy
6 Jan 2024
Llanharan
Clearly couldn't have been too major as it's due back out today as of right now, possibly an issue the driver wasn't aware of which is another thing that is probably causing problems; the crew aren't used to the issues that come up and how to easily fix them!
As an aside, 175101 and 007 head up to Exeter 3E05 tomorrow then 007 heads down to be the first unit of the Class to Paignton, assuming everything goes well.
REVUpminster
3 Jan 2021
Paignton
I shall watch it go through Dawlish on coastcams then head for Paignton when it leaves Exeter.
There are optimum service operating today except the Busy train from Barnstaple is 158951 and Newquay's 175 not allocated at this time.
It's listed as 175101-175007 yet 175007 leaves first at 0650 then 175101 for Penzance at 0655.
The 3 car is leading so that is logical.
Odd test working 2Q34 between Chard and Exeter tomorrow, not sure if it 175 related, but I would assume it would make sense to clear them in case needed as substitutes on Axminster shuttles
REVUpminster
3 Jan 2021
Paignton
First 175 into Paignton
175007 leaving at 0750
RPI
6 Dec 2010
If it's going out to Riverside I doubt it's 175 related, is it the test train?
XFeed
25 Nov 2025
Chester
101 believed Passcom issues and 114 hazard (BIL) light problems so I hear.
Thanks and new faults that have not been mentioned on here before but having said that 114s hazard light on could be door related especially if only one car. There are 7 or 8 reasons that the hazard light can be illuminated on a 175.
PP57601
3 Jun 2019
They can't have a second 175 on the Newquay, something to do with some crews not signing them (yet)
Plymouth has two different sets of Drivers.
The more established (ex-Intercity HST Drivers) have not yet been released to learn 175’s, so one Newquay diagram has to remain as a 150 until further notice.
