Class 156s to Neville Hill
bigmanaiq
29 May 2025
yorkshire
Hearing from a friend 156402 is now based out of Neville Hill - is this true and if it is will any more units follow?
pokemonsuper9
20 Dec 2022
Greater Manchester
Interesting, has that moved from Newton Heath (and has anything moved in return)?
I believe 156402 has been out of service for some time.
Tractor37
23 May 2017
Not heard anything in the messroom. There’s only a few of us based at Leeds that still sign 156’s. Although they still appear occasionally at Neville Hill to use the wheel lathe
Geeves
6 Jan 2009
Rochdale
As others have said if Northern move it themselves it's usually over a day or two while they get the drivers arranged
Used to be easier when they cycled them via the Calder Valley, Huddersfield or Sheffield to Manchester but those days are over now.
Adam0984
18 Feb 2014
Theyre now mostly moved by ROG as too much traction knowledge has lapsed to make it viable. Very few Leeds and York drivers still sign them to get them Newcastle to Leeds and Leeds to Neville Hill
Soft Hands
27 Dec 2020
Bolton
It last worked a passenger train in the North West towards the end of April. It then went to Heaton for C4 bogie work / replacement wheelsets. Presumably corrosion issues were then identified that required the move in Mid June to Brodies at Kilmarnock. The photos of it at the time appear to show it already on replacement bogies when it made the move from Heaton into Scotland.
diligentdave
20 Oct 2007
The movement should of been 158756 and 156402 but the 158 wasn't available to move and the timings couldn't be amended so the 156 still moved to Neville Hill for a move to Heaton on Thursday. 156402 is moving to Heaton for a little while to cover for other Angel 156's currently ongoing C6.
david l
27 Dec 2016
Wigan
Dave
156460 has also gone from NH to HT. Is this covering as well?
Tram203
15 Jun 2024
Always Changing
Apologies if off topic for the thread - but I stumbled across Heaton based 156485 at Manchester Victoria around lunchtime today...
Bikeman78
26 Apr 2018
They are a bit mixed up at the moment. Several Heaton units were trapped south of Whitehaven when the line closed. Sooner or later they will end up at Newton Heath for an exam and then likely turn out on any class 156 diagram.
Soft Hands
27 Dec 2020
Bolton
156421, 156440, 156469, 156483 and 156485 are the units in question!
td97
26 Jul 2017
156485 seems to be out on a Clitheroe circuit today
